do I need to define a variable state?
hi,
I have created a dummy device called "Dimmer" and given it values names "1" and "2"
creating the following rule and without the IF I can switch on and off at the given times but I want the PWM to increment by 1 every second and as it stands nothing happens.
what am I doing wrong?
something daft I am sure but a pointer would be a huge help
on Clock#Time=All,15:22 do //will run once a day at ?am
if [Dimmer#1]<4095
Delay 1000
[Dimmer#1]=[Dimmer#1]+1
PCAPWM,0,[Dimmer#1]
PCAPWM,1,[Dimmer#1]
on Clock#Time=All,15:30 do //will run once a day at ?am
if [Dimmer#1]>0
Delay 1000
[Dimmer#1]=[Dimmer#1]-1
PCAPWM,0,[Dimmer#1]
PCAPWM,1,[Dimmer#1]
if [Dimmer#1]<4095
Delay 1000
PCAPWM,0,[Dimmer#1]
PCAPWM,1,[Dimmer#1]
if [Dimmer#1]>0
Delay 1000
PCAPWM,0,[Dimmer#1]
PCAPWM,1,[Dimmer#1]
Re: do I need to define a variable state?
ok made a few changes and slowly getting there.....
I have changed the dummy device to "light" and variables to "dim1" and "dim2"
on Clock#Time=All,16:15 do //will run once a day at ?am
if [light#dim1]<4095
Delay 100
TaskValueSet 2,1,[light#dim1]+1
PCAPWM,0,[light#dim1]
PCAPWM,1,[light#dim1]
else TaskValueSet 2,1,4321
I now have "dim1" increasing with each run through the if and the PWM is set to one less than dim1 but the if only runs once.
how can I get it to loop until "dim1" =4095? this is how I would expect an if to work being captured until the condition is met to move on but this does not seem to be how its working here.
changed to :
on Clock#Time=All,16:24 do //will run once a day at ?am
if [light#dim1] and [light#dim1]<4095
Delay 100
thinking this should trigger on value change but nope - might be as its in the on command - will take it out see if that works
Delay 100
changed to :
Delay 100
well 4 hours later and I am getting fed up of something that should be simple giving garbage outputs and nonsensical logs.
is this just a case of not being something that can be done with rules?
I have tried multiple ways of getting a trigger and simple increments to variables which according to the wiki should work but that's not what I am finding.
current code that's getting close to doing something is :
problem is the log which shows :
grasping at straws I split out incrementing light#dim1 so that it is light#dim3 that becomes light#dim1+1. this is then copied back to light#dim1.
this should be unnecessary but it was done to help debug where its going wrong as are the varying number increases used.
whats got me confused is the log shows taskvalueset commands that have numerical detail but the numbers are not changed and other taskvalueset commands with no detail. it looks like its gone through the loop a couple of times but none of the dummy variables have updated as expected.
hopefully someone can help point me in the right direction but I have had it for today. need to come back to this with a clear head and a nights sleep
on Clock#Time=All,19:49 do //will run once a day at ?am
if [light#dim1] < 4095
TaskValueSet 2,3,[light#dim1]+1
TaskValueSet 2,1,[light#dim3]
Delay 100
TaskValueSet 2,2,1
TaskValueSet 2,3,[light#dim1]+5
Delay 100
TaskValueSet 2,4,1
TaskValueSet 2,3,[light#dim1]+2
32719: EVENT: light#dim1=0.00
32733: EVENT: light#dim2=0.00
32745: EVENT: light#dim3=0.00
32758: EVENT: light#dim4=0.00
34516: ACT : Delay 100
34533: ACT : PCAPWM,0,0
34539: PCA 0x40: GPIO 0
34548: ACT : PCAPWM,1,0
34553: PCA 0x40: GPIO 1
34577: ACT : TaskValueSet 2,3,0+5
34596: ACT : TaskValueSet 2,1,0
34609: ACT : Delay 100
34627: ACT : PCAPWM,0,0
34630: PCA 0x40: GPIO 0
34639: ACT : PCAPWM,1,0
34644: PCA 0x40: GPIO 1
34659: ACT : TaskValueSet 2,3,0+2
34678: ACT : TaskValueSet 2,1,0
34740: Dummy: value 1: 0.00
34740: Dummy: value 2: 0.00
34740: Dummy: value 3: 0.00
34741: Dummy: value 4: 0.00
34744: EVENT: light#dim1=0.00
34764: EVENT: light#dim2=0.00
34784: EVENT: light#dim3=0.00
34800: EVENT: light#dim4=0.00
34818: Command: taskvalueset
34820: Command: taskvalueset
34821: Command: delay
34928: Command: taskvalueset
34935: Command: taskvalueset
34937: Command: delay
35045: Command: taskvalueset
35046: Command: taskvalueset
35716: Dummy: value 1: 0.00
35716: Dummy: value 2: 0.00
35716: Dummy: value 3: 2.00
35716: Dummy: value 4: 0.00
35719: EVENT: light#dim1=0.00
35732: EVENT: light#dim2=0.00
35745: EVENT: light#dim3=2.00
35757: EVENT: light#dim4=0.00
Multiple ifs are not yet supported.
