Working on a solution to get the HMI working with ESP_Easy 120 and the domoticz server. it is based on the serial project i already did
This is my current setup.
Setup can be found here http://vorsselmansphilip.blogspot.be/20 ... t-esp.html
I'll launch the files on github as soon as i have a minimum working configuration
Nextion HMI - Domoticz on Raspberry
running Domoticz on a raspberry pi.
mi-light on domoticz
basic knowledge in electronics
Currently developing in python
Re: Nextion HMI - Domoticz on Raspberry
The Nextion HMI screen (again)
You can find the HMI file and python code here
https://github.com/playtime1971/Nextion-HMI.git
Hardware Setup
Setting up the ESPEasy
1. Give it a usefull name
2. Enter your SSID and key
3. Point it to the domoticz server
4. Give it static network parameters
Leave the hardware settings as default
Add a new Task
And enter the Nextion Screen Serial settings
Labels: Domoticz ESP8266-12E Python Raspberry Pi
Hardware Setup
Add a new Task
Code on github has been updated
Need some help about similar project with serial interface. Can you help me about it?
Users browsing this forum: No registered users and 101 guests
