New ESP gadget
Re: New ESP gadget
Probably never got booted into flash mode.
Re: New ESP gadget
I thought that as well. So I double-checked all connections.
Also, when I start the unit without GPIO0 connected to ground, I can see the blue LED flash twice quickly. When I start the unit with GPIO0 low, it only blinks once. So there definitely is a difference...
Re: New ESP gadget
Shardan wrote: ↑22 Dec 2017, 18:13 Always remember Ruskin's rule:
"There is hardly anything in the world that someone cannot make a little worse and sell a little cheaper, and the people who consider price alone are that person's lawful prey. It's unwise to pay too much, but it's worse to pay too little. When you pay too much, you lose a little money – that is all. When you pay too little, you sometimes lose everything, because the thing you bought was incapable of doing the thing it was bought to do. The common law of business balance prohibits paying a little and getting a lot – it can't be done. If you deal with the lowest bidder, it is well to add something for the risk you run, and if you do that you will have enough to pay for something better."
(John Ruskin)
The long version of the good old German saying "Wer billig kauft, kauft zwei mal", --> If you buy cheap, you buy twice. I concur
Re: New ESP gadget
You run into a tricky area considering the definition of the word "cheap".toffel969 wrote: ↑27 Feb 2018, 13:15Shardan wrote: ↑22 Dec 2017, 18:13 Always remember Ruskin's rule:
(John Ruskin)
Expensive: a 25000 Euro car that depreciates 40% in the first year.
Cheap: a 35000 Euro car that depreciates 20% in the first year.
I've seen examples of both. My point: price alone does not determine if a product is cheap or expensive.
Especially with the quickly dropping prices of Chinese hardware, it makes sense to keep an eye on new items and check them out.
Re: New ESP gadget
I've found a very nice looking 27x19x18mm sized ESP8266 module with one relay and one touch button.
https://www.ebay.com/itm/ESP8266-WIFI-I ... 1932199168
I currently using Sonoff Touch and Sonoff T1 for Lighting Control, so i do not see any use case for me, but still it is a very compact unit. Maybe for a smart smart 230V extension cable..
But as i see the RX and TX is near the crystal and not an easy task to solder it.
Re: New ESP gadget
I found a new device, looks like a redesigned Sonoff S20..
"WAZA Wifi Smart EU Plug Power Socket"
Anyone has it? I wonder if it could be flashed?
Re: New ESP gadget
By the way it's a Heltec Touch Relay:enesbcs wrote: ↑02 Mar 2018, 23:08 I've found a very nice looking 27x19x18mm sized ESP8266 module with one relay and one touch button.
https://github.com/xoseperez/espurna/wi ... ouch-Relay
Re: New ESP gadget
As i see this wifi door sensor is ESP based:
Anyone tested it already?
https://www.gearbest.com/smart-home-con ... id=1433363
Re: New ESP gadget
Cool one You get also quite a lot of additional sensors.enesbcs wrote: ↑13 Sep 2019, 17:39 ESP32 based Watch.
https://www.banggood.com/LILYGO-TTGO-T- ... 53613.html
Might be funny playground for making door entry keypad with display
Re: New ESP gadget
Does ESP Easy support the display?
Re: New ESP gadget
The display is an SPI connected ST7789V so i guess not.
Re: New ESP gadget
The new ESP32 clock:
https://www.tindie.com/products/ttgo/li ... atch-2020/
Re: New ESP gadget
Also saw this one yesterday, but I am not able to pre-order it.
LILYGO® TTGO T-Watch-2020 ESP32 Main Chip 1.54 Inch Touch Display Programmable Wearable Environmental Interaction
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 126 guests
