I'm working on a device plugin that has both standard Values and CustomTasks. During the Interval timer both Values and CustomTask events are processed/sent as expected. However, some users only want the Values sent during the initial trigger, but not at the timer interval. Instead, only the CustomTasks would be processed at the interval.
I searched existing device plugins for an example but it appears this is a unique requirement. Is it possible to do this in the plugin without any changes to other ESPeasy modules?
Advice needed: Prevent Sending Event Values at Interval Time
Re: Advice needed: Prevent Sending Event Values at Interval Time
I'd say they should use rules for that.
Yep, do not connect a controller to that plugin, but use the rules to fetch the values and send them when needed.
Thanks for the advice. I prefer using rules too, which is how I handle it. But suggesting this has not been received with much love.
I believe I have a solution for the customized plugin. Just waiting for user feedback.
I've added a test in PLUGIN_READ that checks the UserVar values. If they have not changed then they are ignored and not sent during the timer interval. Fingers are crossed that the feedback is overflowing with love.
I just finished (Pull request is ready) moving the sensor timers to the new scheduler.
This allows a plugin to set its own schedule if you like.
By default the set delay is being used, but you could set a new one from within the plugin code itself.
This allows to set the delay to some near infinite value ("0") and the plugin may set a new value to make the scheduler handle the "PLUGIN_READ" as soon as there is something changed.
Just call
"runAt" can be set to "millis()" or maybe "millis() + 10" to allow for some delay of 10 msec from now.
Task_index is set in the event and it represent the task (plugin) number in the list (note offset of 1)
This allows plugins to react much more responsive.
It also means the real work has to be done in the calls to 50/sec and 10/sec calls (or 1/sec).
And please do as little as absolutely needed in those time-critical calls, to help not to block the system.
Just call
schedule_task_device_timer(task_index, runAt);
@TD-er:
Brilliant. Thank you for the new functionality.
As far as i have seen, this functionality now needs "TimerOption = true" to work. (which i want to avoid)
Is there another way to get "PLUGIN_READ" triggered from inside a plugin?
