ESP Easy Mega ESP_Easy_mega-20180223_dev_ESP8285_1024
the first start and entering the password is ok
after timeout ...
I can not enter the password on the page because you can not see the password field !?
test :IE, firefox,chrome...
WWW login problem...
Re: WWW login problem...
Did you try to reboot the ESP module?
I did a quick test here (on newer code, which will be merged quite soon) and I noticed you had to reboot the ESP module to get the password check active.
Also, see this issue: https://github.com/letscontrolit/ESPEasy/issues/884
no problems with ESP_Easy_mega-20180219_dev_ESP8285_1024
but..
I can not turn ON Sonoff Touch with mosquitto
mosquitto report ok:
myhome/sonoff/touch/switch 0
myhome/sonoff/relay/switch 0
or
myhome/sonoff/touch/switch 1
myhome/sonoff/relay/switch 1
unfortunately:
mosquitto_pub -h localhost -t myhome/sonoff/relay/switch -u "user" -P "mypassword" -m "0"
or
mosquitto_pub -h localhost -t myhome/sonoff/touch/switch -u "user" -P "mypassword" -m "0"
did not work..
Configure ESPEASY from :https://www.letscontrolit.com/wiki/inde ... noff_Touch
but..
or
unfortunately:
or
did not work..
You need to send commands to the "cmd" topic.
https://www.letscontrolit.com/wiki/inde ... _Reference
About the login part:
See my temporary work-around to allow you to login: https://github.com/letscontrolit/ESPEas ... -368300365
This will be fixed in the next build.
TD-er - this is it ! thx
ok.grovkillen wrote: ↑25 Feb 2018, 07:12 You need to send commands to the "cmd" topic.
how to send the same command from openhab?
example please...
no question. I am stupid7keys wrote: ↑25 Feb 2018, 12:23ok.grovkillen wrote: ↑25 Feb 2018, 07:12 You need to send commands to the "cmd" topic.
example please...
%sysname%/cmd -m "GPIO,12,1"
sorry
Users browsing this forum: Bing [Bot] and 115 guests
