Plugin Development
Re: Plugin Development
You have a lot of this plugin activated and all on GPIO pin 0.
At first, do not use GPIO pin 0 for any plugin, unless you really know what you're doing.
Second. The plugin is not setup, I guess
Third, I am not sure this plugin will work well when used multiple times on the same ESP node. Not many plugins can work with more than one of the same active.
quick guess: you havent set up this weatherestation, right? i would appreciate help from people who knows. thank you.
regarding gpio0: i have no possibility to choose any pins.
edit: take a look https://www.letscontrolit.com/wiki/index.php/VentusW266
Ah I see, indeed. Sorry about the confusion.osoon wrote: ↑24 Apr 2018, 22:54quick guess: you havent set up this weatherestation, right? i would appreciate help from people who knows. thank you.
@osoon, You might be correct, this can't be right. Let me check the code. If this has a bug then probably the lightning strikes are also wrong.
I'll have to find the time though, so don't expect the fix in the next few days but should not take very long to fix.
thank you!
Ok, as far as I can tell it does show the current rainfall but due to a rounding error it”ll only show rainfall in excess of 12 mm/hr.
I still have to write the fix and test it out though. Also lightning can do with a rewrite sincce distance seems to work fine but lightning strikes per 5 min. also only ever shows 0.
do you have been time do look at this?JustmeNL wrote: ↑01 May 2018, 09:43 Ok, as far as I can tell it does show the current rainfall but due to a rounding error it”ll only show rainfall in excess of 12 mm/hr.
found another issue... we had last night light wain and my internal unit shows total 0,7 mm but plugin stays at zero...
I created a fix but I'm still in the process of testing. You could try it out: https://github.com/JustMe-NL/ESPEasy
If you do try this one please let me know if this fixed the problems.
seems no change, total updating but per hour still not.JustmeNL wrote: ↑13 Jun 2018, 14:57 Hi,
any updates maybeJustmeNL wrote: ↑13 Jun 2018, 14:57 Hi,
have you been time to look at this maybe?JustmeNL wrote: ↑13 Jun 2018, 14:57 Hi,
Its an old topic, i know.
But like someone else asked in the beginning, is this working with mqtt ?
As i am not using domoticz this would be great.
thanks
thanks
Users browsing this forum: Bing [Bot] and 28 guests
