Nextion display plugin
Re: Nextion display plugin
Sounds like a good idea to me.
@TD-er: I was hoping to hear that there was a built-in method to postpone plugin Write events. Since that was wishful thinking, your suggestion (thanks!) is where I will go.
I looked through the ESP Easy code and can't find an existing string Queue routine to use. I don't want to re-invent the wheel so I prefer using a library function. There are a couple published queue handlers available, but that means it would have to be installed. Like this one:
https://playground.arduino.cc/Code/QueueList
Is adding another library frowned upon or is it a normal thing for the ESP Easy developers to do? Any guidance on this is appreciated.
Also, enhancing the ESPeasySoftwareSerial module to add functions to switch between hardware (both swap and USB) and soft serial would be fantastic. I'd be happy to contribute to the effort (not as a project leader, but can do some grunt work like testing/validation).
@BertB: Any chance you can try out the new V3 Nextion code and perform some validation? BTW, I found an odd issue with TaskDeviceName that required me to make some code changes shortly after I published it. So copy the V3 plugin's code again to ensure you have the revised V3.
@ThomasB, I will do the testing.
@ThomasB
After I installed your latest version V3, I started with using D7 and D8 as Rx and Tx, with the Use Hardware Serial left unchecked.
Initially this works fine, but for some reason, I get unintended events. It is as if press a switch (1274) on the Nextion, but I don't.
It happens once every minute and this is the serial log.
600472 : LoadFromFile: config.dat index: 4096 datasize: 472
600475 : LoadFromFile: config.dat index: 5120 datasize: 768
600537 : LoadFromFile: config.dat index: 6144 datasize: 472
600543 : LoadFromFile: config.dat index: 4096 datasize: 472
600572 : LoadFromFile: config.dat index: 6144 datasize: 472
600575 : LoadFromFile: config.dat index: 4096 datasize: 472
600603 : LoadFromFile: config.dat index: 6144 datasize: 472
600606 : LoadFromFile: config.dat index: 4096 datasize: 472
600637 : LoadFromFile: config.dat index: 6144 datasize: 472
600639 : LoadFromFile: config.dat index: 4096 datasize: 472
600676 : EVENT: E16Nextion#idx=1274.00
600684 : ACT : SendToHTTP xxx.xxx.xxx.xxx,8080,/json.htm?type=command¶m=switchlight&idx=387&switchcmd=Toggle
600700 : Command: sendtohttp
600732 : HTTP/1.1 200 OK
600770 : EVENT: E16Nextion#idx=1274.00 Processing time:94 milliSeconds
600771 : EVENT: E16Nextion#value=0.00
600795 : EVENT: E16Nextion#value=0.00 Processing time:25 milliSeconds
600796 : LoadFromFile: config.dat index: 28672 datasize: 724
600814 : Domoticz: Sensortype: 5 idx: 1 values: 1274;0
600815 : MQTT : {"idx":1,"RSSI":3,"nvalue":0,"svalue":"1274;0"}
600818 : LoadFromFile: config.dat index: 29696 datasize: 724
600837 : HTTP : connecting to xxx.xxx.xxx.xxx:8080
600851 : Domoticz: Sensortype: 5 idx: 310 values: 1274;0
600881 : HTTP : Success
600888 : HTTP : closing connection
600985 : NEXTION075 : WRITE, Command is page3.b5.bco=48631
601472 : LoadFromFile: config.dat index: 6144 datasize: 472
603475 : EVENT: Clock#Time=Sat,23:02
603500 : EVENT: Clock#Time=Sat,23:02 Processing time:25 milliSeconds
603571 : LoopStats: shortestLoop: 46 longestLoop: 1137307 avgLoopDuration: 128.59 systemTimerDuration: 21.62 systemTimerCalls: 32 loopCounterMax: 652173 loopCounterLast: 230924 countFindPluginId: 0
603580 : PluginStats P_37_Generic - MQTT Import READ Count: 1 Avg/min/max 2541.00/2541/2541 usec
603589 : PluginStats P_37_Generic - MQTT Import ONCE_A_SECOND Count: 31 Avg/min/max 2177.32/2127/2541 usec
603599 : PluginStats P_37_Generic - MQTT Import TEN_PER_SECOND Count: 297 Avg/min/max 2225.59/2083/3868 usec
603609 : PluginStats P_37_Generic - MQTT Import WRITE Count: 2 Avg/min/max 2311.50/2094/2529 usec
603619 : PluginStats P_37_Generic - MQTT Import EVENT_OUT Count: 1 Avg/min/max 2813.00/2813/2813 usec
603629 : PluginStats P_37_Generic - MQTT Import SERIAL_IN Count: 1 Avg/min/max 2068.00/2068/2068 usec
603639 : PluginStats P_37_Generic - MQTT Import FIFTY_PER_SECOND Count: 1476 Avg/min/max 2147.14/2055/2684 usec
603647 : PluginStats P_71_Display - Nextion [TESTING_V3] READ Count: 1 Avg/min/max 200096.00/200096/200096 usec
603658 : PluginStats P_71_Display - Nextion [TESTING_V3] ONCE_A_SECOND Count: 31 Avg/min/max 34.45/26/47 usec
603668 : PluginStats P_71_Display - Nextion [TESTING_V3] TEN_PER_SECOND Count: 297 Avg/min/max 133.53/122/159 usec
603679 : PluginStats P_71_Display - Nextion [TESTING_V3] WRITE Count: 3 Avg/min/max 7632.00/134/22608 usec
603689 : PluginStats P_71_Display - Nextion [TESTING_V3] EVENT_OUT Count: 1 Avg/min/max 58.00/58/58 usec
603700 : PluginStats P_71_Display - Nextion [TESTING_V3] SERIAL_IN Count: 1 Avg/min/max 47.00/47/47 usec
603710 : PluginStats P_71_Display - Nextion [TESTING_V3] FIFTY_PER_SECOND Count: 1476 Avg/min/max 38.09/27/48 usec
603720 : Load File stats: Count: 13 Avg/min/max 4399.46/1332/19547 usec
603726 : Plugin call 50 p/s stats: Count: 1476 Avg/min/max 3122.74/2974/3819 usec
603734 : Plugin call 10 p/s stats: Count: 297 Avg/min/max 3275.19/3090/4900 usec
603741 : Plugin call 10 p/s U stats: Count: 297 Avg/min/max 3235.36/2997/3832 usec
603748 : Plugin call 1 p/s stats: Count: 31 Avg/min/max 18967.03/4096/425777 usec
603756 : checkSensors() stats: Count: 31 Avg/min/max 14398.42/547/422162 usec
603763 : sendData() stats: Count: 1 Avg/min/max 217326.00/217326/217326 usec
603771 : Compute formula stats: Count: 1 Avg/min/max 19.00/19/19 usec
603777 : WD : Uptime 10 ConnectFailures 0 FreeMem 14200
That's very interesting. Is it reliably happening every minute, or does the time vary?
On the bottom of the Nextion plugin web access page, directly above the Values names, is a Interval time scroll box. What is the value [sec] entered there?
@ThomasB
It is 60 seconds, give or take a few.
The delay also is 60 sec.
Ok, then you are seeing expected behavior. The last received idx and value are stored. Then at each elapsed timer interval the idx and value are resent.
I assume that this is how other plugins' Interval function works. If not then I'll need to know what the expected behavior is so this plugin follows the ESPeasy standards.
The workaround? You can create a rule that sets the idx and value to 0 after your MQTT is sent. Then ignore 0 on future interval updates. In my home automation installation (Openhab) I have local rules that only trigger when the data changes. So repeated values are ignored.
Two comments on that.
