cannot get %eventvalue% to work
Moderators: BertB, rtenklooster, Voyager, Stuntteam, Martinus
bartv
#1 Post by bartv » 13 Jan 2018, 20:18
Hello forum,
using a sonoff module,
I put in rules as shown below.
when running " http://sonoff-12/control?cmd=event,TimerOn" in my browser
the LED is lit for 10 seconds, everything ok.
but when putting " http://sonoff-12/control?cmd=event,remoteTimerControl=5" in my browser
the LED blink shortly, sometimes very short, sometimes half a second.
It looks to me that the eventvalue is not forwarded ?
Pls help !
Regards, Bart
// LED off/on
on LedOff do
  gpio,13,1
on LedOn do
  gpio,13,0
on remoteTimerControl do
   event LedOn
   timerSet,1,%eventvalue%
on rules#timer=1 do
  event LedOff
on TimerOn do
  event LedOn
  timerset,2,10
on rules#timer=2 do
  event LedOff
Re: cannot get %eventvalue% to work
#2 Post by grovkillen » 13 Jan 2018, 21:00
Try this :
   event LedOn
Author of ESP Easy Flasher [use this for flash and wifi setup at flash time]
Author of ESP Easy Webdumper [use this for easy screendumping of your units]
For my private projects: https://testoftimes.com
bartv
#3 Post by bartv » 14 Jan 2018, 01:03
hello grovkillen, thanks for your reply,
but, nope, doesn't change a thing.
still irregular times between +/- 0.2 and 1 second.
reboot and power-off/on also doesn't help after changing rules (just to be sure)
behavior stays the same.
Bart
bartv
#4 Post by bartv » 14 Jan 2018, 01:05
oh, and tried to have the rule with %eventvalue% as first line in Rules,
so eventvalue is on second line, but that didn't help either.
Bart
vader
#5 Post by vader » 14 Jan 2018, 21:41
Take this version without any stupid rules....
"http://sonoff-12/control?cmd=longpulse+13%2C0%2C10" (example for 10 seconds)
Change the "10" to your needed value of seconds to turn LED on and that was it....
bartv
#6 Post by bartv » 15 Jan 2018, 20:47
Hello Vader,
yep that works!!
Still it is strange why eventvalue does not work
I cannot find the error in what i'm doing, but also nobody with the same problem using google.
It's very unlikely i'm the only one ;-)
But, for now, i can use your solution to what i'm creating, so thank you !!
Bart
vader
#7 Post by vader » 15 Jan 2018, 22:00
No problem, man. I have all that already behind me. And sometimes it's better not to be an engineer for simple solutions.... :D
This works also:
longpulse,13,0,%eventvalue%
bartv
#8 Post by bartv » 16 Jan 2018, 06:20
Hello Vader,
I'm sorry, but the rule you propose
event LedOn
has exactly the same result as my initial rule, it works, but the length of the timer is not correctly set.
The led now is lit for a short while, few tenths of a second, up to half a second.
so eventvalue is not passed through in this case either.
Bart
#9 Post by grovkillen » 16 Jan 2018, 06:35
bartv wrote:
16 Jan 2018, 06:20
Hello Vader,
event LedOn
Bart
He didn't propose this part :
event LedOn
I think you misunderstand the long pulse command, it will (given the example above, using state 0) turn the led off and when the given time is up turn it back on. No need for the event you added.
vader
#10 Post by vader » 16 Jan 2018, 09:24
bartv wrote:
16 Jan 2018, 06:20
Hello Vader,
event LedOn
Bart
My rule is only 3 lines long, yours has 4! "event LedOn" is nonsense, because you are already turning on the LED with "13,0" (inversed logic). I have tested the rule on my test board and it works like it should be. So %eventvalue% works....
Users browsing this forum: Bing [Bot] and 1 guest
