Stepper Motor
Re: Stepper Motor
Well if you want to discuss hardware / software...
https://circuitdigest.com/electronic-ci ... or-circuit
Why not then add a external PWM and only controll Direction/Enable with the ESP12?
555 timer is like $0,5
Re: Stepper Motor
Strange answer ..
With a small electronic modification and an intelligent A4988 driver you can use the software you asked me for (without overloading the ESP).
As TD-er commented here: https://github.com/letscontrolit/ESPEas ... -373406715
Re: Stepper Motor
Also know a bit of the electronics and why things are limited somehow.
The thing is, a stepper motor is driven by current, not by voltage. This may sound a bit strange, but let me explain.
If you disable the current through the stepper motor coil, it will produce some voltage, which is opposite to the voltage applied previously.
For slow stepping, this doesn't matter.
But for faster steps, this will decrease the current through the coil and thus the strength of the magnetic field of the coil.
Above some step frequency it is no longer to keep up and you will loose steps, stall or even make some reverse steps.
This depends on the load of the stepper, the voltage applied and some other factors.
Some more sophisticated stepper motor drivers support a sense resistor to measure the current through the coil and limit the current (to prevent heating up the motor).
This allows to use a much higher voltage and thus higher step frequencies.
The A4988 is such a more sophisticated stepper motor driver, used often in 3D printers.
If you're running at the same step frequency always and also disable the current through the stepper when not moving, you could use a (much) higher voltage, even when using a very simple stepper motor driver like the 2003. (make sure you don't exceed the max current and voltage of the driver)
Just watch the temperature closely when determine the desired stepper speed and do these tests with the actual load of the stepper motor.
You could also make a power supply for the stepper which limits the current automatically to something like 100 mA. I think that's the safest way.
Re: Stepper Motor
@Domosapiens
Thanks, I have already seen the modification for the motor in another forum. I may go in this direction, but they also pointed out that you loose torque. I am afraid that the motor will not manage to drive a roller-blind.
What's your experience of this modification? I have the 12v versions.
Re: Stepper Motor
I never used it without modification, so I don't know the difference.
It fulfilled my requirement of 7N but too slow for my 4 meter curtain (iirc 1.5 minutes).
This one is my selection:
https://www.ebay.com/itm/1PCS-Used-27mm ... 282f328fa0
Has metal gears instead of plastic.
And works with Stepper-Driver-A4988 https://nl.aliexpress.com/item/5pcs-lot ... 62c6uYD24x
Re: Stepper Motor
Guys,
hope you can help me.
I have setup a Wemos D1 mini + DRV8825 + Nema 17 (17HD40005-22 b).
Wires are connected as shown in post #7:
ENABLE -> D5
Step -> D6
Dir -> D7
12VDC / 6A Power supply:
+ -> VMOT
- -> GND
100 µF cap between + and -
RESET + SLEEP are connected to 3,3V from ESP
I have successfully compiled the ESPEasy firmware (ESPEasy_mega-20180302) incl. the plugin from Domosapiens and also tested a second version of the firmware with the original P106 plugin. Both ESPEasy versions have the same behavior after configuring the Plugin in the Web-IF of ESPEasy.
Vref of the motor driver before has been configured to 600mV.
Unfortunately I do not have any experience with stepper motors so I start to ask myself, what values I have to define for my stepper in the plugin sources.
I've tested a lot with values like:
max_stepper_speed = 32000;
stepper_accel = 16000;
steps = 800;
According to the spec my stepper runs max 8000 pps (pulse per sec) and 200 pulses/rev.
The problem is, it starts to move but only very slow and it's more like stuttering it's way forward. I'm not able to change the speed with parameters set_accel, steps, speed.
http://esp09.fritz.box/control?cmd=speed,2000
http://esp09.fritz.box/control?cmd=left
I played already with Vref but the situation stays the same. Next I've used a very simple stepper code with an Arduino UNO only connected 5V, GND, Pins 8 and 9 and voila it turns as expected with a decent speed.
Arduino code:
Why it is that slow if I use the ESP and how do I have to properly configure the parameters in the plugin sources. At the moment I'm a bit lost, would be great if someone can help me to sort that out.
Thanks in advance, Sven
ENABLE -> D5
Step -> D6
Dir -> D7
+ -> VMOT
- -> GND
steps = 800;
Arduino code:
/* stepper motor control code for DRV8825
// define pin used
const int stepPin = 9;
const int dirPin = 8;
void setup() {
// set the two pins as outputs
pinMode(stepPin,OUTPUT);
pinMode(dirPin,OUTPUT);
void loop() {
digitalWrite(dirPin,HIGH); //Enables the motor to move in a perticular direction
// for one full rotation required 200 pulses
for(int x = 0; x < 200; x++){
digitalWrite(stepPin,HIGH);
delayMicroseconds(500);
digitalWrite(stepPin,LOW);
delay(1000); // delay for one second
digitalWrite(dirPin,HIGH); //Enables the motor to move in a opposite direction
// for three full rotation required 600 pulses
for(int x = 0; x < 600; x++){
Re: Stepper Motor
Hi there!
@Domosapiens, did you use the default settings (for the AccellStepper library) or some specific ones for the 28BYJ
And if I may, which values you used for the 2phase - 6wires? (https://www.ebay.com/itm/1PCS-Used-27mm ... 282f328fa0)
It's a bit tricky to find the right balance and get the most of these little motors.
I am trying to move 2m long Ikea roller blinds.
Thanks and great work on the libraries!
Re: Stepper Motor
My project is still dormant ..
What I remember
Use
A+ and A-
B+ and B-
Other wires not connected.
I just fiddled with the parameters, nothing special.
What I remember
Use
A+ and A-
B+ and B-
Re: Stepper Motor
Hey,
i am using the code from the fist page of this thread. Compiling and uploading OK.
When i try to add the motor plugin i get this error:
Is that something i can ignore? Doesn't look like it. Am i the only one with this error?
Would be thankful for an advice.
Thank you
ED
Thank you
ED
Re: Stepper Motor
Is there anybody using it with actual mega firmware?
there is less about stepper motors in the forum nobody usig it?
Re: Stepper Motor
W.r.t. viewtopic.php?f=6&t=2356#p25884
Hope this link is persistent
https://drive.google.com/open?id=1Xylw5 ... ezs7vBohyg
Re: Stepper Motor
Thank you!
I will test it
I will test it
Re: Stepper Motor
Does anyone have this working?
I've got a TB6612 stepper motor controller but I can't get this plugin to work?
I could do with a wire diagram and an example.
Re: Stepper Motor
I have been using nodeMCU for a couple of weeks now and I am able to control Leds using switches and potentiometer.
I am trying to control a stepper motor with the nodeMCU (with esp8266) and openhab. Can someone help me with this?
Could someone please provide the custom plugin? The 7 day duration has obviously expired, @Domosapiens
At a beginner level, can someone please explain how exactly to add a custom plugin to the firmware?
Any help and suggestions would be highly appreciated. Thank you!
Re: Stepper Motor
I'm struggling to compile ESPEasy_v2.0.0-dev7_Cstep_Ostep_firmware from around 2017 into latest ESPEasy releases. Full of errors when trying to build.
@Domosapiens please can you give us some pointers on how to successfully build on latest releases. What needs to change in the P107/P108 and ESPEasy.ino files? What else needs changing?
Your help is much appreciated.
Re: Stepper Motor
Why are you trying to build a firmware of 5 years ago?
What do you need, that isn't present in the current builds?
Please share a link to the plugins you need to build.
Users browsing this forum: No registered users and 114 guests
