HTTP advanced controlle - instability?
spachal
#1 Post by spachal » 19 May 2018, 20:20
Hi, I'm using test builds with on nodeMCU board, with only one sensor (BME280). Everything is now stable (including wifi, thanks!), but only until then I configure HTTP Advanced controller (http://www.letscontrolit.com/forum/view ... f=6&t=5298). After that I have a lot of reboots (appr. 3-10 per hour).
- nodeMCU 32MB board
- fw mega-20180517 (ESP82xx Core 2_4_1, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3), test 4096, but the same problem I had also with older releases
- one BME280 sensor (gpio4+5)
- I only changed device name, enabled NTP and using DHCP with reserved IP
- one HTTP Advanced controller (POST to rasspi influxdb)
- no rules (disabled), no notifications, no sleep mode, no mqtt
Log:
482920 : HTTP : connecting to 192.168.166.177:8086
Panic /home/travis/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/core_esp8266_main.cpp:99 __yield
ctx: sys
sp: 3fff30c0 end: 3fffffb0 offset: 01b0
>>>stack>>>
3fff3270:  00000003 00000029 3fff1e28 402577f7 ....
Do you have any idea how to solve this 'an unpleasant' problem? Thanks! :]
Please excuse my English, thanks!
