ads1115
ads1115
we are trying to send a value to domoticz.
in the device we see the value, in the log we don't see the value, so its not send to domoicz.
What are we doing wrong?
- divice.PNG (30.78 KiB) Viewed 7563 times
Re: ads1115
What do the controller settings look like?
What does the plugin settings look like?
Re: ads1115
Do you see it coming into the Domoticz log at all? So many things could be wrong, you need to take it step by step.
First, check the controller settings. Are other values coming into Domoticz, or is this the only one?
Next, check the Domoticz log.
If you see something coming in there, check the idx.
Re: ads1115
Are you sure the idx is filled in correctly? In the screenshot I see IDX=1, highly unlikely...!gertvanwijk wrote: ↑11 Jul 2018, 21:58 we are trying to send a value to domoticz.
Re: ads1115
The settings to domoticz are correct. when i ad another sensor its no problem to get the value in domoticz.
I see those values in the green field in devices, and in the log off espeasy
I see the value in the device from the 1115 but i don't see the values in the espeasy log. i think this is the reason the don't get send to domoticz
Re: ads1115
Hmmm... unfortunately I don't have this device, so I can't reproduce the problem.gertvanwijk wrote: ↑12 Jul 2018, 08:06 The settings to domoticz are correct. when i ad another sensor its no problem to get the value in domoticz.
Anyone else?
Alternatively, from your name I deduct you are Dutch? Where are you located?
Re: ads1115
Could you also try the latest build?
There has been a fix in checking the values sent to the controller.
Re: ads1115
We have setup the latest build, 20180716
This is the result
We see the value's in the device. picture 1
We don't see the value from the ads1115 device in the log. picture 2
Can anyone tel me how this is possible!
This is the result
- 2.PNG (68.85 KiB) Viewed 7465 times
- 1.PNG (39.47 KiB) Viewed 7465 times
Re: ads1115
I don't see any set IDX value in your screenshot.
For Domoticz, you have to create a dummy device in Domoticz and look for its IDX value.
Then enable (and configure) the Domoticz controller in ESPeasy (HTTP or MQTT) and check the used controller in the plugin you want to sent data to Domoticz.
For Domoticz, you also have to add the IDX value to the selected controller on the plugin page.
Re: ads1115
I remember have a similar problem, setting up an S8 CO2 sensor. I defined the device in Domoticz and made sure the idx was in ESP, but no value came in.
After a lot of trial-and-error I ended with a dummy device, plus a small LUA script that copies the value from the dummy device into the environment sensor device.
The intermediate device was defined as a "custom sensor".
The script is really simple.
Device "$Dummy S8" is used to receive the value from the ESP, so this idx should be filled in on the device definitions there.
Device "SenseAir S8" is defined as Air Quality, Voltcraft CO-20.
Obviously this last device type is not the right one for you, but the principle should be the same.
Perhaps that could work here as well?
-- this script will copy CO2 values from the hidden custom-sensor device into the AirQuality device
commandArray = {}
if devicechanged['$Dummy S8'] then
val = tonumber(otherdevices_svalues['$Dummy S8'])
commandArray['UpdateDevice'] = otherdevices_idx['SenseAir S8']..'|'..val..'|0'
end
Re: ads1115
This is the result
This is the result
- 2.PNG (68.85 KiB) Viewed 7439 times
- 1.PNG (39.47 KiB) Viewed 7439 times
Re: ads1115
The ADS1115 plugin appears to send its log to LOG_LEVEL_DEBUG
So you may have to increase the log level of the web interface (Advanced settings).
That will show quite some more logs.
And you may want to use a newer build also.
A lot has been fixed since 0716.
Re: ads1115
Hi TD-er
This did the trick for us. thanks for the support.
Users browsing this forum: Ahrefs [Bot] and 132 guests
