Serial MCU controlled relay/switch
Re: Serial MCU controlled relay/switch
perfect thanks
will try to test
will try to test
I tried the R147 but did not manage to switch the relay.
as there are 3 relays , I assume only first 2 are mapped to LCTech .
but cmd=relay,0,1 does not switch anything.
any way to monitor debug this?
if I http://192.168.0.143/control?cmd=relay,1,1 then in relay1 in device overview it is not reflected. relay1 is still 0
it is only working for relay0, showing 1 , after switching. (but not the relay itself).
how do serial definition interact?
maybe it should be good to have a variable baud rate also in the plugin.
You can see the ESPEasy log about details.riker1 wrote: ↑29 Jan 2018, 15:18 Hi
Th plugin sends the following commands:
relay,0,1 = A0 01 01 A2
relay,0,0 = A0 01 00 A1
relay,1,1 = A0 02 01 A3
relay,1,0 = A0 02 00 A2
In the documentation, i found 115200 as the recommended speed. It is weird, it was 9600 in the one relay version. Now i made the speed selectable in the plugin.
New test version attached to this post. I made some nasty mistakes in the previous binary, as this plugin created for ESP Mega WEBFORM LOAD/SAVE versions originally. I think i corrected it, sorry.
thanks a lot for the fast support.
a lot of progress.
Now I can switch relay with 115200 baut.
Problem is:
relais open and close directly with command relay,0,1 : open and immediate close after half a second without any command.
Do you have and idea?
Thanks a lot
a lot of progress.
Problem is:
Thanks a lot
The LCTECH 1 relay version is reported to be veery slow, so i send every on and off command twice, this worked until now. It seems that this 2relay version is faster, and maybe does not tolerate multiple ON commands? Anyway i compiled a new binary with a new option "Use command doubling". (attached) Please make sure to set it off, and reboot the ESP if needed. In the ESPEasy Tools->Log menu you can see the sent commands.
I have no more idea at software level.
On hardware side:
The device has a chinese documentation, describing the S1 and S2 buttons, and below that some text says - according to Google Translator - that Mode2 is the phone mode, when these serial commands can be executed. Also this panel has some undocumented jumpers...
This LCTech 2 relay module is a strange thing, the original Itead module have a button that can choose between inching/self-lock mode:
https://www.itead.cc/inching-self-locki ... witch.html
I tested it, but not really a difference.
I tried mode 1 and 2 , no change
same with the jumper, without jumpers, no switching at all.
Vendor is saying: Under normal conditions, the Jumpers should be plug on the board. You'd better unplug the jumpers when you need send AT conmand to debug the ESP8266, the function of the jumpers is avoid the UART disturbance that from STM8S003/N76E003
with AT Firmware ,
switching : echo -e '\xA0\x01\x01\xA2' | nc -q 1 192.168.0.143 8080
the relay persists in position open .
all strange.
Thanks for your help
with AT Firmware ,
all strange.
Strange indeed.
In ESPEasy under Tools->Advanced, the Enable serial port is unchecked and Serial log level is 0?
There are also a P020 Serial Server plugin in ESPEasy, that you can test directly with nc.
(I am using 2.4.0-rc2 core to compile, so if in my binary the P020 plugin also does not works, than maybe R147 needs to be compiled with 2.3.0)
nc is not working with serial server for this relay. Not sure why.
disable command doubling option does not help. relay is closing immediatly.
I follow two approaches:
AT-Firmware
and EspEasy.
Now I recognized that relay is rebooting the ESP (with AT Frimware) after switching a relay. this is not stable.
I think I throw this out of the window. LC Tech is not supporting and relay is instable
Thanks for your work
cheers T
AT-Firmware
and EspEasy.
cheers T
It's very sad, i am very curious about new gadgets. There were no such errors with the LCTech 1 relay version.. maybe the relays draw to much current + the power supply is not stable enough. Perhaps you can try to apply a 1000uf capacitor between the ESP 3.3V power line and GND to stabilize.
https://iot-playground.com/images/artic ... titled.png
Please note that an empty capacitor will draw as much current as it can get.enesbcs wrote: ↑01 Feb 2018, 17:39It's very sad, i am very curious about new gadgets. There were no such errors with the LCTech 1 relay version.. maybe the relays draw to much current + the power supply is not stable enough. Perhaps you can try to apply a 1000uf capacitor between the ESP 3.3V power line and GND to stabilize.
