Hello all,
i use ESP Easy at Sonoff-S20. Works great, but sometimes the system crashes.
I start monitoring system variables. (CPU load, Memory, uptime, ...)
After some uptime i see high CPU load (70%) while using LongPulse. Crashes i see only while CPU load is high.
i switch to the timer function. But the result is the same.
I try different versions ... precompiled from 2.0.0-dev10,dev11,dev12 (1MB) ... currently i have a version compiled by myself with sources from march (some WiFi mods)
all with exactly the same problem
High CPU Load and crashes with LongPulse or Timer
- uptime/CPU-Load/...
- SensorCrash1.JPG (53.89 KiB) Viewed 1648 times
Users browsing this forum: Amazon [Bot], Google [Bot] and 49 guests
