Serial input to MQTT
redskinhu
#1 Post by redskinhu » 17 Jun 2018, 23:25
I have a small problem. My esp is connected to the alarm system through serial to the rx/tx pins with level converter.
I use the Serial Server plugin. I would like to send the received data to my HASS server through MQTT. I created a rule to publish the recieved data.
On !Serial# do
  publish home/ESP07/Alarm,%eventvalue%
If the esp get data from the alarm the !Serial# event is fired. Rule is working, it publish.
But i get this: home/ESP07/Alarm/!Serial#, doesn't matter what is the received data.
I know this plugin is not created to doing this. I thought maybe i can catch the data from the %eventvalue%. But not.... :(
Any idea how can i get the real data? Other plugin?
T
xury
Re: Serial input to MQTT
#2 Post by xury » 26 Jun 2018, 23:15
Hi I just read about your problem and I have an idea.
On !Serial# do
Because !Serial# does not have a value name.
You can try use a prefix on sending data as: myname= and after send your data
Obviously if you have an impact on the format of the data being sent to esp trough serial
When try a rule as:
On !Serial#myname do
dirk_k
#3 Post by dirk_k » 02 Jul 2018, 11:00
i use the following syntax
On Serial#myname do
publish home/ESP07/Alarm,[Serial#myname]
Users browsing this forum: Ahrefs [Bot] and 47 guests