And you should really start small and add stuff as you go.
Try this
And go from there
TaskValueSet,2,3,[light#dim1]+1
TaskValueSet,2,2,1
ok.....
but each if on its own only runs once. I would have expected a if to loop until the condition was satisfied but this does not work either.
what I am trying to achieve shouldn't be too tricky but if the rules don't let me then will I need to do this in the firmware and re upload?
how else can this result be achieved?
was hoping to avoid having to recompile and upload for any small changes but if that's the only way then thats how its done
I have started as described with just switching which worked then adding the dummy var and so on but as responses were unusual I added more complexity to see where it was breaking down.
will start again in the morning but its to inconsistent for me at the moment and wont loop cleanly. possibly use the timer commands to control the loop
Yes you can use events to do multiple ifs but you cannot do multiple ifs in the same "on".
But remember to do the event command last in the if/else to be sure any other commands are being processed before the event.
If you upload all your settings (screenshots) I'd be able to assist you better.
And to make it clear, the rules are parsed in the core loop. It's not a actual running code inside the ESP. So it's pseudo coding.
not sure there are any settings. vanilla upload and added the PCA9685 as 2w on D3 and D4grovkillen wrote: ↑21 Sep 2018, 22:13 If you upload all your settings (screenshots) I'd be able to assist you better.
added rules from the advanced tools and NTP server
doesn't look like I can upload a pic to this site and don't have any image hosting so hope that's enough. not even thought about adding MQTT and Domoticz control yet as I was hoping this should be able to be stand alone
You can upload using the attachment tab found below the response text editor.
sounds similar to Domoticz "blocky" great for really simple things but falls over if you want to do anything less simple.grovkillen wrote: ↑21 Sep 2018, 22:15 And to make it clear, the rules are parsed in the core loop. It's not a actual running code inside the ESP. So it's pseudo coding.
hoping I can work with or around any limitations.
all I am trying to do is bring 2 channels on the PCA9685 up gently over time so a simplification of one channel might look like :
10 at 09:00 start
20 set dim1 =0
30 if dim1 < 4095 (channel 1 PWM value = dim1 ) and (dim1 = dim1 + 1)
40 delay 1000
50 goto 30
both channels can be the same but would be nice to have them different.
if I can get one working ramp then I could go from there.
I know there is a PWM fade parameter but as this would be fading over hours not minutes or seconds its no good as it locks into the single thread.
I suspect this may be problematic with what I am seeing of rules and I may have to write it into the sketch and compile a new version but hopefully I am wrong.
thanks for that - missed the attachments below - was looking at the top with the other buttons - if only all forum were the same
any settings you need? like I said I have changed almost nothing from the default. thank you for the help
P.S. sorry for the bast back to BASIC mixed in - showing my age! cut my teeth on BASIC, COBAL and COMAL - I really dont miss those days! but a LOT has changed - mainly for the better!
Instead of delay you can use timer. That way you can build a "loop". Tomorrow I hope to have some time to help you out with that.
thanks,grovkillen wrote: ↑21 Sep 2018, 23:06 Instead of delay you can use timer. That way you can build a "loop". Tomorrow I hope to have some time to help you out with that.
I may be getting there
on Clock#Time=All,22:12 do //will run once a day at ?am
timerSet,1,1 //Set Timer 1 for the next event in 1 seconds
TaskValueSet,2,1,0
On Rules#Timer=1 do //When Timer1 expires, do
TaskValueSet,2,1,[light#dim1]+1
else 0.5
TaskValueSet,2,2,1
We are going to add sub second timers but we are not there just yet. But it's on the horizon.
amazing what a large G&T some food and great advice can do.
I think I got there....
I think it works, will find out if it turns on in the morning
need to tidy up so if the unit reboots the lights are either on or off but will do for now.
thanks again for the help
P.S. possible change would be if you go over the 2048 character limit then not deleting all changes and carefully commented lines back to the last version saved and just warn that you went over! (guess how I know it does this )
on Clock#Time=All,09:00 do //will run once a day at 9am
timerSet,1,10 //Set Timer 1 for the next event in 10 seconds
timerSet,2,10 //Set Timer 2 for the next event in 10 seconds
TaskValueSet,2,1,4095
TaskValueSet,2,2,4095
TaskValueSet,2,3,0
TaskValueSet,2,4,0
on Clock#Time=All,15:00 do //will run once a day at 3pm
timerSet,3,10 //Set Timer 3 for the next event in 10 seconds
timerSet,4,10 //Set Timer 4 for the next event in 10 seconds
if [light#dim1] > 2000
TaskValueSet,2,1,[light#dim1]-1
TaskValueSet,2,3,1
On Rules#Timer=2 do //When Timer2 expires, do
if [light#dim2] > 2000
PCAPWM,1,[light#dim2]
TaskValueSet,2,2,[light#dim2]-1
TaskValueSet,2,4,1
On Rules#Timer=3 do //When Timer3 expires, do
On Rules#Timer=4 do //When Timer4 expires, do
if [light#dim2] < 4095
TaskValueSet,2,2,[light#dim2]+1
Yes the rules editor need some love, I will give it some in a couple of weeks.