1 I cannot remember thuis happening with the original version.
2 In this case the event only triggers a rule. Idx will be id of the switch. Value is always 0.
I will test this in more detail tomorrow.
No code changes were made that would affect this behavior, so you'll find that the original does it too. But if this is wrong then we can fix it.
Edit #1: My Nextion sends custom idx codes that range from 10 to 30. I don't sent Nextion Touch events, but have a rule for them in case I decide to do that in the future. So here's a ESPeasy rule example that sends a MQTT to my home controller, then masks the sent data (set to -1) so it can be ignored by the rule when the timer intervals occur:
Edit #2: I expect others will share your feelings about the repeating idx and value. So I have a solution; We can allow the user to disable the interval timer (set Interval to 0 secs). But let's talk about this some more after your validation is further along. All the needed changes can be folded into the next beta revision.
Thanks for doing the testing!
As an alternative you can set both to -1 (or any other number) after your MQTT. Just choose a number that does not normally occur so that you can ignore it.In this case the event only triggers a rule. Idx will be id of the switch. Value is always 0.
on NEXTION#idx do
if [NEXTION#idx]>=10 and [NEXTION#idx]<=30
Publish /%sysname%/NEXTION/idx,[NEXTION#idx]
if [NEXTION#idx]>=500 // Touch Events
Publish /%sysname%/NEXTION/value,[NEXTION#value]
NEXTION#value = -1
NEXTION#idx = -1
I dare to disagree . I carried out some investigation and found out that your latest (7-13-2018) code has the flaw, whereas my latest modification (07082018) has not.
Just to be sure, below both versions. Off course, there is a lot of difference between them.
07082018 version:
//################################### Plugin 075: Nextion <info@sensorio.cz> ###########################
//################################### Created on the work of majklovec ###########################
#ifdef USES_P075
#define PLUGIN_075
#define PLUGIN_ID_075 75
//#define PLUGIN_NAME_075 "Display - Nextion [TESTING]"
#define PLUGIN_NAME_075 "Display - Nextion [BERTB REV3]"
#define PLUGIN_VALUENAME1_075 "code"
#define PLUGIN_VALUENAME2_075 "value"
#define Nlines 12 // The number of different lines which can be displayed - each line is 64 chars max
boolean Plugin_075_init = false;
boolean Plugin_075(byte function, struct EventStruct *event, String &string) {
boolean success = false;
switch (function) {
case PLUGIN_DEVICE_ADD: {
Device[++deviceCount].Number = PLUGIN_ID_075;
Device[deviceCount].Type = DEVICE_TYPE_DUAL;
Device[deviceCount].VType = SENSOR_TYPE_DUAL;
Device[deviceCount].PullUpOption = true;
Device[deviceCount].ValueCount = 2;
case PLUGIN_GET_DEVICENAME: {
string = F(PLUGIN_NAME_075);
case PLUGIN_GET_DEVICEVALUENAMES: {
strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[0],PSTR(PLUGIN_VALUENAME1_075));
strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[1],PSTR(PLUGIN_VALUENAME2_075));
success = true;
case PLUGIN_GET_DEVICEGPIONAMES: {
int rxPin = Settings.TaskDevicePin1[event->TaskIndex];
int txPin = Settings.TaskDevicePin2[event->TaskIndex];
if ((rxPin == 3 && txPin == 1) || (rxPin == 13 && txPin == 15)) {
event->String1 = F("GPIO HW RX ←");
event->String2 = F("GPIO HW TX →");
else { // Soft Serial.
event->String1 = F("GPIO SS RX ←");
event->String2 = F("GPIO SS TX →");
case PLUGIN_INIT: {
/* LoadTaskSettings(event->TaskIndex);
if (Settings.TaskDevicePin1[event->TaskIndex] != -1)
Plugin_075_RXpin = Settings.TaskDevicePin1[event->TaskIndex];
if (Settings.TaskDevicePin2[event->TaskIndex] != -1)
Plugin_075_TXpin = Settings.TaskDevicePin2[event->TaskIndex];
if (!nextion) {
nextion = new ESPeasySoftwareSerial(Plugin_075_RXpin , Plugin_075_TXpin);
Serial.begin(9600);
Serial.flush();
Serial.swap();
Plugin_075_init = true;
success = true;
case PLUGIN_TEN_PER_SECOND: {
if(Plugin_075_init) {
char __buffer[80];
uint16_t i;
uint8_t c;
String Vidx;
String Nvalue;
String Svalue;
String Nswitch;
while (Serial.available() > 0) {
delay(10);
c = Serial.read();
if (0x65 == c) {
if (Serial.available() >= 6) {
__buffer[0] = c;
for (i = 1; i < 7; i++) {
__buffer[i] = Serial.read();
__buffer[i] = 0x00;
if (0xFF == __buffer[4] && 0xFF == __buffer[5] && 0xFF == __buffer[6]) {
UserVar[event->BaseVarIndex] = __buffer[1] * 256 + __buffer[2];
UserVar[event->BaseVarIndex + 1] = __buffer[3];
String log = F("Nextion : code: ");
log += __buffer[1];
log += ",";
log += __buffer[2];
log += ",";
log += __buffer[3];
addLog(LOG_LEVEL_INFO, log);
sendData(event);
success = true;
else success = false;
return success;
else if (c == '|') {
i = 1;
__buffer[0] = c;
c=0;
if (__buffer[i]==0x0d) break;
i++;
__buffer[i] = 0x00;
String tmpString = __buffer;
int argIndex = tmpString.indexOf(F(",i"));
int argEnd = tmpString.indexOf(',', argIndex + 1);
if (argIndex)
Vidx = tmpString.substring(argIndex + 2,argEnd);
switch (__buffer[1]){
case 'u':
argIndex = argEnd;
argEnd = tmpString.indexOf(',',argIndex + 1);
if (argIndex)
Nvalue = tmpString.substring(argIndex + 2,argEnd);
argIndex = argEnd;
argEnd = tmpString.indexOf(0x0a);
if (argIndex)
Svalue = tmpString.substring(argIndex + 2,argEnd);
case 's':
argIndex = argEnd;
if (argIndex)
if (Nvalue == F("On"))
Svalue='1';
if (Nvalue == F("Off"))
Svalue='0';
default:
success = false;
return success;
UserVar[event->BaseVarIndex] = Vidx.toFloat();
UserVar[event->BaseVarIndex+1] = Svalue.toFloat();
String log = F("Nextion : send command: ");
log += __buffer;
log += UserVar[event->BaseVarIndex];
sendData(event);
ExecuteCommand(VALUE_SOURCE_SYSTEM, __buffer);
success = true;
case PLUGIN_ONCE_A_SECOND: {
success = true;
case PLUGIN_WEBFORM_SAVE: {
String argName;
char deviceTemplate[Nlines][64];
for (byte varNr = 0; varNr < Nlines; varNr++)
String arg = F("Plugin_075_template");
arg += varNr + 1;
String tmpString = WebServer.arg(arg);
strncpy(deviceTemplate[varNr], tmpString.c_str(), sizeof(deviceTemplate[varNr])-1);
deviceTemplate[varNr][63]=0;
// strncpy(deviceTemplate[varNr], WebServer.arg(argName).c_str(), sizeof(deviceTemplate[varNr]));
success = true;
case PLUGIN_WEBFORM_LOAD: {
LoadCustomTaskSettings(event->TaskIndex, (byte*)&deviceTemplate, sizeof(deviceTemplate));
addFormTextBox(String(F("Line ")) + (varNr + 1), String(F("Plugin_075_template")) + (varNr + 1), deviceTemplate[varNr], 64);
success = true;
/* case PLUGIN_EXIT:
if (nextion)
delete nextion;
nextion=NULL;
case PLUGIN_READ: {
String newString;
for (byte x = 0; x < Nlines; x++) {
String tmpString = deviceTemplate[x];
if (tmpString.length())
int rssiIndex = tmpString.indexOf(F("rssi"));
if(rssiIndex >= 0)
int barVal;
newString = tmpString.substring(0, rssiIndex);
int nbars = WiFi.RSSI();
if (nbars < -100)
barVal=0;
else if (nbars >= -100 and nbars < -90)
barVal=20;
else if (nbars >= -90 and nbars < -80)
barVal=40;
else if (nbars >= -80 and nbars < -70)
barVal=60;
else if (nbars >= -70 and nbars < -60)
barVal=80;
else if (nbars >= -60)
barVal=100;
newString += String(barVal,DEC);
newString = parseTemplate(tmpString, 0);
sendCommand(newString.c_str());
success = false;
case PLUGIN_WRITE: {
String tmpString = string;
if (argIndex)
tmpString = tmpString.substring(0, argIndex);
if (tmpString.equalsIgnoreCase(F("NEXTION"))) {
argIndex = string.indexOf(',');
tmpString = string.substring(argIndex + 1);
sendCommand(tmpString.c_str());
// Serial.println(tmpString);
success = true;
return success;
void sendCommand(const char *cmd) {
Serial.print(cmd);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
#endif // USES_P075
//################################### Revisions by BertB and ThomasB ###########################
//################################### Last Revision: July-13-2018 (TB) ###########################
#ifdef USES_P075
#include <ESPeasySoftwareSerial.h>
// Defines start here
// Plug-In defines
#define PLUGIN_075
#define PLUGIN_NAME_075 "Display - Nextion [TESTING_V3]"
#define PLUGIN_VALUENAME1_075 "idx"
#define Nlines 12 // Qty of "optional" user entered Command-Text strings, 64 chars max per line.
