_P111_RF.ino
Posted: 14 Jul 2018, 07:26
I'm new to ESPEasy and I'm trying to use the RF receiver plugin.
When I refresh devices tab, I can see that the receiver works well; the rf code change every time I push a remote button but In the log nothing happen and Domoticz don't receive the code.
When I open the log tab, I can see only the first code received and nothing after (even if the value change in the device tab)
CAn someone help me with this?
Thank you in advance
Chris
4023902: Load File stats: Count: 15 Avg/min/max 8459.73/1339/18477 usec
4023902: Plugin call 50 p/s stats: Count: 1414 Avg/min/max 890.41/745/1293 usec
4023903: Plugin call 10 p/s stats: Count: 288 Avg/min/max 993.93/906/1347 usec
4023903: Plugin call 10 p/s U stats: Count: 288 Avg/min/max 3507.58/3017/4441 usec
4023903: Plugin call 1 p/s stats: Count: 30 Avg/min/max 10663.83/1522/48728 usec
4023904: checkSensors() stats: Count: 30 Avg/min/max 869.13/524/6958 usec
4023904: sendData() stats: Count: 6 Avg/min/max 42588.33/38898/46044 usec
4023904: WD : Uptime 67 ConnectFailures 0 FreeMem 13816
4031861: FILE : Saved config.dat
4041810: RF Code Recieved: 25062154
4041810: For sending this command,
4041811: use URL: http://ESP_03/control?cmd=RFSEND,25062154,1,25
4044643: Domoticz: Sensortype: 20 idx: 201 values: 25062154
4053905: LoopStats: shortestLoop: 43 longestLoop: 4206929 avgLoopDuration: 90.98 systemTimerDuration: 29.60 systemTimerCalls: 30 loopCou
4053909: WD : Uptime 68 ConnectFailures 0 FreeMem 13792
4083910: LoopStats: shortestLoop: 43 longestLoop: 4206929 avgLoopDuration: 78.87 systemTimerDuration: 31.32 systemTimerCalls: 31 loopCou
4083915: WD : Uptime 68 ConnectFailures 0 FreeMem 13816
Chris
