several rules
Re: several rules
thx, the event works in general, but the motor does not stop if [Reed1-oben#Switch] changes from 0 to 1.
But this should be the case, right?
If I release the [Taster1#Switch] and press it again, while [Reed1-oben#Switch] is still 1 motor does not start again. This is correct.
Also if [Reed1-oben#Switch] is 1 when [Taster1#Switch] is pressed the motor does not start. Keeping the [Taster1#Switch] pressed and [Reed1-oben#Switch] changes from 1 to 0 the motor starts. This is alos correct.
Re: several rules
Post your code and add comments (//) where is not working.
Regards,
Regards,
Re: several rules
I was refering to this:
And I would have expected the motor to stop, when [Reed1-oben#Switch] changes from 0 to 1.
//Dummy1
//999 default
//1[Dummies#Tag][Reed1-oben#Switch][Reed2-unten#Switch]
//1110 day door open
//1101 day door down
//1010 night door open
//1001 night door down
On System#Boot do
TaskValueSet 7,1,0 // no day = 0
TaskValueSet 7,2,200 // Helligkeit on dummy sensor
TaskValueSet 7,3,0 // DC Motor off
TaskValueSet 7,4,0 // Timer off
TaskValueSet 8,1,999 // To concat of some dummys (named Dummy1#Concat) '999' just as a default ref
timerSet,2,10
// day or night
On Lichtsensor#Analog do
if [Lichtsensor#Analog] > [Dummies#HelligkeitTriggerTag]
TaskValueSet 7,1,1
TaskValueSet 7,1,0
//every 1 sek Timer1 is adding values from the devices to the concat dummy
On Rules#Timer=1 do
TaskValueSet 8,1,1[Dummies#Tag][Reed1-oben#Switch][Reed2-unten#Switch]
timerSet,1,1
On Taster1#Switch do
If [Taster1#Switch]=1 and [Reed1-oben#Switch]=0
Event,DoorClose
Else
Event,DoorStop
On DoorStop Do
WemosMotorShieldCMD 0 Stop
TaskValueSet 7,3,0
EndOn
On DoorOpen Do
WemosMotorShieldCMD 0 Backward 50
TaskValueSet 7,3,1
EndOn
On DoorClose Do
WemosMotorShieldCMD 0 Forward 50
TaskValueSet 7,3,1
EndOn
Else
Event,DoorStop
Re: several rules
ok, got this now working with events. door motor is triggered by push button or cmd.
so basic version is working, as wife is asking for POC...
but this is manual interaction. next step is automation. either based on light sensor or weekday and time.
On System#Boot do
timerSet,2,10
//close door if Taster1 is pressed and door is not closed
On Taster1-close#Switch do
If [Taster1-close#Switch]=1 and [Reed2-close#Switch]!=1
Event,DoorClose
Else
Event,DoorStop
//stop door close if reed2 changes from 0 to 1
On Reed2-close#Switch do
If [Dummies#DCMotorOn]=1 and [Reed2-close#Switch]=1
Event,DoorStop
//stop door open if reed1 changes from 0 to 1
On Reed1-open#Switch do
If [Dummies#DCMotorOn]=1 and [Reed1-open#Switch]=1
Event,DoorStop
//Events
On DoorStop Do
TaskValueSet 7,3,0
EndOn
On DoorOpen Do
If [Reed1-open#Switch]!=1
TaskValueSet 7,3,1
EndOn
On DoorClose Do
If [Reed2-close#Switch]!=1
TaskValueSet 7,3,1
EndOn
Re: several rules
Just to simplify, both reed should stop the motor regardless the state of the motor.
TaskValueSet 7,3,0 // Door state
If [Reed2-close#Switch]=1
TaskSet,7,1// here you can set the state of the door for later use
Event,DoorStop
If [Reed1-open#Switch]=1
TaskSet,7,0// here you can set the state of the door for later use
Event,DoorStop
Re: several rules
thx, added your rules partly.
state of door is already known by state of reed1 and reed2.
On System#Boot do
timerSet,2,10
// day or night
TaskValueSet 7,1,1
TaskValueSet 7,1,0
Event,DoorClose
Else
Event,DoorStop
//close door if Taster2 is pressed and door is not open
On Taster2-open#Switch do
If [Taster2-open#Switch]=1 and [Reed1-open#Switch]!=1
Event,DoorOpen
Else
Event,DoorStop
Event,DoorStop
Event,DoorStop
//stop motor if Reed1 or Reed2 triggered
Event,DoorStop
Event,DoorStop
// for all day close door at time if not closed
On Clock#Time=All,22:30 do
Event,DoorClose
Else
Event,DoorStop
//Events
On DoorOpen Do
TaskValueSet 7,3,1
EndOn
On DoorClose Do
TaskValueSet 7,3,1
EndOn
On DoorStop Do
TaskValueSet 7,3,0
EndOn
Re: several rules
You complicate yourself
This:
Should be only
You don't need to check the state of the motor if you want to stop it.
This:
Event,DoorStop
Event,DoorStop
Event,DoorStop
Re: several rules
thx danmero, changed it.
Users browsing this forum: No registered users and 129 guests