// Nextion defines
#define RXBUFFSZ 80 // Local Serial RxD buffer.
#define TOUCH_BASE 500 // Base offset for 0X65 Touch Event.
// Serial defines
#define B9600 0
#define B38400 1
#define B57600 2
#define B115200 3
#define DEFAULT_BAUD B9600
// Global vars
ESPeasySoftwareSerial *SoftSerial = NULL;
int rxPin = -1;
int txPin = -1;
// PlugIn starts here
boolean Plugin_075(byte function, struct EventStruct *event, String& string)
static boolean HwSerial = false;
static boolean AdvHwSerial = false;
uint32_t AdvHwBaud = 9600UL;
switch (function) {
AdvHwSerial = Settings.TaskDevicePluginConfig[event->TaskIndex][0];
event->String1 = F("GPIO SS RX ← ");
event->String2 = F("GPIO SS TX → ");
if(AdvHwSerial == true) {
event->String1 = F("GPIO HW RX ← ");
event->String2 = F("GPIO HW TX → ");
if (!((rxPin == 3 && txPin == 1) || (rxPin == 13 && txPin == 15))) { // Hardware Serial Compatible?
Settings.TaskDevicePluginConfig[event->TaskIndex][0] = false; // Not HW serial compatible, Reset Check Box.
if (rxPin == 3 && txPin == 1) { // USB Port?
if(Settings.TaskDevicePluginConfig[event->TaskIndex][0]==false && // Hardware serial disabled.
Settings.TaskDeviceEnabled[event->TaskIndex] == true) { // Plugin is enabled.
Settings.TaskDevicePluginConfig[event->TaskIndex][0]=true; // USB port access uses HW serial, Force set Check Box.
if (Settings.TaskDevicePluginConfig[event->TaskIndex][0] == false) { // Softserial mode.
Settings.TaskDevicePluginConfig[event->TaskIndex][1] = B9600; // Reset to 9600 baud.
addFormSeparator(2);
addFormSubHeader(F("Enhanced Serial Communication"));
addFormCheckBox(F("Use Hardware Serial"), F("AdvHwSerial"), Settings.TaskDevicePluginConfig[event->TaskIndex][0]);
byte choice = Settings.TaskDevicePluginConfig[event->TaskIndex][1];
String options[4];
options[0] = F("9600");
options[1] = F("38400");
options[2] = F("57600");
options[3] = F("115200");
addFormSelector(F("Baud Rate"), F("plugin_075_baud"), 4, options, NULL, choice);
addFormNote(F("Un-check box for Soft Serial communication (low performance mode, 9600 Baud)."));
addFormNote(F("Hardware Serial is available when the GPIO pins are RX=D7 and TX=D8."));
addFormNote(F("D8 (GPIO-15) requires a Buffer Circuit (PNP transistor) or ESP boot may fail."));
addFormNote(F("Do <b>NOT</b> enable the Serial Log file on Tools->Advanced->Serial Port."));
// ** DEVELOPER DEBUG MESSAGE AREA **
// addFormNote(ExtraTaskSettings.TaskDeviceName); // Debug value.
// int datax = (int)(Settings.TaskDeviceEnabled[event->TaskIndex]); // Debug value.
// String Data = "Debug. Plugin Enable State: ";
// Data += String(datax);
// addFormNote(Data);
addFormSubHeader(F("")); // Blank line, vertical space.
addFormHeader(F("Nextion Command-Text Strings (Optional)"));
for (byte varNr = 0; varNr < Nlines; varNr++) {
success = true;
String argName;
arg += varNr + 1;
if(ExtraTaskSettings.TaskDeviceName[0]==0) { // User forgot to enter device name!
strcpy(ExtraTaskSettings.TaskDeviceName,"NEXTION"); // Give standard name.
Settings.TaskDevicePluginConfig[event->TaskIndex][0] = isFormItemChecked(F("AdvHwSerial"));
Settings.TaskDevicePluginConfig[event->TaskIndex][1] = getFormItemInt(F("plugin_075_baud"));
success = true;
case PLUGIN_INIT: {
uint8_t BaudCode = Settings.TaskDevicePluginConfig[event->TaskIndex][1];
if(BaudCode > B115200) BaudCode = B9600;
const uint32_t BaudArray[4] = {9600UL, 38400UL, 57600UL, 115200UL};
AdvHwBaud = BaudArray[BaudCode];
if (Settings.TaskDevicePin1[event->TaskIndex] != -1) {
if (Settings.TaskDevicePin2[event->TaskIndex] != -1) {
if (SoftSerial != NULL) {
delete SoftSerial;
SoftSerial = NULL;
String log = F("NEXTION075 : serial pin config RX:");
log += rxPin;
log += F(", TX:");
log += txPin;
if(Settings.TaskDeviceEnabled[event->TaskIndex]==true)
log += F(", Plugin Enabled"); // Plugin is enabled.
else log += F(", Plugin Disabled");
if(Settings.TaskDeviceEnabled[event->TaskIndex] == true) { // Plugin is enabled.
// Hardware serial is RX on 13 and TX on 15 (swapped hw serial)
if (AdvHwSerial && rxPin == 13 && txPin == 15) {
log = F("NEXTION075 : Using swap hardware serial");
HwSerial = true;
Settings.UseSerial = false; // Disable global Serial port.
Settings.SerialLogLevel = 0; // Disable logging on serial port.
Settings.BaudRate = AdvHwBaud; // Set BaudRate for Nextion.
