Hello!
I have problem with Wifi setup. When chose network and type password, counter going to zero and I got only this (look at screenshot)
My board is WEMOS D1 mini pro, and I use release ESPeasy mega-20180320.
Board is invisible in the DHCP list on the router. I checked two Wemos board, and two wifi networks. Still does not work:(
Eny ideas why?
Wifi Setup wizard stuck
Armageddon was yesterday, today we have a serious problem.
Re: Wifi Setup wizard stuck
Have you tried to power off and on again?
Yes, I tried without success.
Issue is confirmed, I'm working on a fix now and it will be fixed in the next build tomorrow.
As a short-cut you can try to flash the 0316 build, do initial setup and flash 0320 if you like.
The problem is in the connection test before the settings are being saved.
Thanks for the information. I am waiting for a new release :):)
Users browsing this forum: Ahrefs [Bot] and 91 guests
