Good Day All,
Thanks to everyone involved in the development of this brilliant firmware for the ESP8266, I have found it most useful and stable.
I am building a peltier temperature controller for home brewing fermentation, IO 12 to cool and IO 14 to heat,the rules below are working well,but I need both GPIO pins taken low when temperature is between 6 and 7 degrees.
What rule can be used to implement this ?
Does ESPeasy support =< and => ?
Have tried but it does not seem to work,unless my syntax is wrong.
On Fermenter_Temp#Fermenter_Temperature<6 do
gpio,12,0
gpio,14,1
On Fermenter_Temp#Fermenter_Temperature>7 do
gpio,14,0
gpio,12,1
Cheers Dave
ESP Rules
Re: ESP Rules
add...
On Fermenter_Temp#Fermenter_Temperature>6 do
gpio,14,0
On Fermenter_Temp#Fermenter_Temperature<7 do
gpio,12,0
Re: ESP Rules
Those rules perfectly,thanks
Do ESPeasy rules support =< and => or only <,> and =
Re: ESP Rules
Only < > = are supported.
But X=>10 can be changed to X>9.99 for almost the same result.
Users browsing this forum: No registered users and 124 guests
