From bd1d99e3cf9553fe189b9f290f2af1ba616a4b40 Mon Sep 17 00:00:00 2001
Date: Mon, 2 Jan 2017 14:10:07 +0100
Subject: [PATCH] Add "toggle" command to P001_Switch plugin
_P001_Switch.ino | 25 +++++++++++++++++++++++++
1 file changed, 25 insertions(+)
diff --git a/_P001_Switch.ino b/_P001_Switch.ino
index e465ea8..db8ab1d 100644
--- a/_P001_Switch.ino
+++ b/_P001_Switch.ino
@@ -226,6 +226,31 @@ boolean Plugin_001(byte function, struct EventStruct *event, String& string)
+ if (command == F("toggle"))
+ success = true;
+ if (event->Par1 >= 0 && event->Par1 <= 16)
+ // identify Pinmode
+ uint32_t bit = digitalPinToBitMask(event->Par1);
+ uint8_t port = digitalPinToPort(event->Par1);
+ volatile uint32_t *reg = portModeRegister(port);
+ if (*reg & bit) {
+ // Pin is OUTPUT - Toggle
+ digitalWrite(event->Par1, !digitalRead(event->Par1));
+ } else {
+ // Pin is !OUTPUT - set to OUTPUT and enable
+ pinMode(event->Par1, OUTPUT);
+ digitalWrite(event->Par1, 1);
+ setPinState(PLUGIN_ID_001, event->Par1, PIN_MODE_OUTPUT, digitalRead(event->Par1));
+ log = String(F("SW : GPIO ")) + String(event->Par1) + String(F(" toggle to ")) + String(digitalRead(event->Par1));
+ addLog(LOG_LEVEL_INFO, log);
+ SendStatus(event->Source, getPinStateJSON(SEARCH_PIN_STATE, PLUGIN_ID_001, event->Par1, log, 0));
if (command == F("pwm"))
success = true;
