RGBWW Plugin development questions
Re: RGBWW Plugin development questions
dev0, sorry to bother you but i would love to get your plugin working. I tried to compile 147_RC8 8, but with you plugin loaded i can´t get it to work.
In
ESPEasy.ino sketch i changed #define FLASH_EEPROM_SIZE from 4096 to 512
Arduino Settings:
Board: Generic ESP8266 Module
Flash Mode: DIO
Flash Frequency: 40MHZ
CPU Frequency: 80 MHZ
Flash Size: 512 (64K SPIFFS)
Debug port: Disabled
Debug Level: none
Reset Method: ck
Upload Speed: 115200
Port: COM5
Please give us a hint how to setup the board with your plugin. A precompiled image would also help.
Having said this i like to mention that i love your idea to develop a plugin for h801 mqtt rgb control and it would be a pleasure to me to give you a feedback how it works.
Sorry for hijacking your thread
In
Arduino Settings:
Flash Mode: DIO
Debug Level: none
Reset Method: ck
Port: COM5
This is not needed. You have to set Flash Size tp 512k/64k in Arduino IDE only. Copy the plugin, remove 2-3 unused Plugins, compile.sledge wrote: ESPEasy.ino sketch i changed #define FLASH_EEPROM_SIZE from 4096 to 512
If there is a compiler error telling you that there is not enough space then remove another plugin. That's all.
Keep in mind that the plugin is not more then a proof of concept at the moment. A setup with only cw/ww stripes will work fine, but all other setups will not show an usable white for example. There is no color correction at all.
Hello Dev0, that is not correct. The H801 has the same flash chip as the ESP-01, Flash Chip ID: 1327328dev0 wrote:512k/64k for the H801
So you can use 1M (64K SPIFFS) for the H801.
I did it with my H801 and it going perfect.
I don't think you can know which flash chip is used on my hardware. May be there are other versions.ManS-H wrote:that is not correct.dev0 wrote:512k/64k for the H801
You are not able to flash or you don't get it working? I can flash but the RGB commands show no effect on a simple RGB stripe (R,G,B, VCC)sledge wrote:dev0, sorry to bother you but i would love to get your plugin working. I tried to compile 147_RC8 8, but with you plugin loaded i can´t get it to work:
Thx Dev0 it worked for me. Now we talk
To keep your thread clean i started a new one with a little documentation how to get your plugin running. viewtopic.php?f=2&t=2582
Is it possible to send MQTT messages to control the RGB functionality? I so, may I have an example of how to set this up (topic and payload syntax).
MQTT should be possible, as with all other plugins.
Is this plugin perhaps working??
Like to have a rgbw controller based on Espeasy..
Or are there @this time other espeasy rgbw controllers that are working with domoticz?
Users browsing this forum: Bing [Bot], Google [Bot] and 139 guests