Depending on the capacity of the capacitor, it may take some time.
So if you're using bigger capacitors, it may very well be you can overload (damage) the power regulator that stabilizes the 3.3V.
Those 3V3 versions are often not the most powerful ones.
When a separate 3V3 line is present, which powers the ESP, you may want to add a small resistor (order of 1 ... 10 Ohm) between the power and the ESP and put such a capacitor directly over the Vcc and GND lines of the ESP.
If the 3V3 comes from an onboard stabilizer, like on a NodeMCU, I would suggest to add the capacitor over de 5V line instead.
I am using a b3603 buck converter.
showing esp01 only on 80mA and additional 50 mA for each relay. Power should be stable.
I set input power to 5 V 1 A, when 2 Relay were open, current was 200mA.
Hard to put resistors and capacitator in the relay ESP is onboard plugged on.
maybe it is also possible to control / program the onboard STM8S003 SWIM.
hard to give up....
hard to give up....
good news,
problem was related to power supply via breadboard.
all working now. Thanks for your support.
will p165 be part of a normal release?
compiling a release myself failed with always different errors....
good news,
If it is considered stable, you can always make an issue for it on Github.
I think there are lots of plugins on the playground which may benefit others.
Plugin is currently working only with Arduino core 2.4.0-rc or newer, so compilation with default settings is not straightforward. I think the plugin status is better than "DEVELOPMENT", but reported to run out of memory on Sonoff Dual after a month uptime. On my Tuya wall light switch, i have no such problems, but it is moderately used by me. So i guess my plugin falls under "TESTING" category.
The supported 3 type of hardware: Sonoff Dual, Tuya touch light switch and LCTech relays is not typically used as sensors (only a few GPIOs accessible) so i remove a lots of plugin before compiling it, for speed and size reasons.
I think i will offer pre-compiled binaries in 3 versions for users who have problems with compilation:
1. ESPEasy Mega 4MB/1MB SPIFFS
2. ESPEasy Mega 1MB/128k SPIFFS
3. ESPEasy R147 1MB/64k SPIFFS (legacy version for PUYA - SPIFFS not used in this release, but checked by ESPEasy to be greater than 0 for some reasons)
In these binaries i will include the following:
Controllers: All (C001-C011)
Notification plugins: All (N001-N002)
Plugins: P165 SerSwitch, P001 Switch, P002 ADC, P003 Pulse, P020 Ser2Net (for debugging purposes), P021 Level, P026 Sysinfo, P029 Output, P033 Dummy, P037 MQTTImport, P043 ClkOutput (not sure if it can be useful for this devices), and for in case also including my Modemsleep plugin P166 just in case.
If anyone has other needs, write it.
that sounds great.
one hint maybe.
looks like for lc Tech relays with 2 relays, only statsu of 1. rleay is send to fhem
message is rel:on rel:off
but only for first relay0 not relay1
thanks Thomas
that sounds great.
one hint maybe.
thanks Thomas
Yes from the beginning this device reports itself as SWITCH, and in ESPEasy it can report exactly one value, the first. This is why i am using Rules, to report back each relays separately, as this mentioned in the first post.
To address this issue, now i changed it to SENSOR_TYPE_TRIPLE and tried to change it according the selected number of buttons.
Hint: if selecting the LCTECH type for the first time in the device settings, please refresh the page and Submit another time, after selecting the number of buttons, and other options, to make sure to save it.
Binary attached to the first post of this thread:
download/file.php?id=1930
ok top thanks
will try
it is working,
only small thing. relay names must be short to be distinguished in fhem:
fhem is showing Rel: 0 Rel: 0
changed in EasyESP : shorter names : R1: 0 R2: 0 appears in fhem
ok top thanks
will try
it is working,
Hi!
Thank you very much taking the time to produce this. I admire your work here and greatly appreciate what you accomplished.
I have recently purchased a Tuya clone 1-gang wall switch from aliexpress. I like them since they don’t have any branding in the glass pane like sonoff and their glass cover color matches the case color.
I’ve disassembled the switch, luckily I saw the pins out there with labels on the back.