Serial.flush();
Serial.begin(AdvHwBaud);
Serial.swap();
// Hardware serial is RX on 3 and TX on 1. USB serial for Nextion IDE (User MCU Input function).
else if(AdvHwSerial && rxPin == 3 && txPin == 1) {
log = F("NEXTION075 : Using USB hardware serial");
HwSerial = true;
Serial.flush();
else {
log = F("NEXTION075 : Using software serial");
HwSerial = false;
if (SoftSerial == NULL) {
SoftSerial = new ESPeasySoftwareSerial(rxPin, txPin);
SoftSerial->begin(9600);
SoftSerial->flush();
else {
success = true;
case PLUGIN_READ: { // Get Plugin's optional command-text strings. Special RSSIBAR bargraph keyword is supported.
int RssiIndex;
String newString;
String tmpString;
String UcTmpString;
if (tmpString.length()) {
UcTmpString = deviceTemplate[x];
UcTmpString.toUpperCase();
RssiIndex = UcTmpString.indexOf(F("RSSIBAR")); // RSSI bargraph Keyword found, wifi value in dBm.
if(RssiIndex >= 0) {
int barVal;
newString = tmpString.substring(0, RssiIndex);
if (nbars < -100 || nbars >= 0)
barVal=0;
else if (nbars >= -100 && nbars < -95)
barVal=5;
else if (nbars >= -95 && nbars < -90)
barVal=10;
else if (nbars >= -90 && nbars < -85)
barVal=20;
else if (nbars >= -85 && nbars < -80)
barVal=30;
else if (nbars >= -80 && nbars < -75)
barVal=45;
else if (nbars >= -75 && nbars < -70)
barVal=60;
else if (nbars >= -70 && nbars < -65)
barVal=70;
else if (nbars >= -65 && nbars < -55)
barVal=80;
else if (nbars >= -55 && nbars < -50)
barVal=90;
else if (nbars >= -50)
barVal=100;
else {
sendCommand(newString.c_str(), HwSerial);
success = true;
if (argIndex) tmpString = tmpString.substring(0, argIndex);
// String log = F("TaskDeviceName : ");
// log += ExtraTaskSettings.TaskDeviceName;
// addLog(LOG_LEVEL_INFO, log);
// if (tmpString.equalsIgnoreCase(ExtraTaskSettings.TaskDeviceName)) { // Use Plugin Name as command ID name.
sendCommand(tmpString.c_str(), HwSerial);
String log = F("NEXTION075 : WRITE, ");
log += F("Command is ");
log += (tmpString.c_str());
success = true; // Set true only if plugin found a command to execute.
case PLUGIN_EXIT: {
if (SoftSerial) {
delete SoftSerial;
SoftSerial=NULL;
if(HwSerial) {
HwSerial = false;
Settings.UseSerial = DEFAULT_USE_SERIAL;
Settings.BaudRate = DEFAULT_SERIAL_BAUD;
Serial.flush();
Serial.begin(DEFAULT_SERIAL_BAUD); // Restart Serial Logging with default baud.
success = true;
uint16_t i;
uint8_t c;
uint8_t charCount;
String log;
String Vidx;
String Nvalue;
String Svalue;
String Nswitch;
char __buffer[RXBUFFSZ+1];
if(HwSerial) charCount = Serial.available(); // Prime the Hardware Serial engine.
else charCount = SoftSerial->available(); // Prime the Soft Serial engine.
while (charCount) { // This is the serial engine. It processes the serial Rx stream.
if(HwSerial) c = Serial.read();
else c = SoftSerial->read();
if (c == 0x65) {
if (charCount < 6) delay((5/(AdvHwBaud/9600))+1); // Let's wait for a few more chars to arrive.
if (HwSerial) charCount = Serial.available();
if (charCount >= 6) {
__buffer[0] = c;
if(HwSerial) __buffer[i] = Serial.read();
else __buffer[i] = SoftSerial->read();
__buffer[i] = 0x00;
UserVar[event->BaseVarIndex] = (__buffer[1] * 256) + __buffer[2] + TOUCH_BASE;
log = F("NEXTION075 : code: ");
log += __buffer[1];
log += ",";
log += __buffer[2];
log += ",";
log += __buffer[3];
sendData(event);
else {
if (c == '|') {
__buffer[0] = c;
if (charCount < 8) delay((9/(AdvHwBaud/9600))+1); // Let's wait for more chars to arrive.
else delay((3/(AdvHwBaud/9600))+1); // Short wait for tardy chars.
if(HwSerial) {
i = 1;
while (Serial.available() > 0 && i<RXBUFFSZ) { // Copy global serial buffer to local buffer.
if (__buffer[i]==0x0a || __buffer[i]==0x0d) break;
i++;
else {
i = 1;
while (SoftSerial->available() > 0 && i<RXBUFFSZ) { // Copy global serial buffer to local buffer.
i++;
__buffer[i] = 0x00;
log += tmpString;
if (argIndex) Vidx = tmpString.substring(argIndex + 2,argEnd);
boolean GotPipeCmd = false;
case 'u':
GotPipeCmd = true;
argIndex = argEnd;
if (argIndex) Nvalue = tmpString.substring(argIndex + 2,argEnd);
argIndex = argEnd;
if (argIndex) Svalue = tmpString.substring(argIndex + 2,argEnd);
case 's':
GotPipeCmd = true;
argIndex = argEnd;
if (Nvalue == F("On")) Svalue='1';
if (Nvalue == F("Off")) Svalue='0';
if (GotPipeCmd) {
sendData(event);
log = F("NEXTION075 : Pipe Command Sent: ");
log += __buffer;
else {
log = F("NEXTION075 : Unknown Pipe Command, skipped");
success = true;
return success;
void sendCommand(const char *cmd, boolean SerialHW)
if(SerialHW) {
Serial.print(cmd);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
else {
SoftSerial->print(cmd);
SoftSerial->write(0xff);
#endif // USES_P075
No problem. It is my baby tooThanks for doing the testing!
I use a slightly modified version of your suggested work around, but it seems that idx and value won't modify.
This is the log:
on E16NEXTION#idx do
if [E16NEXTION#idx]>=1274 // Touch Events
E16NEXTION#value = -1
E16NEXTION#idx = -1
1865069 : EVENT: E16Nextion#idx=1274.00
1865078 : [if 1274>=1274]=true
1865080 : ACT : SendToHTTP xxx.xxx.xxx.xxx,8080,/json.htm?type=command¶m=switchlight&idx=387&switchcmd=Toggle
1865097 : Command: sendtohttp
1865122 : HTTP/1.1 200 OK
1865140 : ACT : E16NEXTION#value = -1
1865154 : Command: e16nextion#value
1865155 : Command unknown
1865160 : ACT : E16NEXTION#idx = -1
1865173 : Command: e16nextion#idx
1865173 : Command unknown
1865195 : EVENT: E16Nextion#idx=1274.00 Processing time:126 milliSeconds
1865196 : EVENT: E16Nextion#value=0.00
1865223 : EVENT: E16Nextion#value=0.00 Processing time:27 milliSeconds
1865225 : LoadFromFile: config.dat index: 28672 datasize: 724
@BertB: Thanks for hanging in there! This morning I recompiled with the original release (before hard serial). It has the same interval behavior as the latest V3 beta.
To test your version what method are you using to review the ESP log? The web interface's log has never worked correctly for me, so I need to come up with an alternate method that avoids edits to my home automation system.
Your rule workaround's log looks like it should work because idx has been set to -1. I say that because it matches the log I see on mine.
After this there are no future log entries of the NEXTION since idx=-1 and the rule ignores it.
There's some interesting things going on here. In the meantime, do your best to continue with the validation so all the issues can be identified.
Lastly, if you are using the Arduino IDE, what compiler version is it? I would be good for me to know what others are using.
