Hi, Please can someone help? I'm struggling to add a MPU6050
1. I downloaded the latest easy version - https://github.com/letscontrolit/ESPEasy
(this includes MPU6050's) https://github.com/letscontrolit/ESPEas ... PU6050.ino
2. Uploaded from arduino v1.6.11
3. Once online I found no dropdown option in devices for MPU6050??
I'm sure i'm doing something wrong, but I can't seem to work it out?
Any one know? Many thanks
I also don't see the _P186_Ventus_W266 option or _P120_Thermocouple
[img] [/img]
MPU6050 [SOLVED]
MPU6050 [SOLVED]
Re: MPU6050
Hello,hamster wrote:Hi, Please can someone help? I'm struggling to add a MPU6050
A week ago i got it working with the P118_MPU6050.ino from the playground. (compiled and uploaded with arduino ide)
Today i pulled this updated P118_MPU6050.ino and got the same trouble as you have.
As a workaround comment:
//#ifdef PLUGIN_BUILD_TESTING
//#endif
Re: MPU6050
Thanks Piet.. that worked
Much appreciated
Much appreciated
Re: MPU6050 [SOLVED]
officially you would have to add
#define PLUGIN_BUILD_TESTING
to espeasy.ino to enable all testing plugins.
we still have to update documentation for this.
Your workaround should is fine as well if you only need this plugin.
Thanks for explaining, you are doing a great job for the ESP Easy project!
Users browsing this forum: No registered users and 75 guests
