After mega-20180426-normal sending TEXT tro OLED don't work
Re: After mega-20180426-normal sending TEXT tro OLED don't work
.... ahhh! Got it
I will check that out in the evening and will report asap.
Thx a lot!
Thx a lot!
DLzG
Micha
Micha
... half and half ...
I have enter part one as new rule and send "set WM_08 event CL=4" from FHEM...
It clears the first 2/3 of the line and leave the rest of it untouched
I.E.: From ...
BR: . STAND BY .
stay after command ...
BY .
So I can say that the base are right but only clear 12 signs from start
I.E.: From ...
BR: . STAND BY .
BY .
DLzG
Micha
Micha
What is the "Display Size" on OLED SSD1306 configuration?
Regards,
Edit: we are talking on two different versions , upgrade to the latest nightly built
Regards,
... nope, not possible! After 20180522 there is a BUG so that I can't send nothing. See also the Topic and the first messages here ...
DLzG
Micha
Micha
I test on 20180606
... don't work with FHEM. The BUG slime in at 0524 and is present in all versions from 0524 till today ...
DLzG
Micha
Micha
What you see as a bug, other see as improvement.
Maybe you can adapt/adjust from here.
Regards,
Regards,
hu? If I can't send Text is a improvement? Sorry, can't follow that ...
DLzG
Micha
Micha
You did send the text(fact) however not in the new format as per changes.
I will take a look at plugin code and try to spot the changes.
Regards,
Regards,
... ahhh! I haven't read anything about a new format
I also have ask for that in my 1st post of this topic with no hint- response:
EDIT say:
What I do not understand is why such changes are nowhere documented? The developer/s of the module/s must know what the new format should look like ?!
Folks like me are not able to understand the code of a modul and certainly not able to read out any changes ...Or has something changed meanwhile what I have not noticed yet?
EDIT say:
DLzG
Micha
Micha
... any news maybe about the changed parameter?
DLzG
Micha
Micha
- budman1758
I too would li8ke to know what the commands to write to the display have changed to. If it has changed it would be nice to know the differences are.
... looks as if no more sow cares, just like to the matter with the BME280 (viewtopic.php?p=28956#p28956) ...
That's a pity. I think the system is pretty good, but of course with this way of "support" you get the best OpenSouce software broken down quite quickly.
There is nothing left to do but switch to another system where support isn't a unknown word ...
DLzG
Micha
Micha
We're doing our best to get it stable and thus some issues are taking more time than anticipated. I'm sorry you're thinking our support is not good. I will improve.M*I*B wrote: ↑30 Sep 2018, 20:32 ... looks as if no more sow cares, just like to the matter with the BME280 (viewtopic.php?p=28956#p28956) ...
Did you open an issue on GitHub?
... I have not say it's not good. I have say that the support not exist ...
It's month ago not only I ask for the new implemented parameter. Normaly if someone implement new parameter or attributes there is a changelist where the (what the name say) changes are documented... But here is nothing... Just changed and leave all alone with that. That's the same i.e. I cut a single cable in your home but don't tell you whith one and who ...
DLzG
Micha
Micha
I totally understand you. We will get better in the change log, at least for stable releases, maybe not much better for nightly. But have you opened one or more issues on GitHub? We have very little time to parse through the forum on search of issues.M*I*B wrote: ↑30 Sep 2018, 20:55 ... I have not say it's not good. I have say that the support not exist ...
... no ... Some time ago I have tell you that I don't know what GitHub is and how to handle ... I'm not a programmer/coder... I'm just a simple user with much scills in hardware and do my best to report faults and/or achievements and also ever be there to test some new things. But if I have'nt any things to test or have'nt any docs/changelist to read I can't check and test anything. And I believe that most of the users here also just users and don't know to handle GitHub but are able to describe problems and wishes in a forum like this ...
DLzG
Micha
Micha
Ok, then it's a bit hard for us to take care of those issues. We prefer you to use the GitHub issue tracker since it'll keep you updated with current status. We're not (yet) a big company so it's essentially me and TD-er taking care of everything around here. Once we get a chance to release a first stable we'll get more up to date with the documentation. I hope you understand our side of the story, we're doing our best and will get better doing it. Please bear with us.M*I*B wrote: ↑30 Sep 2018, 22:04 ... no ... Some time ago I have tell you that I don't know what GitHub is and how to handle ... I'm not a programmer/coder... I'm just a simple user with much scills in hardware and do my best to report faults and/or achievements and also ever be there to test some new things. But if I have'nt any things to test or have'nt any docs/changelist to read I can't check and test anything. And I believe that most of the users here also just users and don't know to handle GitHub but are able to describe problems and wishes in a forum like this ...
... I understand you and your point of view ... That's not the problem. But I think you also have to take care of this user that can't handle GitHub; I believe that are the most.
If I have to wait 6 month or more without result for a thing I'm watching out for an other way to do it. In my matter it is the BME280 (it goes cold again and I have no way to mount this on the roof before next springtime) and the O-LED that meanwhile is the 4rd one due nobody knows about the dimmimg-attributes that are important for the livetime of this type of display... And meanwhile my stock of this displays are near empty due I have to replace it all 2-3 month... Gradually to destroy hardware and not to move forward is not really useful and not my goal ...
Maybe it's time to think about an other way where you not spend more time while pharsing the forum for issues but give the user without GitHub experience a way to incorporate the problems into the development. I'm sure that there is a viable solution that meets all sides, which does not leave the pure user in the rain and thus makes the project itself more manageable and thus more popular in the medium term...
DLzG
Micha
Micha
The Framed Oled plugin has support for dimming (not the normal OLED plugin)
I did add an issue about it: https://github.com/letscontrolit/ESPEasy/issues/1506
But I've simply been too busy fixing other stuff, that it kinda slipped my mind.
I have re-read the topic and am now looking at the source code of the plugin.
It looks like it is looking for "," (a comma) as parameter separator.
For example:
Becomes:
And about the 'support'.
We're spending a hell of a lot of time in making it a better product, and maybe the time isn't spent as optimal as possible.
I do most of the coding (like 90+%) and thus visit the Github page the most.
I try to visit the forum also on a regular basis, but when I do, it takes about half of my evening reading through all the new replies and helping out where I can.
Also on the reported issues at Github, a lot of time is lost in trying to gather enough info to get an idea on what is really happening.
It is all done in our free time.
This is not meant as an excuse on why your question was missed a number of times, just some view on what is going on here.
We're simply short on time and manpower and there is too much which has to be done.
For me, the last few months have been mainly about getting stuff stable and making sure a lot of code duplication was taken out.
A lot of code was <cut><paste><paste><paste><paste> and then altered in just a few lines to match its use.
The problem with that kind of development is that when you fix something in the first few "paste" occurrences, it is still broken in the others.
That's probably also what happened to this OLED command, that it got broken by changing something else.
For example:
oled 4 1 Some Text here
oled,4,1,"Some Text here"
Users browsing this forum: No registered users and 138 guests
