GPIO-1 and GPIO-3. Can I use them?
Re: GPIO-1 and GPIO-3. Can I use them?
Great, thank you very much. I will try it when I receive this device.
Does it mean that example has a mistake? They have Port 1 and IDX/Var is 22, but in your explanation IDX/Var 22 (17-24) would be with the port 2, not port 1. Am I correct? Or maybe I do not understand it.Shardan wrote: ↑22 Mar 2018, 16:33 The input port number depends on the address you've chosen with A0...A2. If you have set A0-A3 to "0" or "Off", this is chip address 0,
so input pins for the setup in ESPEasy are pins 1 ... 8 (so called "Port Range")
If you set for example A0 = 0, A1 = 1 and A2 = 0 you selected the chip address 2. Port range will be 17 ... 24 then.
Thank you.
Port number and IDX are not related.onlize wrote: ↑22 Mar 2018, 23:58Does it mean that example has a mistake? They have Port 1 and IDX/Var is 22, but in your explanation IDX/Var 22 (17-24) would be with the port 2, not port 1. Am I correct? Or maybe I do not understand it.Shardan wrote: ↑22 Mar 2018, 16:33 The input port number depends on the address you've chosen with A0...A2. If you have set A0-A3 to "0" or "Off", this is chip address 0,
Thank you.
In the example in the wiki:
The 3 adress bits (A0-A2) of the PCF chip are all set to 0.
This means the chip will have the I2C-Adress 0x20 and the port range is 1-7.
If the adress bits were set to 1 0 0 the adress of the chip changes to 0x21 with the port range 8-15.
This way, up to 8 chips can be daisy chained.
The IDX is the unique identifier for Domoticz. It has nothing to do with the adress/port of the PCF.
Got it. That IDX value confused me. Thank you for explaining.
Users browsing this forum: No registered users and 131 guests
