I'am trying to make an burglar alarm work with my ESPEasy.
In ESPEasy it generates an Valua 0 in rest and an 1 in alarm situation.
I configurated your IFTTT Maker as in your description.
22 string key found at https://ifttt.com/maker_webhooks (the digits shown here as dots at https://maker.ifttt.com/use/......)
I installed IFTTT on my iphone and pc.
I chose for Pushbullet and installed it also.
I tested 4 applets and nighter of them worked yet
1st and 2nd: as trigger IFTTT (chosen: "new service activated by you") and as actioner 1 with SMS en the second applet with Pushbullet)
3rd and 4th: as trigger Button widget and as actioner 1 with SMS en the second applet with Pushbullet).
There is still something wrong in my thinking, can you please help me to make this work?
Jan
IFTTT Maker
Re: IFTTT Maker
The IFTTT key length has been changed. Actually it is 43 characters.
Could you change your solution?
Norbert
Norbert
Re: IFTTT Maker
Just a thought, would the pulse counter not work for the doorbell?
It might still take 5 seconds to read the single pulse but should be reliable.
Iv'e been using the pulse counter plugin for a water meter and it seems spot-on.
Re: IFTTT Maker
Is it possible to send by email the value of the esp %ip% using the IFTT Marker and plugin "Extra Utilities" and "_P209_IFTTTMAKER" ?
thanks
Carlini
thanks
Carlini
Re: IFTTT Maker
Firstly, thank you to everyone involved in making ESP_Easy what it is. I've not long been using it and it is fantastic.
I'm having the same issue - I just can't seem to get it to send to ifttt under rules.
I've tried every combo I can think of. e.g.:
on extrearpir do
SendToHTTP,maker.ifttt.com,443,/trigger/ExtRearPir/with/key/MYKEY
There are no errors in the log and it appears to respond ok:
6683213: EVENT: extrearpir
6683219: ACT : SendToHTTP,maker.ifttt.com,443,/trigger/ExtRearPir/with/key/MYKEY
6683232: Command: sendtohttp
6683234: EVENT: extrearpir Processing time:21 milliSeconds
6691848: WD : Uptime 112 ConnectFailures 0 FreeMem 19352
6702705: EVENT: Clock#Time=Tue,15:19
6702711: EVENT: Clock#Time=Tue,15:19 Processing time:5 milliSeconds
If I send :
https://maker.ifttt.com/trigger/ExtRear ... /key/MYKEY (it seems to have truncated this line but you can see the url in the browser)
directly from any browser it works fine.
Just to add, I've tried with a space instead of the comma after sendtohttp, space with a comma, etc. as there seems to be a few opinions on format. I'm more than happy to be called a dope and got it completely wrong.
I would be very grateful for any ideas.
Thank you.
on extrearpir do
If I send :
Thank you.
Re: IFTTT Maker
Dear namirda
Do you have a New Version of Plugin IFTTT MAKER for espeasy 2.0 ?
tks
tks
Re: IFTTT Maker
Try this
SendToHTTP maker.ifttt.com,80,/trigger/YOURS_IFTT_TRIGGER/with/key/YOURS_IFTT_KEYS
In my case works very well.
Geoffers wrote: ↑03 Jul 2018, 16:26 Firstly, thank you to everyone involved in making ESP_Easy what it is. I've not long been using it and it is fantastic.
on extrearpir do
If I send :
Thank you.
Users browsing this forum: Google [Bot] and 111 guests