I am quite new to these things and don’t have any electronics background but have some programming knowledge. I had previously flashed sonoff devices with tasmota with success and have embedded them into my home assistant network running on a raspberry pi 3. On the other hand, I have tried to use your firmware but to no luck. I have listed the steps I have followed below. I will be glad if you can help me figure out how to make it work with the device I have.
1) I connected the ESP8266 module to a raspberry pi 3 running on raspbian in flashing mode. I don’t have a USB-UART device, so I am limited to using linux based solutions for flashing
2) I downloaded the compiled version of your plugin for Tuya
3) I backed up the existing firmware using esptool.py (just in case I need to revert to the original firmware in the future)
4) power cycled, erased the existing firmware
5) power cycled, uploaded the new firmware, namely ESPEasy_Mega_P165_4M_1MS.bin from the zip file in the first post.
6) exited flashing mode (disconnected GPIO0 from ground) and power cycled
7) I was now able to see ESP_XXXX access point available in the wireless networks list. However, when I connected, I was unable to open the webpage on 192.168.4.1. I tried to ping and it worked, but the webpage did not show up
8) Still connected to raspberry pi, I ran miniterm.py to listen to the serial log. See the log output below. Seems like ESP was constantly rebooting itself due to an error (which I cannot figure out) and repeats the same error message continously.
9) I also tested powering the switch from a wall plug instead of raspberry pi, but the results were the same/
Any ideas how I can make this work? Is there something that I am missing?
By the way, the product works fine with the vendor app and other third party software on its original firmware.
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
tail 8
chksum 0x2d
csum 0x2d
v4ceabea9
~ld
�U
INIT : Booting version: (custom)
INIT : Warm boot #10
FS : Mounting...
FS : Mount failed
FS : Mount failed
RESET: Resetting factory defaults...
RESET: Warm boot, reset count: 3
RESET: Too many resets, protecting your flash memory (powercycle to solve this)
CRC : No program memory checksum found. Check output of crc2.py
FS : Error while reading/writing config.dat in 1091
PID:0
Version:0
Exception (0):
epc1=0x4000e25d epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: cont
sp: 3fff3bf0 end: 3fff3e50 offset: 01a0
>>>stack>>>
3fff3d90: 3fff4e8c 00000100 00000001 40201980
3fff3da0: 40202a82 3fff4ebc 00000001 40202b88
3fff3db0: 00000000 0000001c 00000003 3fff4ea4
3fff3dc0: 3fffdad0 3fff2e20 3fff2d60 3fff2e20
3fff3dd0: 3fffdad0 00000001 3fff2d60 4022d0f8
3fff3de0: 00000000 0000001c 00000000 40202932
3fff3df0: 402018b6 3fff2d60 3fff1d48 40207e61
3fff3e00: 3fffdad0 3fff2d60 3fff1d48 402251ac
3fff3e10: 00000000 00000000 00000000 3fff4fc4
3fff3e20: 0000002f 00000014 feefeffe feefeffe
3fff3e30: 3fffdad0 00000000 3fff2e1a 4022ee20
3fff3e40: feefeffe feefeffe 3fff2e30 40100710
<<<stack<<<
- 195B67E3-370A-42C0-B532-D97FD03C7457.png (1.28 MiB) Viewed 73919 times
- 6610B890-DBB9-4A5F-A952-8EF72A8FB0C8.jpeg (1.85 MiB) Viewed 73919 times
- 4A5207F2-76D4-47AB-AD1D-B18F442E5A62.jpeg (1.88 MiB) Viewed 73919 times
- 4176A19F-4944-4F08-9881-667E8E894E1B.jpeg (1.64 MiB) Viewed 73919 times
I'm using the downloadable P165_18 version.
The problem is that if I restart the router, it will not re-connect the ESPEasy to the router, but switch to the AP mode.
The rest of ESPEasy will re-connect to the router.
Thanks for the quick response! I was able to connect to the device using the 1M version. Now it’s time to figure out the correct settings...
By the way, the physical button does not function at all after the flash. Does it have to do with the settings?
Of course!
You must also set the button as an input device.
This Kinco switch seems very interesting, on the Yewelink the main button works all the time, because that was hardwired to the MCU. Are you sure, that this switch communicates serially with an MCU?
If it is, you can try to enable all 3 button in the Serial MCU settings, then do a soft reboot and see if anything shows in log when you press the main button. And also see if relay,0,1 or relay,1,1 commands doing anything with the relay.
