within Platformio I can build esp32dev
However i end up with an image with only a few devices
- esp32.png (14.14 KiB) Viewed 13229 times
So being a novice and not knowing how to select the devices for the build I edited the Framed OLED 36 device added the Nextion content, renaming all references to 75 to 36
but this then fails when compiling with the following errors? Any ideas?
Linking .pioenvs\esp32dev\firmware.elf
.pioenvs\esp32dev\src\ESPEasy.ino.cpp.o:(.literal._Z10Plugin_036hP11EventStructR6String+0x34): undefined reference to `ESPeasySoftwareSerial::ESPeasySoftwareSerial(unsigned char, unsigned char, bool, unsigned short)'
.pioenvs\esp32dev\src\ESPEasy.ino.cpp.o:(.literal._Z10Plugin_036hP11EventStructR6String+0x38): undefined reference to `ESPeasySoftwareSerial::begin(long)'
.pioenvs\esp32dev\src\ESPEasy.ino.cpp.o: In function `StringSumHelper::StringSumHelper(String const&)':
C:\Users\noobed\.platformio\packages\framework-arduinoespressif32\cores\esp32/WString.h:47: undefined reference to `ESPeasySoftwareSerial::ESPeasySoftwareSerial(unsigned char, unsigned char, bool, unsigned short)'
.pioenvs\esp32dev\src\ESPEasy.ino.cpp.o: In function `Plugin_036(unsigned char, EventStruct*, String&)':
C:\Users\noobed\.platformio\packages\framework-arduinoespressif32\cores\esp32/WString.h:47: undefined reference to `ESPeasySoftwareSerial::begin(long)'
*** [.pioenvs\esp32dev\firmware.elf] Error 1
