SI1145 - UV index / IR / visible
Please check the enclosed plugin for I2C type SI1145 UV sensor - tested and working.
Adafruit SI1145 library included directly in INO file:
http://www.qadra.sk/downloads/_P110_SI1145.ino
Just download and save the file into your ESPEASY Arduino sketch directory ..
Re: SI1145 - UV index / IR / visible
PM sent. If all goes well, expect to see this in the plugin playground.
Any new official binary compiled yet for it like (ESPEasy_R120_1024.bin)?milan.gsm wrote: Please check the enclosed plugin for I2C type SI1145 UV sensor - tested and working.
Is this sensor supported by Domoticz?
Thank you for your answer!
What is present status for the shift of a SI1145-plugin to a Release?
Any updates for the SI1145 plugin ? It's still in playground.
Can anybody tell me how stable it is ? I recently bought a SI1145 sensor and connected it to an NodeMCU 12E with 3 other I2C devices connected, an BH1750 at 0x23, and BME280 at 0x76 and an LCD1602 at 0x27, the SI1145 is at 0x60 (hardcoded in the plugin).
I sometimes get values but after a while I don't find any I2C devices anymore (with tools/i2c scan), as soon as I remove the SI1145 I see the 3 other I2C devices again.
So now my problem is, is the SI1145 defect ? or is the software not correctly working.
I ordered anothert SI1145 but that can take a while to get here
Any chance to see SI1145 included in a next revision of the firmware, instead of ino-file?
Probably looking at wrong place:
where is description how to merge an ino-file into the ESPEasy-firmware?
That's a good question. The existing manual does not work properly. I want to take over from the Playground so about 4 modules.
Unfortunately, I do not know how, because it always comes with errors when compiling, through the modules from the playground.
Has anyone an idea or a guide?
Thank you
Thank you
Now I have managed, that went through the compilation with the p113 module flawlessly.
After putting the sensor into operation, I realized that something was wrong.
The Si1145 is a light sensor. When it's dark, it still displays values in excess of 200, also in the IR range.
Does anyone have an idea what's wrong in the module?
I have also taken a 2nd sensor and to rule out an error with 1st sensor. This has sent the same values!
Can someone please help me, so that synonymous with darkness values are displayed by 0 ?????
Greetings and thanks
Sascha
The used plugin ist attached !
Sascha
- _P113_SI1145.zip
- (3 KiB) Downloaded 339 times
Users browsing this forum: No registered users and 119 guests
