[help] many difficulties to compile a plugin
tparvais
#1 Post by tparvais » 10 Aug 2018, 17:36
Generally, the compilation of production code "Mega" as available on github is working fine on Arduino 1.8.5 and ESP8266 board (2.3.0)
I want to compile a dev plugin available on https://github.com/jodur/ESPEASY_Plugin_ITHO
I simply copy it to my source file, copy also the libraries to arduino lib and uncomment #define PLUGIN_BUILD_DEV in ESPEASY.ino (btw, I'm not sure this plugin used this flag for compilation).
When compiling the all stuff, I got error
_P145_Itho:150: error: 'PLUGIN_EXIT' was not declared in this scope
case PLUGIN_EXIT
indeed, PLUGIN_EXIT does not seem to be something existing (yet?) in mega-ESPEeasy framework.
Is that correct ?
any help would be very appreciated
Thomas
Re: [help] many difficulties to compile a plugin
#2 Post by TD-er » 10 Aug 2018, 22:21
Just add that PLUGIN_EXIT case and set success to true.
There is no pointer to a struct which has to be deleted, so it can be something like:
     case PLUGIN_EXIT:
          success = true;
Your next error you will probably experience is caused by this section:
     case PLUGIN_WEBFORM_LOAD:
		  addFormSubHeader(string, F("Remote RF Controls"));
          addFormTextBox(string, F("Unit ID remote 1"), F("PLUGIN_145_ID1"), PLUGIN_145_ExtraSettings.ID1, 23);
          addFormTextBox(string, F("Unit ID remote 2"), F("PLUGIN_145_ID2"), PLUGIN_145_ExtraSettings.ID2, 23);
          addFormTextBox(string, F("Unit ID remote 3"), F("PLUGIN_145_ID3"), PLUGIN_145_ExtraSettings.ID3, 23);
          success = true;
You will have to remove the "string" parameter in these function calls. At least, when you are using a fairly recent version of the source tree of ESPeasy.
tparvais
#3 Post by tparvais » 10 Aug 2018, 22:52
Thank you for feedback.
This is definitely a nightmare for me to compile it on the last source :-(
Many many compilation errors :-(
Thomas
tparvais
#4 Post by tparvais » 31 Aug 2018, 16:50
it"s done, compiled and it works partially, but at least for the tasks I need
Thomas
Users browsing this forum: Ahrefs [Bot] and 131 guests
