Hello. I have a rule:
on Sensor4#State do
TaskValueSet 5,1,[Sensor1#State]+[Sensor2#State]+[Sensor3#State]+[Sensor4#State]
On MessageSize#Size do
if [MessageSize#Size]=0
gpio,2,1
gpio,2,0
And the Dummy device (MessageSize task 5) update interval is 600.
Why does not the second event start immediately when the first event is triggered? This happens only after the expiration of the next interval of 600 seconds.
If at the end of the first event I add the following line: Publish /%sysname%/MessageSize/Size,[MessageSize#Size], the previous value will be sent to the MQTT broker rather than calculated in the first line.
I will try to explain in more detail:
Step 1. MessageSize#Size = 1
Step 2. the value of Sensor4#State changes
Step 3. Running TaskValueSet 5,1,[Sensor1#State]+[Sensor2#State]+[Sensor3#State]+[Sensor4#State] // (MessageSize#Size = 2
Step 4. Running Publish /%sysname%/MessageSize/Size,[MessageSize#Size]
Step 5. the value 1 is sent to the MQTT broker! In this case, the new calculated value 2 will be sent only after the interval of 600 seconds has elapsed
What i am doing wrong?
Help with Rule. Dummy device update
Re: Help with Rule. Dummy device update
You could trigger the event with the task run command.
Thank you.
on Sensor4#State do
//MessageSize#Size = 1
TaskValueSet 5,1,[Sensor1#State]+[Sensor2#State]+[Sensor3#State]+[Sensor4#State] //MessageSize#Size = 2
TaskRun,5
Publish /%sysname%/MessageSize/Size,[MessageSize#Size] //it send 1 to broker!!!
LOG:
ACT : Publish /Entrance/MessageSize/Size,0
26901515: Command: taskvalueset
26901517: Command: taskrun
26901522: Dummy: value 1: 1.00
26901522: Dummy: value 2: 0.00
26901522: Dummy: value 3: 0.00
26901522: Dummy: value 4: 0.00
26901525: EVENT: MessageSize#Size=1.00
26901570: ACT : gpio,2,0
26901572: SW : GPIO 2 Set to 0
26901576: EVENT: MessageSize#=0.00
26901603: EVENT: MessageSize#=0.00
26901629: EVENT: MessageSize#=0.00
26901703: Command: publish
Why it send 1 to MQTT broker???
on Sensor4#State do
TaskRun,5
LOG:
I think maybe the task run is executed before the task value is set. You should really bump the log level and test it all.
I dont understand anything...
Log level INFO:
SW : Switch state 0 Output value 1
142801: EVENT: Sensor1#State=1.00
142833: ACT : TaskValueSet 5,1,1+0+0+0
142847: ACT : TaskRun,5
142875: ACT : Publish /Entrance/MessageSize/Size,0
142954: Command: taskvalueset
142956: Command: taskrun
142960: Dummy: value 1: 1.00
142960: Dummy: value 2: 0.00
142961: Dummy: value 3: 0.00
142961: Dummy: value 4: 0.00
142963: EVENT: MessageSize#Size=1.00
143013: ACT : gpio,2,0
143016: SW : GPIO 2 Set to 0
143021: EVENT: MessageSize#=0.00
143048: EVENT: MessageSize#=0.00
143074: EVENT: MessageSize#=0.00
143141: Command: publish
Log level DEBUG More:
221499: EVENT: MessageSize#Size=1.00
221537: [if 1=0]=false
221540: else = true
221542: ACT : gpio,2,0
221544: SW : GPIO 2 Set to 0
221548: EVENT: MessageSize#Size=1.00 Processing time:49 milliSeconds
221549: EVENT: MessageSize#=0.00
221575: EVENT: MessageSize#=0.00 Processing time:26 milliSeconds
221576: EVENT: MessageSize#=0.00
221604: EVENT: MessageSize#=0.00 Processing time:28 milliSeconds
221605: EVENT: MessageSize#=0.00
221631: EVENT: MessageSize#=0.00 Processing time:26 milliSeconds
221656: MQTT : /Entrance/MessageSize/Size 1
221672: Command: publish
The subscriber gets the value 0!
Log level INFO:
221540: else = true
Must be some bug. Please report your finding to our GitHub issue tracker and also refer to this forum topic.
Users browsing this forum: No registered users and 140 guests