FYI there are some Tuya clone which does not use the serial API, instead using direct GPIO-s: (in this case buttons are controlled by the ESP and you have to code some logic (Rules) in the same way like the Sonoff Touch)
such as GPIO-12=RELAY,GPIO-5=PWR LED
I ordered the Kinco switch yesterday and want to flash it to be used through Domoticz when it arrived. How would I know if this will work with any firmware?
---edit---
Hmm, the description on AliExpress says it uses the eWeLink app, just like Sonoff. Wouldn't that mean they function quite like the Sonoffs? So through the GPIO's?
---edit---
I am afraid there are absolutely zero informations about Kinco switches, you can be the first who take apart one, measure with multimeter that which GPIO's connected to which relay if any.. as i do with my own switch.barrymossel wrote: ↑06 Mar 2018, 09:01 I ordered the Kinco switch yesterday and want to flash it to be used through Domoticz when it arrived. How would I know if this will work with any firmware?
---edit---
1/ If you are lucky, the ESP GPIO's are connected directly to the relays, and can be used simply with some Rules in ESPEasy.
2a/ If not, you have to listen the serial communication between the ESP and the MCU modul (i did it with P20 Serial server plugin), if the packages starting with 0x55aa then they are using the Tuya protocol, and P165 plugin can be used. (Yewelink/TUYA) Tuya has published it's official serial API that is licensed by Yewelink, so it has to work.
2b/ If the packages starting with 0xA004 or 0xA000 then it is using the Sonoff protocol and can be used as a Sonoff Dual device also supported by this plugin.
3/ If none of the above then you are on your own.
We will just have to wait I guess
But I can imagine that as it uses the same app as Sonoff (T1) switches, it might be compatible with ESPEasy + some rules.
I will take it apart as soon as I receive it!
The Sonoff Dual also uses EweLink app, but do not use direct GPIO controlling.. but hope dies last.barrymossel wrote: ↑07 Mar 2018, 10:00 We will just have to wait I guess
Haha, let's keep hoping...
I have managed to figure out that the Kinco switch uses the GPIO pin 4 to manage the relay.
I can turn it on and off using the commands but I am struggling with operating the physical button still. My initial idea was that it would be linked to one of the GPIO pins and I would be able to program a trigger that switches GPIO4 when the button is pressed.
I am checking the values of all GPIO pins and then pressing the button and then checking again. However, I don’t see any change in GPIO values.
Any thoughts how I can capture the physical button press?
If i were you, i would set up switches in ESPEasy to "Switch" devices for the following GPIO's:
GPIO-0
GPIO-2
GPIO-4
GPIO-5
GPIO-12
GPIO-13
GPIO-14
GPIO-15
Then when you touch the button, it will be in the ESPEasy logs.
I did the following
but can't see anything in the log when I press the button. any other thoughts?Re: Serial MCU controlled relay/switch
I only see 4 gpio's on the picture. Can be GPIO12-GPIO13-GPIO14?
When you said "GPIO pin 4" you referring GPIO-4 as the picture below?
Perhaps you can trace back the GPIO's from ESP to the touch with a multimeter...
Also there is a CR302..whatever chip with 16 legs on the back side i can not read every letter from the picture, maybe the central K2 touch is connected to it's R2?? Could you find out what's this chip full name?
Rest of the GPIOs were on the next page. Didn't take a screenshot of that. I have all the GPIO pins that are available defined as switches.
By GPIO4 I mean using the command - GPIO,4,0
Regarding the multimeter - I haven't used it for this purpose before. Should I connect the black line of multimeter to ground pin of ESP and test the red line with the other pins while pressing the button on and off? Or should I use the continuity mode somehow?
it says:enesbcs wrote: ↑13 Mar 2018, 21:33I only see 4 gpio's on the picture. Can be GPIO12-GPIO13-GPIO14?
CR302
B747U005PG4
nothing pops out in google when I search for it
It's a bit confusing, if the touch sensors not wired to ESP, than maybe it's some sort of touch controller (CR302) which is wired to ESP8266 serial/I2C/SPI i can not tell it from pictures.
I used the multimeter continuity function to backtrace wiring, more or less success. Multiple layered PCB's are hard to backtrace.
