Plugin Development
Re: Plugin Development
Hi JustmeNL
Thank you for the pointer.
I shall have to see how i can get OOK to work on the RFM69 as i have one of these - [url]http://www.foshk.com/wifi_weather_stati ... 0.html[url]
I have been playing with the settings and i either get nothing... or continuous garbage.
My idea was to use EspEasy with local humidity and barometric pressure instead of the standard display and indoor unit as the outdoor unit alone is less than 40% of the full price.
Is solved the problem P124_Ventus_W266_RFM69 Domoticz wind
@JustmeNL
is there any chance to show also Ice / frost warning and air pressure?
@osoon, At this moment we can”t because those sensors are internal to the Displayunit. However you could just add a bmp180 which is also supported by easyesp.
I wrote this to use with my Domoticz setup and Domoticz does not support ice warnings. You could add rules to check the temprature and send ice warnings to your setup.
thanx.JustmeNL wrote: ↑30 Mar 2018, 13:06 @osoon, At this moment we can”t because those sensors are internal to the Displayunit. However you could just add a bmp180 which is also supported by easyesp.
ive been using it now for 2-3 weeks and i have to admit there might be a bug.
in espeasy:
Plugin function:
Value 1: Rain in mm per hour
Value 2: Total rain in mm
Value 3: not used
rain per hour stays stabile 0 all the time and displayunit shows not per hour but "per day", "weekly" and "total"... how is possible that espeasy should show per hour at all?
@osoon I wrote, and tested, my plugin for Domoticz. Domoticz expects the rain per hour in mm value: https://www.domoticz.com/wiki/Domoticz_ ... L%27s#Rain
correct me if im wrong... espeasy should give some value despite it for domoticz or whatever, no? i have stable zero, but total risingJustmeNL wrote: ↑17 Apr 2018, 07:50 @osoon I wrote, and tested, my plugin for Domoticz. Domoticz expects the rain per hour in mm value: https://www.domoticz.com/wiki/Domoticz_ ... L%27s#Rain
@JustmeNL can you confirm there might be a bug?
It shows the current rain in mm/hr. So it refreshes every 5 minutes or so. If you want to know the rain in the last hour you can use the total rain counter.
are you sure?
please take a look. its raining outside here right now.
13.39 13.43 13.51 and homeassistant shows 13.51 that rain per hour was last updated 2 hours ago, its time when i restarted it. i cant see any updates every 5 minutes....
any comments?
You have a lot of this plugin activated and all on GPIO pin 0.
At first, do not use GPIO pin 0 for any plugin, unless you really know what you're doing.
Second. The plugin is not setup, I guess
Third, I am not sure this plugin will work well when used multiple times on the same ESP node. Not many plugins can work with more than one of the same active.
quick guess: you havent set up this weatherestation, right? i would appreciate help from people who knows. thank you.
regarding gpio0: i have no possibility to choose any pins.
edit: take a look https://www.letscontrolit.com/wiki/index.php/VentusW266
Ah I see, indeed. Sorry about the confusion.osoon wrote: ↑24 Apr 2018, 22:54quick guess: you havent set up this weatherestation, right? i would appreciate help from people who knows. thank you.
@osoon, You might be correct, this can't be right. Let me check the code. If this has a bug then probably the lightning strikes are also wrong.
I'll have to find the time though, so don't expect the fix in the next few days but should not take very long to fix.
thank you!
Ok, as far as I can tell it does show the current rainfall but due to a rounding error it”ll only show rainfall in excess of 12 mm/hr.
I still have to write the fix and test it out though. Also lightning can do with a rewrite sincce distance seems to work fine but lightning strikes per 5 min. also only ever shows 0.
do you have been time do look at this?JustmeNL wrote: ↑01 May 2018, 09:43 Ok, as far as I can tell it does show the current rainfall but due to a rounding error it”ll only show rainfall in excess of 12 mm/hr.
found another issue... we had last night light wain and my internal unit shows total 0,7 mm but plugin stays at zero...
I created a fix but I'm still in the process of testing. You could try it out: https://github.com/JustMe-NL/ESPEasy
If you do try this one please let me know if this fixed the problems.
seems no change, total updating but per hour still not.JustmeNL wrote: ↑13 Jun 2018, 14:57 Hi,
any updates maybeJustmeNL wrote: ↑13 Jun 2018, 14:57 Hi,
have you been time to look at this maybe?JustmeNL wrote: ↑13 Jun 2018, 14:57 Hi,
Its an old topic, i know.
But like someone else asked in the beginning, is this working with mqtt ?
As i am not using domoticz this would be great.
thanks
thanks
