Hi, just loaded v2.0.0-dev7, from v147, an ESP with 5 relays, temp, etc. Thus, had to reload all the Devices, and got same as others on this forum:
viewtopic.php?f=18&t=2257&hilit=FS+%3A+ ... =20#p12414
Now I am unable to complete a critical setup for a garden watering system, as I cannot write any further, and I do not have the time to change code and compile myself.
Should the limit not be moved up from 100 for the normal binaries loaded on the download site?
Daily Flash rate exceeded ...
Re: Daily Flash rate exceeded ...
Hi Edwin, may I please ask for an urgent solution here, my sprinkling system is now broken, I waited a day, thinking that the 'daily flash rate' means daily', but this still does not work the next day to add the last Device?
Found a work around, a power off/on cycle sorts it out.
There's also an undocumented command to reset the daily counter:
resetFlashWriteCounter
Fantastic, thank you !
Users browsing this forum: No registered users and 151 guests
