sorry... what is DNS 1?... what you mean?TD-er wrote: ↑15 May 2018, 00:03What did we do with the sensors?grovkillen wrote: ↑14 May 2018, 22:17 You should not add a suffix number to the JSON path. Do what we did with sensors.
And does this mean "DNS 1" is also not a good idea?
ESPeasy and IDX on JSON string
Re: ESPeasy and IDX on JSON string
He was talking to me
dear all,
I'm trying to install and test the version with implemented JSON "IDX".
I have a problem to compile the new version.
In particolulary I use Arduino IDE arduino-1.6.12.
Till now (up to ESPEasy_mega-20180516.zip) I have all time compiled and programme ESP using the method described on this link (https://www.letscontrolit.com/wiki/inde ... are_Upload).
Today I'm trying to compile ESPEasy_mega-20180517 - 18 and 19 but, I have all times error, like show below:
/opt/arduino-1.6.12P230/portable/sketchbook/ESPEasy_mega-0517/WebServer.ino: In function 'void WebServerInit()':
WebServer:407: error: no matching function for call to 'ESP8266WebServer::on(const __FlashStringHelper*, void (&)())'
WebServer.on(F("/"), handle_root);
I saw "old" webser.ino and in particular:
// Prepare webserver pages
WebServer.on("/", handle_root);
and "new" webser.ino
Can someone help me to understand where is the problem?
thank you in advance!
ricc
ricc
We use PlatformIO as the official IDE so I cannot really help you. Sorry!
ciao!
I will try to install PlatformIO.
I saw 2 different things... PlatformIO IDE for Atom and PlatformIO IDE for VSCode.
I use linux... what you suggest me to use?
thank you
ricc
thank you
ricc
I use PlatformIO with Atom.
Just curious, what's the reason to build your own version?
ciao,
but ...
first of all becouse I started to use the link where letcontrolit show how compile and program flash by using Arduino IDE.
Second becouse we need some small changes to adapt ESPEasy for our laboratory
I don't understand why with Arduino IDE doesn't compile more... i can't find error... mmmm
thank you again!
ricc
but ...
thank you again!
ricc
dear all,
1)
I found the problem, we can still to compile and download the ESPEasy with arduino IDE (arduino-1.6.12), but we have to update the 8266 library, from original one to 2.4.1. With this we can do the same things explainded on main site (https://www.letscontrolit.com/wiki/inde ... are_Upload)
2)
I saw yours code to add IDX on JSON string... but I can't see IDX on JSON page... I can saw just this
"Sensors":[
"TaskValues": [
{"ValueNumber":1,
"Name":"Analog",
"NrDecimals":2,
"Value":7.00
"TaskNumber":1,
"TaskEnabled":"true",
"TaskInterval":1,
"Type":"Analog input - internal",
"TaskName":"ADC 1"
In your code there is a variable to on/off this... (show Data Acquisition) what I have to do to activate the IDX implementation ?
3)
Still I saw the error on third IDX code: missing field to put the number thank you a lot
ricc
1)
2)
"Sensors":[
"TaskValues": [
{"ValueNumber":1,
"Name":"Analog",
"NrDecimals":2,
"Value":7.00
"TaskNumber":1,
"TaskInterval":1,
"TaskName":"ADC 1"
3)
ricc
Users browsing this forum: No registered users and 90 guests