19844 : EVENT: NEXTION#idx=20.00
19878 : ACT : Publish /ESPEZ_Laundry/NEXTION/idx,20
19889 : Command: publish
19923 : ACT : NEXTION#idx = -1
19934 : Command: nextion#idx
19946 : Command unknown
19981 : EVENT: NEXTION#value=0.00
20096 : Command: |s
20097 : Command unknown
@BertB: Is the assigned name of your plugin NEXTION or is it E16NEXTION? The reason I ask is that there's a ESP bug that requires the user assigned name for this plugin to always be set to NEXTION or some things will not work correctly. So please change the Plugin name to "NEXTION" plus update the rule file to match this name.
Okay ... did not know that. I named it E16Nextion.ThomasB wrote: ↑15 Jul 2018, 19:53 @BertB: Is the assigned name of your plugin NEXTION or is it E16NEXTION? The reason I ask is that there's a ESP bug that requires the user assigned name for this plugin to always be set to NEXTION or some things will not work correctly. So please change the Plugin name to "NEXTION" plus update the rule file to match this name.
ThomasB wrote: ↑15 Jul 2018, 19:30
[/qoute]
I agree, the web log is not working correctly. Once the Serial.swap() has been executed, you are virtually blind for debug info.
On the other hand, the V3 version I tested, was with both softserial and hw serial.
There was no difference in 60 sec behaviour, but with softserial you have some proper debug info.
[qoute]
Your rule workaround's log looks like it should work because idx has been set to -1. I say that because it matches the log I see on mine.After this there are no future log entries of the NEXTION since idx=-1 and the rule ignores it.Code: Select all
19844 : EVENT: NEXTION#idx=20.00 19878 : ACT : Publish /ESPEZ_Laundry/NEXTION/idx,20 19889 : Command: publish 19923 : ACT : NEXTION#idx = -1 19934 : Command: nextion#idx 19946 : Command unknown 19981 : EVENT: NEXTION#value=0.00 20096 : Command: |s 20097 : Command unknown
[/qoute]
I only use the ids of Nextion objects. 60 sec thing was still hapening.
IDE 1.8.5 with 2.4.1Lastly, if you are using the Arduino IDE, what compiler version is it? I would be good for me to know what others are using.
I am running V3 again, changed E16Nextion to Nextion and no difference.
My garage light looks like a disco.
I just used platformio to compile and upload the lot.
No change, 60sec interval still there
Thanks for all the info. At this point I don't have a solution that would retain the interval timer, but skip sending idx and value data. That's because the main purpose of the interval function is to periodically send these values. Even if we reset them to something else, they will still be sent at each interval.
Your observation that your Nextion version doesn't do it is a mystery to me. When the dust settles, maybe you can dig in deeper to determine how your code skips sending the data at each interval period.
But in the meantime, here is a workaround. Just set the interval to 0 [sec] and it will turn off the interval timer. This will allow you to continue the testing without the garage disco dance.
//################################### Last Revision: July-15-2018 (TB) ###########################
#ifdef USES_P075
// Plug-In defines
#define PLUGIN_075
#define PLUGIN_NAME_075 "Display - Nextion [TEST_V3.1]"
// Nextion defines
// Serial defines
#define B9600 0
#define B38400 1
#define B57600 2
#define B115200 3
// Global vars
int rxPin = -1;
int txPin = -1;
switch (function) {
Device[deviceCount].TimerOptional = true; // Allow user to disable interval function.
String options[4];
if( Settings.TaskDeviceTimer[event->TaskIndex]==0) {
addFormNote(F("Interval Timer OFF: Nextion Lines and Values <b>NOT</b> scheduled for updates."));
else {
addFormNote(F("Interval Timer On: Nextion Lines and Values scheduled for updates."));
success = true;
String argName;
arg += varNr + 1;
success = true;
case PLUGIN_INIT: {
delete SoftSerial;
SoftSerial = NULL;
log += rxPin;
log += F(", TX:");
log += txPin;
HwSerial = true;
Serial.flush();
Serial.swap();
HwSerial = true;
Serial.flush();
else {
HwSerial = false;
else {
success = true;
int RssiIndex;
String newString;
String tmpString;
String UcTmpString;
int barVal;
barVal=0;
barVal=5;
barVal=10;
barVal=20;
barVal=30;
barVal=45;
barVal=60;
barVal=70;
barVal=80;
barVal=90;
barVal=100;
else {
success = true;
case PLUGIN_EXIT: {
if (SoftSerial) {
delete SoftSerial;
SoftSerial=NULL;
if(HwSerial) {
HwSerial = false;
Serial.flush();
success = true;
uint16_t i;
uint8_t c;
uint8_t charCount;
String log;
String Vidx;
String Nvalue;
String Svalue;
String Nswitch;
if (c == 0x65) {
__buffer[0] = c;
__buffer[i] = 0x00;
log += __buffer[1];
log += ",";
log += __buffer[2];
log += ",";
log += __buffer[3];
sendData(event);
else {
if (c == '|') {
__buffer[0] = c;
if(HwSerial) {
i = 1;
i++;
else {
i = 1;
i++;
__buffer[i] = 0x00;
log += tmpString;
case 'u':
GotPipeCmd = true;
argIndex = argEnd;
argIndex = argEnd;
case 's':
GotPipeCmd = true;
argIndex = argEnd;
if (GotPipeCmd) {
sendData(event);
log += __buffer;
else {
success = true;
return success;
if(SerialHW) {
Serial.print(cmd);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
else {
#endif // USES_P075
Thanks I will try it tomorrow.
What I do not understand is this:
When I push a button, this causes serial data to flow to the serial port. This causes an event, where idx and value are being filled.
When this event occurs it triggers a rule.
Once every 60 seconds, idx and value are read and (in my case) send to a dummy device in Domoticz.
Why does this lead to another serial event and trigger the rule?
@BertB: At each timer interval the two "Values" data (idx and value) will be sent again. Without new data from the Nextion they default to the previous values.
This is the same as any other device that has defined Values and use a interval timer. For example, a Switch device will send the switch state at each interval. Even if the switch state has not been altered, the previous data will be sent again at the interval. That is the purpose of the interval function.
In your example the originating idx was a 1274 touch event. After the initial send, it is resent at the interval time. It is then processed by the rule file, which activates your light again. The "-1" workaround could fix this (because the rule would be ignored when idx is -1), but for some reason that trick is not working for you.
The new code will allow you turn off the interval timer and avoid the 60 second repeat. If there are alternate methods then we can incorporate them too.
I installed a syslog server on my NAS and can now send ESP log files to it. This allowed me to see what your code is doing. It has the same interval behavior as the original Nextion release and the latest V3 code.
Using your code here's the log output of event idx 21 and value 0. This log was captured several minutes after the Nextion sent the idx code 21 to the ESP. In this example the Nextion interval is 10 sec so the repeated data appears often. I also removed the -1 masking trick from the rule file so that the MQTT publish is seen too.
I don't use Nextion Touch events because I prefer a different numerical code for On and Off commands. This, along with my home automation's On Change rule, eliminates any worries of repeated data.
There may be a way to suppress the idx and val from the interval timer (and retain the Lines function), but that will require some research.