Attachments updated in the first post, plugin compiled against the new TurboCharge 20180311 ESPEasy Mega
viewtopic.php?f=6&t=3245&start=90#p16998
I used a multimeter to measure the changes in voltage on my kinco touch switch and figured out that the voltage on the serial pin market with R changes (goes down to 0 depending on how long I press) when I touch the physical button. I guess now I have to figure out how to read serial pin values. I am quite new to the esp easy firmware, please forgive me if this is something trivial.
Nice work, you are in the right direction.dent wrote: ↑14 Mar 2018, 23:42 I used a multimeter to measure the changes in voltage on my kinco touch switch and figured out that the voltage on the serial pin market with R changes (goes down to 0 depending on how long I press) when I touch the physical button. I guess now I have to figure out how to read serial pin values. I am quite new to the esp easy firmware, please forgive me if this is something trivial.
Easy and ugly way if you have only one button on the Kinco:
In ESPEasy menu:
Tools->Advanced->Enable serial port (check box unticked - so disable!)
Tools->Advanced->Serial log level: None
Now you are able to create a Switch device on RX it's GPIO3, and see if it changes state in the log.
The harder way:
- Enable serial port usage, but disable serial logging, also disable all plugin (P165) and device that using serial pins.
- Setup "Communication - Serial Server" plugin for debugging (port 23, baud 9600, 8n1)
https://www.letscontrolit.com/wiki/index.php/Ser2Net
- install Realterm to your PC, setup for displaying in hexadecimal in Display menu, in Capture write the ESP device IP address and port (23) and set the serial settings that matches with the ESP Ser2Net plugin
In that way when you press the touch, you have to see the same Hex byte array - maybe two different: one when switching off, another when switching on. If you see only garbage or not the same numbers every time, you have to change bitrate on each of them and retry. If you can provide the correct hex array i can include in this plugin.
It appears that the one I received is a bit different than the one posted before:
Also it doesn't use the EweLink app as described but the (Tuya?) SmartLife app. I am willing to open it up and experiment with it, but first I'll wait off the dispute with the seller as the front (the only reason why I bought this particular one) is different from the pictures (icons of lamps and can only be placed with the buttons op top of each other instead of next to each other).
I tried your suggestions and I am now able to command the switch and the leds on it trough GPIO commands. I set some rules, installed mqtt and now I am able to control the whole thing both physically and wireless.enesbcs wrote: ↑15 Mar 2018, 09:07Nice work, you are in the right direction.dent wrote: ↑14 Mar 2018, 23:42 I used a multimeter to measure the changes in voltage on my kinco touch switch and figured out that the voltage on the serial pin market with R changes (goes down to 0 depending on how long I press) when I touch the physical button. I guess now I have to figure out how to read serial pin values. I am quite new to the esp easy firmware, please forgive me if this is something trivial.
In ESPEasy menu:
The harder way:
I have also tried the 'hard way'. The hex output I see is "00" almost all the time when I press or hold the button. Is this normal or is "00" an error of some sort?
I have also purchased 2 and 3 gang versions and waiting for their delivery. I will let you know when I get them and try to find out their hex outputs.
I am glad that it helps, maybe you can publish the used GPIO numbers and rules for the others who are buying Kinco switches in Hardware topic.dent wrote: ↑21 Mar 2018, 21:28 I tried your suggestions and I am now able to command the switch and the leds on it trough GPIO commands. I set some rules, installed mqtt and now I am able to control the whole thing both physically and wireless.
I think:
1/ maybe 00 means "button 0" as it is the first and only button on this switch which is returned from the simple serial touch sensor - in which case this is absolutely not a Tuya compatible device - the Tuya protocol seems like "55aa 00 07 0005 01 01 00 01 01 0F". (in hex for the first button)
2/OR the serial baudrate setted in the ESPEasy did not match with the MCU builtin speed in which case the zeroes means nothing. 9600 and 19200 are the most popular default speeds with 8N1.
I did not find anything about this specific chip, however in the AR1000 touch controller datasheet there are a comment in the UART communication mentioning "Sleep mode will cause the TX line to drop low, which may appear as a 0x00 byte sent from the controller"
Hello everybody.
I'm newbie on this forum, and totally beginner with platformio.
I'd like to ask tou how to compile this plugin on 2.3.0 core?
