Same Problem here...
Stepper Motor
Re: Stepper Motor
W.r.t. viewtopic.php?f=6&t=2356#p25884
Hope this link is persistent
https://drive.google.com/open?id=1Xylw5 ... ezs7vBohyg
Re: Stepper Motor
Thank you!
I will test it
I will test it
Re: Stepper Motor
Does anyone have this working?
I've got a TB6612 stepper motor controller but I can't get this plugin to work?
I could do with a wire diagram and an example.
Re: Stepper Motor
I have been using nodeMCU for a couple of weeks now and I am able to control Leds using switches and potentiometer.
I am trying to control a stepper motor with the nodeMCU (with esp8266) and openhab. Can someone help me with this?
Could someone please provide the custom plugin? The 7 day duration has obviously expired, @Domosapiens
At a beginner level, can someone please explain how exactly to add a custom plugin to the firmware?
Any help and suggestions would be highly appreciated. Thank you!
Re: Stepper Motor
I'm struggling to compile ESPEasy_v2.0.0-dev7_Cstep_Ostep_firmware from around 2017 into latest ESPEasy releases. Full of errors when trying to build.
@Domosapiens please can you give us some pointers on how to successfully build on latest releases. What needs to change in the P107/P108 and ESPEasy.ino files? What else needs changing?
Your help is much appreciated.
Re: Stepper Motor
Why are you trying to build a firmware of 5 years ago?
What do you need, that isn't present in the current builds?
Please share a link to the plugins you need to build.
Users browsing this forum: No registered users and 122 guests
