Problem saving Task/Plugin settings
raihei
#1 Post by raihei » 03 Jan 2018, 21:21
Hi all,
I have some problems saving some configuration/values
Build: ESPEasy_v2.0.0-dev12
In a custom devices plugin when a command (http://ip/control?cmd=rgb,off) is received I try to save a value to retain it when the ESP is powered off.
Settings.TaskDevicePluginConfigLong[event->TaskIndex][2] = rgbvalue;
When I read back this value directly after saving it via
Serial.println(Settings.TaskDevicePluginConfigLong[event->TaskIndex][2]);
it shows the right (saved) value.
But when powered back on and I try to restore the value in the "PLUGIN_INIT", it is always zero
case PLUGIN_INIT:
        LoadTaskSettings(event->TaskIndex);
        rgbvalue = Settings.TaskDevicePluginConfigLong[event->TaskIndex][2];
        success = true;
Am I doing something wrong, or is it not supposed to work like that?
I also tried to add SaveTaskSettings, but the value is still not saved...
SaveTaskSettings(event->TaskIndex);
Is there another way to retain a value while powering off the device?
regards
raihei
vader
Re: Problem saving Task/Plugin settings
#2 Post by vader » 05 Jan 2018, 16:30
I think "Settings.TaskDevicePluginConfigLong" does not save to flash! So you are saving/reading just from memory.
You can try this....
SaveCustomTaskSettings(event->TaskIndex, (byte*)&rgbvalue , sizeof(rgbvalue ));
LoadCustomTaskSettings(event->TaskIndex, (byte*)&rgbvalue , sizeof(rgbvalue ));
PS: I'm no prof programmer!
raihei
#3 Post by raihei » 05 Jan 2018, 21:32
vader wrote: 05 Jan 2018, 16:30 I think "Settings.TaskDevicePluginConfigLong" does not save to flash! So you are saving/reading just from memory.
Thank you very much vader, that worked for me!
Users browsing this forum: No registered users and 129 guests