I got error:
I got error:
:/ESPEasy-mega-20180402/src/_P165_SerSwitch.ino: In function 'boolean Plugin_165(byte, EventStruct*, String&)':
L:/ESPEasy-mega-20180402/src/_P165_SerSwitch.ino:481:16: error: 'class HardwareSerial' has no member named 'setRxBuffer
Size'
This plugin made for core 2.4.0rc2, 2.4.0rc1 or 2.4.0 stable.xury wrote: ↑03 Apr 2018, 19:37 Hello everybody.
I got error::/ESPEasy-mega-20180402/src/_P165_SerSwitch.ino: In function 'boolean Plugin_165(byte, EventStruct*, String&)':
Size'
Lack of setRxBuffer is the main reason i do not use previous cores, because for Tuya compatibility the buffer needs to be extended at least 100 bytes! I am serious, their transmitting al three button state every time when change occurs, even if the device only have one button or only one button state changed. If buffer is smaller than 3x33 bytes
that will cause very funny errors, for sure.
In core 2.3.0 the hardware serial buffer is defaulted to 32 bytes and can not be altered in the user space.
If you are desperately want to use the older, KRACK-affected 2.3 core, and DO NOT want to use Tuya, than be my guest, and try the following modifications with the plugin source (Dual and LCTech might work):
Modify:
#define BUFFER_SIZE 100
To:
#define BUFFER_SIZE 32
And comment out the two following lines:
//Serial.setDebugOutput(false);
//Serial.setRxBufferSize(BUFFER_SIZE);
Thank You enesbcs
I will try to compile with your sugestions this evening when I come back home. I need it for lc tech relay so I hope should be good with buffer size 32.
I have one more request. Would you like give me a link for a core 2.4.0 source because as I said im totally beginner.
A don't know how to work with 2.4.0 in platformio without git.
Maby is a zip package with 2.4.0 enviroment to get easy way as in toutorial?
I also found a solution how to reflash lctech IC to get info about relay state.
https://www.esp8266.com/viewtopic.php?p=74262#p74262
From above post after reprogram chip we can use:
Im succesfuly reprogram STC15F104W so I can confirm it's work properlyB0 01 01 B2 -> Reading relay in text format ("ON" and "OFF" ending with a linefeed).
B0 01 00 B1 -> Relay reading in binary format (00 = ON and 01 = OFF).
B0 00 01 B1 -> Reading the firmware version in text format ending with a linefeed.
I am also do not know platformio, because i am compiling with Arduino:xury wrote: ↑04 Apr 2018, 12:02 A don't know how to work with 2.4.0 in platformio without git.
https://github.com/esp8266/Arduino
I checked this user provided binary for the STM. The new commands is nice, but i am not sure what can i do with the nonstandard replies without headers? Also there are a two relay version of this device what about that?
As your suggestion I managed to compile on 2.3.0 core. Plugin sims work OK but when I try add new device I have error in red frame:
I guess is a filesystem error. Maybe not enough flash? Or is wrong organization, because I had another version of firmware before.
I'll tray to disable some unneeded plugins for me and check again.
Ok. I finally managed to compile with what I need.
It was a problem with PUYA chip.
After patching Esp.cpp it works well.
Hi Guys, I have used ESP Easy before, but so far I only uploaded the precompiled bins.
So to make this work for the LCTech relay board I need to compile my own version e.g. from Arduino? This also means that this core 2.4 is not the same as the 20180428 binary versions?
A slightly off topic question: I tried playing around with the ESP_Easy_mega-20180424_normal_ESP8266_1024.bin version (I have a black ESP-01 and not with the PUYA chip). I cannot get it to connect to the AP. I put the password in and nothing happens it comes back to setup. If I flash the older 147 build that works just fine. Any pointers?
Cheers,
Csongor
Cheers,
Csongor
If you want use another plugins not included in bin files shared at first post you have to compile using Arduino or Platformio.
About problems with new releases you mast observe serial output during connection and read logs data.
P.S I have request to enesbcs. If is possible to fix a plugin? On recent sources I have :" Bug in PLUGIN_WEBFORM_LOAD, should not append to string, use addHtml() instead" I cannot it fix myself.
There are always precompiled binaries in the first post in this thread with P165 plugin, no need to compile, if you are not familiar with it. If you need a plugin that is not contained the binaries, name it.
Users browsing this forum: Ahrefs [Bot] and 131 guests
