Removed all except a few of the plugins and the build size gets down enough to build the firmware.
But getting stuck after that.
The resulting image fails on:
No (or too small) SPIFFS area..
System Halted
Please reflash with 128k SPIFFS minimum!
The first problem is I cant get a variant of src_filter to work, so I just drop the src code.
src_filter = +<*> -<.git/> -<svn/> -<examples/> -<_P*> +<_P014_SI7021*> +<_P019_PCF8574*> +<_P026_Sysinfo*> +<_P074_TSL2591*>
Because of the SPIFFS error I tried other settings for esp8266.flash.512k64.ld
esp8266.flash.512k0.ld
esp8266.flash.512k128.ld
It seems I should follow the advice and dispose of these 512k modules. Its a pity though since I have a dozen of them and put some work in half of those.
I'm only wondering if I should have tried to build the v2.0 branch iso. the mega, if that would've made any difference.