18:39:33 EspEasy: EVENT: NEXTION#idx=21.00
18:39:33 EspEasy: WD : Uptime 22 ConnectFailures 0 FreeMem 14384
18:39:33 EspEasy: LoopStats: shortestLoop: 49 longestLoop: 2083484 avgLoopDuration: 89.40 systemTimerDuration: 19.35 systemTimerCalls: 31 loopCounterMax: 612244 loopCounterLast: 328986 countFindPluginId: 0
18:39:23 EspEasy: EVENT: RSSI#signal=-75.00
18:39:23 EspEasy: SYS : -75.00
18:39:23 EspEasy: EVENT: NEXTION#value=0.00
18:39:23 EspEasy: Command: publish
18:39:23 EspEasy: ACT : Publish /ESPEZ_Laundry/NEXTION/idx,21
18:39:23 EspEasy: EVENT: NEXTION#idx=21.00
18:39:13 EspEasy: EVENT: NEXTION#value=0.00
18:39:13 EspEasy: Command: publish
18:39:13 EspEasy: ACT : Publish /ESPEZ_Laundry/NEXTION/idx,21
18:39:13 EspEasy: EVENT: NEXTION#idx=21.00
18:39:03 EspEasy: EVENT: RSSI#signal=-76.00
18:39:03 EspEasy: SYS : -76.00
18:39:03 EspEasy: EVENT: RUNTIME#days=0.01
18:39:03 EspEasy: SYS : 21.00
18:39:03 EspEasy: EVENT: NEXTION#value=0.00
18:39:03 EspEasy: Command: publish
18:39:03 EspEasy: ACT : Publish /ESPEZ_Laundry/NEXTION/idx,21
18:39:03 EspEasy: EVENT: NEXTION#idx=21.00
18:39:03 EspEasy: WD : Uptime 21 ConnectFailures 0 FreeMem 14384
18:39:03 EspEasy: LoopStats: shortestLoop: 49 longestLoop: 2083484 avgLoopDuration: 88.74 systemTimerDuration: 20.94 systemTimerCalls: 31 loopCounterMax: 612244 loopCounterLast: 331381 countFindPluginId: 0
18:39:00 EspEasy: EVENT: Clock#Time=Sun,18:39
18:38:53 EspEasy: EVENT: NEXTION#value=0.00
18:38:53 EspEasy: Command: publish
18:38:53 EspEasy: ACT : Publish /ESPEZ_Laundry/NEXTION/idx,21
18:38:53 EspEasy: EVENT: NEXTION#idx=21.00
18:38:43 EspEasy: EVENT: RSSI#signal=-77.00
18:38:43 EspEasy: SYS : -77.00
18:38:43 EspEasy: EVENT: NEXTION#value=0.00
18:38:43 EspEasy: Command: publish
18:38:43 EspEasy: ACT : Publish /ESPEZ_Laundry/NEXTION/idx,21
18:38:43 EspEasy: EVENT: NEXTION#idx=21.00
18:38:33 EspEasy: EVENT: NEXTION#value=0.00
18:38:33 EspEasy: Command: publish
18:38:33 EspEasy: ACT : Publish /ESPEZ_Laundry/NEXTION/idx,21
18:38:33 EspEasy: EVENT: NEXTION#idx=21.00
18:38:33 EspEasy: WD : Uptime 21 ConnectFailures 0 FreeMem 14384
18:38:33 EspEasy: LoopStats: shortestLoop: 49 longestLoop: 2083484 avgLoopDuration: 89.47 systemTimerDuration: 19.65 systemTimerCalls: 31 loopCounterMax: 612244 loopCounterLast: 328733 countFindPluginId: 0
18:38:23 EspEasy: EVENT: RSSI#signal=-77.00
18:38:23 EspEasy: SYS : -77.00
18:38:23 EspEasy: EVENT: NEXTION#value=0.00
18:38:23 EspEasy: Command: publish
18:38:23 EspEasy: ACT : Publish /ESPEZ_Laundry/NEXTION/idx,21
18:38:23 EspEasy: EVENT: NEXTION#idx=21.00
That is exactly my point. Why would a timer interval invoke a rule that should be event driven by the switch. In my case, the timer sends the values to a domoticz waste bin.
So weird as on my wemos my latest code does not show the 60 sec on off behaviour. Tonite i will start from scrap..
I'm just the messenger, so don't shoot me. It's the behavior of the interval timer. It can be turned off now, so you should be good to go.That is exactly my point. Why would a timer interval invoke a rule that should be event driven by the switch. In my case, the timer sends the values to a domoticz waste bin.
So far, the plugin is running just fine.
@BertB: Thanks for checking it. Let me know if any other issues come up.
@Everyone: Would be great if there were others that could try it out. More feedback would be helpful.
I found a CustomTaskSettings byte storage mistake in the Nextion Plugin. But fixing it did not solve the crash/brick when the plugin is deleted and system rebooted. I see an Exception (28) in the logs right after the rule file tries to process a Nextion statement.
The workaround is to delete Nextion rules before deleting the plugin. If I don't do that then the recovery is to reflash with full memory reset. The problem comes and goes, depending on its mood.
The original Nextion plugin (without hardware serial) experiences the problem too. My gut feeling is that it has nothing to do with the Nextion Plugin.
I have a question about the Nextion display, maybe not the right place to ask but what version of the Nextion is most common for this plugin.
On the Itead site i see two versions, the Basic Model and the Enhanced Model.
I only have tested and developed with the Basic model.
I deployed most of my nextions so far working within the constraints of the plugin prior to H/W serial. I think H/W serial with a reliable serial message will allow me to cut down my rules (one nextion I have all 4 rules almost completely full!).ThomasB wrote: ↑17 Jul 2018, 02:19 @BertB: Thanks for checking it. Let me know if any other issues come up.
If I understand correctly I could have if/else/whatever statements on the nextion and the state of internal variables would determine what exactly gets sent to the ESP (on/off/whatever) vs button pressed and then I have to determine the state based on stored dummy values which eats up valuable rule characters.
Enhanced has more memory and faster CPU. Most likely not necessary for what most of us do here. The faster CPU means pages or images refresh faster ( I assume). The basic model refreshes the page plenty fast enough. It's noticeable, but no problem whatsoever. I only mean you can see it happen but it is not a problem.
More memory could be useful depending on how many images you use. I think with my 3.5" I have 5 pages ( and 2 images/page) and I was using 3MB so I got kind of close to filling one. I could reduce the quality probably and it wouldn't make any difference visually.
I see no real reason to get the enhanced version
I use the basic model.I have a question about the Nextion display, maybe not the right place to ask but what version of the Nextion is most common for this plugin.
That's how I do it. I don't use the Touch Event Send Component ID at all. Instead, in the button's Touch Event code space I use if/else and Nextion vars to assign a different idx value for button On and Off while emulating a push on-off toggling switch. Each touch button gets a pair of unique codes to do this. Some buttons have more codes to represent different variations of the button so that one button can do additional things.If I understand correctly I could have if/else/whatever statements on the nextion and the state of internal variables would determine what exactly gets sent to the ESP (on/off/whatever) vs button pressed and {snip}.
Below is example Nextion code to a simple touch button that is a push-on / push off switch. The Send Component ID checkbox remains unchecked. Instead, the customized Touch Press Event assigns two different idx values (20 & 21). Not shown are many other if/else actions, such as change picture graphics, text, and colors for the on/off states:
if(page0.va_SwState.val==0) // Switch is currently off
page0.va_SwState.val=1 // Toggle state (turn it on)
print "|s,i21,sOff" // Send idx to ESP MQTT rule
printh 0a
}else
page0.va_SwState.val=0 // Toggle state (turn it off)
print "|s,i20,sOff" // Send idx to ESP for MQTT rule
printh 0a
damn, too bad i had a bunch of boards made using some guy's design off of home assistant (HASP). the tx/rx are wired to d4/d7 (i think, i dont remember)ThomasB wrote: ↑17 Jul 2018, 19:03I use the basic model.I have a question about the Nextion display, maybe not the right place to ask but what version of the Nextion is most common for this plugin.
