RF 433 plugin for KAKU in the playground
Re: RF 433 plugin for KAKU in the playground
Can't compile... Always getting errors...
Does anybody could upload the compiled image and share the download link?
I'm using 4M ESP modules.
Here's an image I am using on a 4M Wemos mini D1 with Kaku and some other 433MHz related plugins. The analog input configured to measure supply voltage.
download at http://tinydevices.de/esp-easy-firmware/
Added Plugins:
109 NEXA
111 RF
112 RFTX
122 Neopixel
199 433MHz Kaku
Added Plugins:
109 NEXA
111 RF
112 RFTX
122 Neopixel
199 433MHz Kaku
It would be great if you could upload the source code please. Thanksdata wrote:Here's an image I am using on a 4M Wemos mini D1 with Kaku and some other 433MHz related plugins. The analog input configured to measure supply voltage.
Added Plugins:
109 NEXA
111 RF
112 RFTX
122 Neopixel
199 433MHz Kaku
Thank you.
I bought REV Ritter Outlet Sockets from Bauhaus also available at amazon:
I successfully integrated the kaku plugin from the playground with Arduino IDE (2.0.0 dev11 version).
The chipset is TE90TP16N (self-learing).
I also sniffed the code from the remote control with Arduino Serial Monitor via NewRemoteSwitch library (downloaded from here:
From this Forum:
Serial monitor showed:
Addr 17594190 unit 15 on, period:255us
How can I Transmit this Code via ESPEasy?
I tried the following Rule:
on demoEvent do
newKakuSend,17594190,15,16
I Also tried Rule:
on demoEvent do
newKakuSend,17594190,15,0 //also newKakuSend,17594190,15,1 etc.
I executed the Rule with the command "http://<ESP#1-ip >/control?cmd=event,demoEvent".
ESPEasy told me the command was transmitted, but the outlet socket did not switched on. What is wrong?
I am using this kit:
https://www.amazon.de/gp/product/B0017USSM4/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=A3JWKAKR8XB7XF
http://fhilgendorf.square7.ch/Rever/
https://www.arduinoforum.de/arduino-Thread-Ritter-Funksteckdose-433mhz?page=2
on demoEvent do
I Also tried Rule:
on demoEvent do
http://www.ebay.de/itm/RF-Sender-Empfanger-Modul-433MHz-Wireless-Link-Kit-fur-Arduino-/332339792823?hash=item4d60fecbb7:g:ZjEAAOSwz2tZjYEA
I want testing this RF plugin,but compilation end with error.
_P111_RF.ino: In function 'boolean Plugin_111(byte, EventStruct*, String&)':
_P111_RF:61: error: 'irReceiver' was not declared in this scope
if (irReceiver != 0) {
_P111_RF:88: error: 'irReceiver' was not declared in this scope
if (irReceiver != 0) break;
lock at this one viewtopic.php?p=20598#p20598
I had the same problem. After deleting some standard plugins and do exactly what is mentioned in the tutorial for compliling ESPeasy with Arduino IDE everything works for me.
I compiled KAKU Plugin and the other RF send / receive Plugins together.
Great Plugin. Now I can switch every self-learning rf 433 mhz socket.
Just a hint: If you want to use MQTT to switch rf sockets, use rules in combination with MQTT import plugin. Its absolutely excellent because you can subscribe to a topic and switch everything from openhab or fhem or HAAS or whatelse.
I've tried to compile the plugin for a wemo, but without success. I removed all standard plugins (_P...) and placed the three RF plugins in the folder. I used the following configuration:
arduino-1.6.12P230
espeasy mega-20180314, and earlier versions (2.0.0-dev11)
After I compile the famous error 1 appears....
any idea's???
Mark
arduino-1.6.12P230
any idea's???
Mark
Nobody any idea or suggestions?
Hello, the link does not work. I would like to try this image.data wrote: ↑04 Feb 2017, 08:48 Here's an image I am using on a 4M Wemos mini D1 with Kaku and some other 433MHz related plugins. The analog input configured to measure supply voltage.
Added Plugins:
109 NEXA
111 RF
112 RFTX
122 Neopixel
199 433MHz Kaku
Oh, sorry, I moved the folder last year. Try this one:
http://tinydevices.de/ESP-Easy/ESPEasy.ino.generic.bin
have someone this RF Plugin and the latest ESPEasy relase.
and can giv it to me.
I dont bring it together
Regards Makro
Regards Makro
Users browsing this forum: No registered users and 123 guests
