mega-20180801 bug
sylvaing26
mega-20180801 bug
#1 Post by sylvaing26 » 02 Aug 2018, 11:46
sorry for my bad english... I'm french.
Since I've flashed my Wemos D1 with mega-20180801 firmware, I've bugs.
Log doesn't work, I've "Fetching log entries..." but nothing other
And the rules doesn't work too but activated.
I've created a dummy device and this event
on Test do
TaskValueSet 1,1,1
In my webborther I go to http://192.168.31.2/control?cmd=event,Test
I've Ok message but the event do nothing in the first value of my dummy device...
Do you have this bugs ?
Re: mega-20180801 bug
#2 Post by grovkillen » 02 Aug 2018, 12:55
The rule you provided work just fine for me (though I got the dummy on task number "4" instead of your "1"). And the log is fetching entries like it's supposed to. Have you made sure you got the serial logging on?
sylvaing26
#3 Post by sylvaing26 » 02 Aug 2018, 15:02
Sorry I don't know
I've just flashed with the v2.0-20180322 and I've not the problems...
In Git, I've not see the sames bugs on the pulls requests...
It's strange :?
#4 Post by grovkillen » 02 Aug 2018, 20:02
Maybe some garbage in the flash procedure? It's not an 100% hit rate when it comes to serial programming.
sylvaing26
#5 Post by sylvaing26 » 03 Aug 2018, 09:04
It's possible.
I've not flash again with this version.
But if I'm lonely with this bugs, you're probably right ;)
I'm not lucky !
#6 Post by TD-er » 03 Aug 2018, 22:01
Make sure you set the log level for the web log view to the right level.
Default is "Error" + "Info" if I remember correctly.
Users browsing this forum: Google [Bot] and 15 guests