Below is example Nextion code to a simple touch button that is a push-on / push off switch. The Send Component ID checkbox remains unchecked. Instead, the customized Touch Press Event assigns two different idx values (20 & 21). Not shown are many other if/else actions, such as change picture graphics, text, and colors for the on/off states:This method simplifies ESP and home automation rules by pushing some low level work onto the Nextion.Code: Select all
if(page0.va_SwState.val==0) // Switch is currently off { page0.va_SwState.val=1 // Toggle state (turn it on) print "|s,i21,sOff" // Send idx to ESP MQTT rule printh 0a }else { page0.va_SwState.val=0 // Toggle state (turn it off) print "|s,i20,sOff" // Send idx to ESP for MQTT rule printh 0a }
https://github.com/aderusha/HASwitchPla ... master/PCB
I designed this communication to put more of the thinking in the Nextion, but it also more or less causes more often changes in the Nextion.
This is not very user friendly while there is no easy way to update Nextion.
Therefore I mostly use the id's and let Rules and Domoticz do the thinking.
The drawback here is the shortage of rules space, but the gain is simplicity, agility and beter feedback.
Thank for the info about the Nextion display.
@BertB: I have been working on the interval issue. There is a chance that this new beta release is what you want:
Please check it. Be sure to turn the Interval timer back on and recreate your previous conditions. If the magic code is working your garage light shouldn't do the disco dance anymore.
//################################### Last Revision: July-18-2018 (TB) ###########################
#ifdef USES_P075
// Plug-In defines
#define PLUGIN_075
#define PLUGIN_NAME_075 "Display - Nextion [TEST_V3.2]"
// Configuration Settings. Custom Configuration Memory must be less than 512 Bytes!
//#define Nlines 12 // Qty of "optional" user entered Command-Text strings.
//#define Lenlines 64 // Length of "optional" user entered Command-Text strings.
#define Nlines 8 // Qty of "optional" user entered Command-Text strings.
#define Lenlines 48 // Length of "optional" user entered Command-Text strings.
char deviceTemplate[Nlines][Lenlines];
// Nextion defines
#define TOUCH_BASE 500 // Base offset for 0X65 Touch Event Component ID.
// Serial defines
#define B9600 0
#define B38400 1
#define B57600 2
#define B115200 3
// Global vars
int rxPin = -1;
int txPin = -1;
switch (function) {
String options[4];
addFormTextBox(String(F("Line ")) + (varNr + 1), String(F("Plugin_075_template")) + (varNr + 1), deviceTemplate[varNr], Lenlines-1);
addFormNote(F("Interval Timer OFF: Nextion Lines (above) <b>NOT</b> scheduled for updates."));
else {
addFormNote(F("Interval Timer On: Nextion Lines (above) scheduled for updates."));
success = true;
String argName;
arg += varNr + 1;
deviceTemplate[varNr][Lenlines-1]=0;
success = true;
case PLUGIN_INIT: {
Settings.TaskDevicePluginConfig[event->TaskIndex][2] = -999; // Reset Last known idx.
Settings.TaskDevicePluginConfig[event->TaskIndex][3] = -999; // Reset Last known value.
delete SoftSerial;
SoftSerial = NULL;
log += rxPin;
log += F(", TX:");
log += txPin;
HwSerial = true;
Serial.flush();
Serial.swap();
HwSerial = true;
Serial.flush();
else {
HwSerial = false;
else {
success = true;
int RssiIndex;
String newString;
String tmpString;
String UcTmpString;
int barVal;
barVal=0;
barVal=5;
barVal=10;
barVal=20;
barVal=30;
barVal=45;
barVal=60;
barVal=70;
barVal=80;
barVal=90;
barVal=100;
else {
success = true;
// At Interval timer, send idx & value data only if either changed. This eliminates repeating the data.
if ((Settings.TaskDevicePluginConfig[event->TaskIndex][2] != UserVar[event->BaseVarIndex]) ||
(Settings.TaskDevicePluginConfig[event->TaskIndex][3] != UserVar[event->BaseVarIndex+1])) {
Settings.TaskDevicePluginConfig[event->TaskIndex][2] = UserVar[event->BaseVarIndex]; // Save new idx.
Settings.TaskDevicePluginConfig[event->TaskIndex][3] = UserVar[event->BaseVarIndex+1]; // Save new value.
success = true;
else {
success = false;
case PLUGIN_EXIT: {
if (SoftSerial) {
delete SoftSerial;
SoftSerial=NULL;
if(HwSerial) {
HwSerial = false;
Serial.flush();
success = true;
uint16_t i;
uint8_t c;
uint8_t charCount;
String log;
String Vidx;
String Nvalue;
String Svalue;
String Nswitch;
if (c == 0x65) {
__buffer[0] = c;
__buffer[i] = 0x00;
log += __buffer[1];
log += ",";
log += __buffer[2];
log += ",";
log += __buffer[3];
sendData(event);
else {
if (c == '|') {
__buffer[0] = c;
if(HwSerial) {
i = 1;
i++;
else {
i = 1;
i++;
__buffer[i] = 0x00;
log += tmpString;
case 'u':
GotPipeCmd = true;
argIndex = argEnd;
argIndex = argEnd;
case 's':
GotPipeCmd = true;
argIndex = argEnd;
if (GotPipeCmd) {
sendData(event);
log += __buffer;
else {
success = true;
return success;
if(SerialHW) {
Serial.print(cmd);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
else {
#endif // USES_P075
same here which is why i asked early on if the Nextion could be updated remotely. As this isn't possible I wanted to rely more on the ESP. It turns out not to be a huge problem..make the panel design once, and something you can live with and the rest you manipulate with espeasy and openhab(domo/whatever) but I do run out of rules, almost! something like 2000/2048 on all 4 pages! glad i didn't need more buttonsBertB wrote: ↑18 Jul 2018, 08:51 I designed this communication to put more of the thinking in the Nextion, but it also more or less causes more often changes in the Nextion.
@ThomasB
I will test it this weekend.
@Thomas,
You have limited the number of lines and the max number of characters. I guess it is to limit the memory usage, but iyt gave me a lot of trouble as I had to delete the plugin and activated it all over again. No big deal, but it was a bit confusing.
Then, because of the lack of info on the WEB LOG tool, I used the Softserial option with the normal serial port for debug info.
It gave me this, but for some reason, nothing happens in the domoticz anymore. (I am going to test that later with an older version of ESPEasy).
This is the output:
Edit
When I enter this in a internet page, I get to expected result:
This is the output:
1480325 : NEXTION075 : code: ,,
1480328 : EVENT: Nextion#idx=2039.00
1480346 : ACT : SendToHTTP xxx.xxx.xxx.xxx,8080,/json.htm?type=command¶m=switchlight&idx=293&switchcmd=Toggle
1480363 : Command: sendtohttp
1480369 : GET HTTP/1.1
Host: xxx.xxx.xxx.xxx
Connection: close
1481385 : Timeout while reading input data!
1481418 : EVENT: Nextion#idx=2039.00 Processing time:1090 milliSeconds
1481419 : EVENT: Nextion#value=0.00
1481461 : EVENT: Nextion#value=0.00 Processing time:42 milliSeconds
1481474 : HTTP : connecting to xxx.xxx.xxx.xxx:8080
1481483 : Domoticz: Sensortype: 5 idx: 310 values: 2039;0
1481511 : HTTP : Success
1481516 : HTTP : closing connection
Ok
1494318 : NEXTION075 : code: ,,
1494320 : EVENT: Nextion#idx=2039.00
1494338 : ACT : SendToHTTP xxx.xxx.xxx.xxx,8080,/json.htm?type=command¶m=switchlight&idx=293&switchcmd=Toggle
1494357 : Command: sendtohttp
1494394 : GET HTTP/1.1
Connection: close
1495409 : Timeout while reading input data!
