corrupted platformio.ini
error option u'lib_archive' in section u'env:normal_ESP8285_1024' already exists'
uncommented lib_archive
-lib_archive = ${common.lib_archive}
+;lib_archive = ${common.lib_archive}
After I fixed platformio.ini
platformio run
only esp32dev was successfull the reset ended in
error *** [.pioenvs/hard_Ventus_W266/firmware.elf] Implicit dependency `.platformio/platforms/espressif8266/builder/;' not found, needed by target `.pioenvs/hard_Ventus_W266/firmware.elf'.
Can build with PlatformIO
Re: Can build with PlatformIO
Download the full source from GitHub.
When you compile you might get an error, this is due to leftovers from our (we the developers) previous compile.
Run the compile again and PlatformIO will delete these leftovers.
Be happy
Be happy
I did do some edits in the past week, but Travis is building fine.
Have you tested getting the last version from Github, like Grovkillen suggested?
Build on PlatformIO, version 3.5.4 on ubuntu 18.04
lib_archive already exists in section in platformio.ini
186) lib_archive = ${common.lib_archive}
419) lib_archive = ${common.lib_archive}
There is something odd.
Benno
Benno
Thanks for the pull request, I merged it.beigenmann wrote: ↑15 Jul 2018, 16:17 Build on PlatformIO, version 3.5.4 on ubuntu 18.04
Benno
Users browsing this forum: No registered users and 56 guests
