ADS1115 and PT100 - EL skills needed
Lukeq
#1 Post by Lukeq » 21 Oct 2018, 18:08
Hello community
You may know BBQ. You also may know the company Weber. They build Grills for way to much money. So far, so well known.
I recently reverse engineered the Weber iGrill 3, which is in fact a pretty stupid Bluetooth thermometer with >>10m range for ~180€. So far, so well known.
Now, I want to create the same thing and improve. With ESPeasy, PT100 (they use 200k NTCs) and MQTT.
Therefore I added an ADS1115 with a sample PT100 (2wire for the beginning). I managed it, to measure the analog 3.3V thru henry's article.
Unfortunately I'm to stupid to calculate the Steinhart-Hart PT100 equation. Can someone help me with a correct T= formula please?
love, peace and ice cream
Lukas
PS: why can I add only 40chars in the formula input box?
HomeJCL
Re: ADS1115 and PT100 - EL skills needed
#2 Post by HomeJCL » 21 Oct 2018, 19:31
How do you wire the Pt100 ?
Do you have a 2 wire Temperature transmitter or is it a 2-wire Pt100 ?
With 2-wire TX it is fairly easy google 4-20mA on Arduino.
If you want to connect a Pt100 directly check this https://www.instructables.com/id/Readin ... g-Arduino/ haven’t read it but seems to address your question.
Although you can forego linearisation and extrapolate on the fairly linear behaviour and go for 0,385 Ohms/°C
Or you extrapolate a function in the most used curve part for your needs.
I use 2-wire TX.
Belgium and land of ESP ... counting :D
Lukeq
#3 Post by Lukeq » 22 Oct 2018, 08:49
PT100 directly, as I thought, the ADC can do the job.
In all samples I've seen, they use a voltage divider, which is as far as I know, not needed here. Or, can someone explain me, why I need this?
I have a reference voltage of the ADC and a resistor.