1495441 : EVENT: Nextion#idx=2039.00 Processing time:1121 milliSeconds
1495442 : EVENT: Nextion#value=0.00
1495485 : EVENT: Nextion#value=0.00 Processing time:42 milliSeconds
1495499 : HTTP : connecting to xxx.xxx.xxx.xxx:8080
1495510 : Domoticz: Sensortype: 5 idx: 310 values: 2039;0
1495530 : HTTP : Success
1495535 : HTTP : closing connection
>settings
1499880 : Command: settings
http://xxx.xxx.xxx.xxx:8080/json.htm?type=command¶m=switchlight&idx=293&switchcmd=Toggle
Something seems to be not ok with the latest release Release mega-20180722, as it does not do the switching in Domoticz.
Release Release mega-20180719 seems to work.
Do you use rules for intercepting the command? What if the exact command you use? We have a little parsing error that is going to be fixed here in some days.
This is the rule:grovkillen wrote: ↑22 Jul 2018, 16:34 Do you use rules for intercepting the command? What if the exact command you use? We have a little parsing error that is going to be fixed here in some days.
on Nextion#idx=2039 do
The original Nextion plugin was violating the SPIFFS memory allowance. According to the Developer's Guide, only 512 bytes are allowed for custom config, so I reduced the optional Lines count and their length (was 12 lines x 64 chars, now 8 x 48). There's some extra bytes that would allow two more lines. Or it can be used to increase the length of the 8 lines to 62 chars. Which do think would have the widest appeal?You have limited the number of lines and the max number of characters. I guess it is to limit the memory usage ...
That's a relief the latest Nextion plugin works in the 0719 release.Something seems to be not ok with the latest release Release mega-20180722, as it does not do the switching in Domoticz.
But despite that you got the latest Nextion plugin to work, I just realized my interval "fix" might not work correctly for everyone. So some questions for you.
1. I understand that you are using the Nextion "Send Component ID" on the Touch Press Event. Is the Touch Press Release Event also being used with the Press Event?
2. Does the Nextion button continue to work correctly after the first press? Or does it only work the first time you press it?
I think more lines, but per haps it is not necessary to use that much ccharacters. 32 was just too few. Maybe 40 is ok.
No, I only use the Tough Release Event.But despite that you got the latest Nextion plugin to work, I just realized my interval "fix" might not work correctly for everyone. So some questions for you.
Yes it does continue to work just fine.2. Does the Nextion button continue to work correctly after the first press? Or does it only work the first time you press it?
Ok, a couple more Lines it is. Keep in mind that Lines statements can consume a lot of characters. For example, this useful Nextion text update would require a line length of 50 bytes.I think more lines, but per haps it is not necessary to use that much characters. 32 was just too few. Maybe 40 is ok.
page7.t1.txt="Date %sysmonth%:%sysday%:%sysyears%"
Thanks for the additional info. It confirms that the latest release is working as intended. But for more user flexibility I will add another checkbox that allows the user to restore the default interval behavior.Yes it does continue to work just fine.
There are two open issues on the plugin that are being reviewed by the ESPeasy developers. As follows:
1. The user assigned Plugin name must be NEXTION. If it is named anything else some functionality is lost.
2. The Plugin sometimes will crash/brick the firmware if you have any NEXTION rules in the ESP rules file when you delete the plugin. Bricking requires erasing the flash memory and re-installing ESPeasy.
Unbelievably, these two issues are related. Software can be so cruel!
I'll post the final (hopefully it's final) version this week. If all goes well it will be the one to add to the official TESTING distribution.
BTW, I believe I'm the first to fully incorporate the new hard serial Nextion plugin in a finished project. And it has been working great. It's a little gadget that is integrated with Amazon Echo that provides a voice notification when the laundry is done. I'll post some build photos and more details soon.
. - Thomas
very nice indeed.
I have two work in progress projects.
One is a thermostat to be placed in the various rooms in my house.
The other one is a general purpose control panel.
I am now testing the pont control.
Nice projects guys.
Here are my 2 3.5" models. I have a few 2.4s in bedrooms for light/temp/vent control.
In out main living room there are 4 (yeah, 4) small ceiling fan/lights. Previously, a single 3-way (2-way?) switch turned them on and off and you had to use pull chains at each fan to make adjustments. Now there's an on/off for all lights and fans as well as a screen where individual lights/fans can be turned on and off. Garage doors can be actuated, stair light, tart warmer, neato schedule etc... This one is by the front door. It controls some lights and gives some basic info before heading out. Temps, UV Index, and burn times.
Really love these project pictures. Inspiring!
Cool projects! More photos of working Nextion projects will help spread the Nextion plugin love. So keep the photos coming!
Currently the Nextion wiki (https://www.letscontrolit.com/wiki/index.php/Plugin75) is an empty page. I'd volunteer to add some information to it if I was granted write/edit privileges.
Some project details to share to help inspire other Nextion/ESPeasy projects:
My recently completed Nextion project is a simple application that provides Amazon Echo voice notifications when the laundry is ready. The device slips onto the dryer's control panel and is held in place by a hidden magnet. Power is provided by a orphan USB charger supply.
Overview:
A single ESP8266 monitors the washer and dryer, which are ten year old GE machines. ESPeasy's Nextion plugin communicates the touch screen entries to the home automation controller (Openhabian) using MQTT. In turn, the home automation system can interact with the ESP8266/Nextion using HTTP messages. All touch screen commands have equivalent Echo voice commands (touch and voice commands duplicate each other).
Hardware:
The ESP8266 is the Lolin NodeMCU v3. It's my go-to board for ESPeasy projects. Cost is less than $5 USD from China suppliers. The display is a $20 Nextion 2.8-inch, #NX3224T028.
Here's an overview of all the pieces, including the 3D printed plastic parts:
The ESP8266 needs to know when the washer or dryer are running and when they turn off. My goal was to avoid any electrical connections to them. This was possible on the dryer using a $2USD MPU6050 accelerometer that senses vibration from the spinning drum. Sensitivity is amazing, it can detect ANY size laundry load. The ESP8266 has a MPU6050 plugin that makes this possible with minimal effort.
But the washer required invasive electrical surgery. My machine doesn't have indicator lights and sensing vibration won't work because of the motionless soak cycles. Monitoring machine current was considered, but current draw is nearly zero during some operating states so current loop solutions weren't practical.
The chosen solution was a $2USD high voltage optoisolator board designed for 220VAC. Fortunately it works fine on the washer's 120VAC mains without any modifications. The board safely isolates the washing machine's high voltage and provides TTL compatible On/Off status to the ESP8266. For moisture protection all PCB circuitry was coated in epoxy and protected with shrink wrap.
The plastic parts were created in 123D Design and 3D printed in white ABS plastic. All visible surfaces were sanded, acetone polished, then spray painted with Appliance White epoxy paint.
Basic Operation:
The home automation system (Openhabian) provides the interface to the Amazon Echo voice functions and monitors the machines with two large Rules files. Besides giving vocal announcements when the washer or dryer are done, it also provides loss-of-communication warnings and reports user mistakes (like forgetting to turn on the machine). Some simple animations are shown on the display to indicate the operating mode.
Below is a video of the washer and dryer running. At the 13 second mark the washer ends it cleaning cycle (graphic changes color). Not heard on the video is the "The washing machine is done, your laundry is ready" message broadcast by our Amazon Echo speakers.
https://youtu.be/gVsYJ0QBaxY
Overview:
Hardware:
Basic Operation:
Users browsing this forum: No registered users and 116 guests
