PMS7003 no readings
PMS7003 no readings
The problem is easy to explain, the sensor does not work. Displays only zeros.
Wiring diagram according to this information -> https://www.letscontrolit.com/wiki/index.php/PMSx003
Connections checked (several times).
I use Wemos D1 mini Pro, with mega-20181218 (ESP_Easy_mega-20181220_dev_ESP8266_4096.bin).
How do you check if the sensor works?
Armageddon was yesterday, today we have a serious problem.
Re: PMS7003 no readings
How did you configure the plugin and how did you wire the dust sensor?
I did everything as described in the wiki
Just for a test:
Disconnect the connection from Sensor-SET to GPIO16 and connect the SET via a 10KOhm resistor to VCC (3.3V)
If something with rules does not work the GPIO16 might be permanently on "0" disabling the sensor.
When you put the Web log level to Debug en look in the web log window, don't you see messages like:
65666: PMSx003 : pm1.0=0, pm2.5=0, pm10=0, pm1.0a=0, pm2.5a=0, pm10a=32896
67466: PMSx003 : pm1.0=0, pm2.5=0, pm10=0, pm1.0a=0, pm2.5a=0, pm10a=32896
69274: PMSx003 : pm1.0=0, pm2.5=0, pm10=0, pm1.0a=0, pm2.5a=0, pm10a=0
71073: PMSx003 : pm1.0=0, pm2.5=0, pm10=0, pm1.0a=0, pm2.5a=0, pm10a=0
You could try to connect the PMS to an USB2Serial connector and see if it sends messages.
PMS5003 - almost same.
My setup is exactly the same as in the wiki. Gpios pulled with 10k resistors, 47yF buffering 5V
Lifetime-helper rule working. (Replaced longpulse with timer - cause there is an issue.)
Problem:
When the Sensor gets actived by timer, it lasts at least 15sec. to get the values.
And this is not even sure!
In some cases during the 15sec. timer-on, no reading is comming.
(After this15sec power-on, the power is 30sec off. And again from the beginning.)
In other cases, there are 2 readings (á 3 values) direct behind each other.
Or, the Sensor gets off (gpio16 0) and THEN values come.
It is not possible to get realtime-data from the Sensor, nor is it possible switch the Sensor on for a short time, grab the data and off again.
In the wiki (lifetimehelper), the Sensor gets on for 5sec. I have no Chance to get data.
What can I do?
My rules - I found 15sec is the min. power-on for the sensor.:
Here's a typical log:
Gpio,16,1 = Sensor on
Timer1= 45sec
Timer2=15sec Sensor (Gpio16) on
As you can see, on the first gpio16,1 nothing happens. the second gpio16,1 it takes a long time to get values.
Btw & off-topic: running with static IP, no wifi drops. Maybe this helps on other place.
Problem:
What can I do?
on System#Boot do
gpio,16,0
timerSet,1,30 //Mess-Start in 30 sec.
On Rules#Timer=1 do
GPIO,16,1
timerSet,2,15 //Messdauer - Datenübertragung 15 sec.
timerSet,1,45 // Messintervall 30 sec. (45-messdauer)
On Rules#Timer=2 do
GPIO,16,0
// Gpio,0,1 //reset
// timerSet,3,1
//On Rules#Timer=3 do
// Gpio,0,0
// endon
Timer1= 45sec
168565313: EVENT: Rules#Timer=1
168565324: ACT : GPIO,16,1
168565326: SW : GPIO 16 Set to 1
168565330: ACT : timerSet,2,15
168565340: ACT : timerSet,1,45
168565355: Command: timerset
168565356: Command: timerset
168581313: EVENT: Rules#Timer=2
168581328: ACT : GPIO,16,0
168581330: SW : GPIO 16 Set to 0
168582868: WD : Uptime 2810 ConnectFailures 0 FreeMem 14288
168611313: EVENT: Rules#Timer=1
168611324: ACT : GPIO,16,1
168611326: SW : GPIO 16 Set to 1
168611330: ACT : timerSet,2,15
168611339: ACT : timerSet,1,45
168611355: Command: timerset
168612868: WD : Uptime 2810 ConnectFailures 0 FreeMem 14288
168613314: EVENT: Clock#Time=Tue,18:04
168619983: EVENT: Partikelsensor#pm1.0=4.00
168620002: EVENT: Partikelsensor#pm2.5=6.00
168620036: EVENT: Partikelsensor#pm10=6.00
168627324: EVENT: Rules#Timer=2
168627343: ACT : GPIO,16,0
168627345: SW : GPIO 16 Set to 0
What do you mean with a long time?
Somewhere in the documentation of the device, I read it takes about 30 secondes for the device to stabilise after a wake up.
https://www.google.com/url?sa=t&rct=j&q ... xBwvyOFMaB
I read that too, but the lifetime-rule confused me. I thought, that rule is OK for that Sensor, but it is just an example.
I power on the Sensor for 15 sec now. Thats the minimum timing for my setup.
The Sensor values are OK. I compare them with an Airquality-sensor (AppliedSensor) which detects VOC (stinky organic Gases. Miefsensor)
You can see on both Sensors the smoke of a cigarette very well - and when it's time to close the window.
Users browsing this forum: No registered users and 136 guests
