It's done. Beware that you will experience a full reset because this version has a different memory layout for the config.dat file.VoBo wrote: ↑02 Mar 2018, 18:06 Hi everybody
I´m playing around with R20100 on my ESP32 board.
Installing was easy and everything what I need, is already working
"One" of the advantages of the ESP32 ist the increased amount of GPIO Ports; but the amount of devices in R20100 ist only 12.
Is it possible to increase also the amounts of devices ? I think that 24 or 32 should be enough. As far as I know, there are only 12 device because of the limits at an 8266.
The ESP32 should have enough ressources for more devices ?
Is it possible to change this ? And, if yes, can somebody compile a version with more devices ? (for me, that is too deep in arduino)
greetings from germany
Volker
Now we have a theoretical max of 32 tasks to be configured. It doesn't imply that performance will be sufficient to actually run 32 tasks as this has never been tried before. I can imagine that when you run a large number of tasks that use the 10PERSECOND polling scheme, the system could slow down to a hog...
But hey, this route is highly experimental anyway...
