The current version of ESP Easy contains a bug which causes HTTP advanced not being able to send multiple pieces of data. A single piece of data is possible but when you use %LF% to add another piece of data it will cause a error. So the use of HTTP Advanced is very limited at this moment
the bug is described here : https://github.com/letscontrolit/ESPEasy/issues/1306
Now I have discovered that HTTP Advanced in ESPEasy v2.0.0-dev7 doesn't have this limitation. I really want to get the sensor SDS011 to work. Would it be possible to add the sds011 to the dev7? Or are there smarter options to bypass the limitations of the HTTP advanced bug?
Looking for workaround HTTP Advanced bug
Users browsing this forum: Google [Bot] and 148 guests