just thinking about ways to make this one more usable for me and thinking that I can split the ON routine from the OFF routine and the Reset routine when I write it and make them separate rules so that I can comment more thoroughly. also any reason that I cant use a dummy variable in the timer command so that the timer duration could be controlled without a rule change? also same with clock#time command.(see a problem as this is formatted differently )grovkillen wrote: ↑22 Sep 2018, 07:18 Yes the rules editor need some love, I will give it some in a couple of weeks.
going forward I will want to control 5 PWM channels so will need more space so splitting across several rules would be needed.
thinking rule 1 to set all the variables and reset timer
rule 2 with ON routine
rule 3 with OFF routine
rule 4 with RESET routine
good news is the lighting just came on
this is an aquarium LED lighting system but with 700W of lighting a soft start is nice
with the clock#time command would this work?
on Clock#Time=All,[clock#onh]:[clock#onm] do
It should work but you should change the dummy type to quad.
And you can use up to 4 "pages" of rules (2048 bits each).
what difference does the dummy type make?
just curious as I set that the first time but the 4 variables show no matter the type set
my poor fish will be getting a disco today as I start testing this
You used to have it set to quad for the core loop to take notice of all four values.
just thinking about - on Clock#Time=All,[clock#onh]:[clock#onm] do
if [clock#onm] is less than 10 will missing the leading 0 cause an issue?
so with :
[clock#onh] = 9
[clock#onm] = 0
[clock#onh]:[clock#onm] = 9:0 which I could see being a problem as the format isn't what is expected.
do you know what the result of this would be or will I need to test?
I think i will give my poor fish a break and set up another unit to test this on
so with :
[clock#onh] = 9
[clock#onm] = 0
Yes that would not render in a match. Time stamps need that leading zero.
You could use system variables maybe? And do tests on a bead board?
I keep forgetting I have breadboard!grovkillen wrote: ↑22 Sep 2018, 12:06 Yes that would not render in a match. Time stamps need that leading zero.
never have the correct dupont cables when I need them! need M-M so of course today can only find M-F or F-F but a breadboard will solve that too.
not ideal but for the moment just have to make sure I use minutes at 15, 30,45 not 00
I will have a look at system variables once I get it all working. if it goes according to plan then changes should be easy enough
thanks again
Instead of 00 you can use 59
exactly what I am doing. it works but its messy
trying to decide how far I want to go at the moment as I can add loads of variables so could setup everything in one rule and make any editing easy but not sure if I want to go that far.
its tempting as this is stand alone I don't need to add anything else
well I almost have it. the on and off routines work fine but the reset on boot is causing a problem.
I think I need to reference %systime% rather than clock#time but its not playing nice.
I started with :
If %systime% > [clock#onh]:[clock#onm]:00 and %systime% < [clock#offh]:[clock#offm]:00
but simplified to :
wont work either way though
I added the delays to make sure the clock updated and I can see from the log that the clock is running before the last delay
would you mind having a quick look at the following and if there is a better way let me know?
I started with :
but simplified to :
// Rule 1 set up
On System#Boot do //When the ESP boots, do
delay 1000
TaskValueSet,2,1,4095 // [light#dim1]
TaskValueSet,2,2,4095 // [light#dim2]
TaskValueSet,2,3,2000 // [light#dim3]
TaskValueSet,2,4,2000 // [light#dim4]
TaskValueSet,3,1,10 // [timer#on]
TaskValueSet,3,2,10 // [timer#off]
TaskValueSet,3,3,1 // [timer#reset]
TaskValueSet,3,4,0 //
TaskValueSet,4,1,14 // [clock#onh]
TaskValueSet,4,2,20 // [clock#onm]
TaskValueSet,4,3,14 // [clock#offh]
TaskValueSet,4,4,59 // [clock#offm]
TaskValueSet,5,1,1 // [step#on]
TaskValueSet,5,2,1 // [step#off]
TaskValueSet,5,3,100 // [step#reset]
TaskValueSet,5,4,0 //
delay 1000
delay 1000
timerSet,5,[timer#reset] //Set Timer 5
timerSet,6,[timer#reset] //Set Timer 6
also tried :
If %syshour% > 13
cant get this to trip the timers.
having got everything else to work I must have missed something daft but stuck again
If %syshour% > 13
You can always first try to add it to a dummy. I'm not sure system variables are up to speed for it to be used inline.
do you mean like :grovkillen wrote: ↑22 Sep 2018, 17:22 You can always first try to add it to a dummy. I'm not sure system variables are up to speed for it to be used inline.
TaskValueSet,3,4,%syshour%
tried this and the dummy is not set even though the clock is up and running
Okay I need to try it myself. I'm currently in the move with getting this ship floating
no worries, it's working just need to prepare for resets and power outs so not criticalgrovkillen wrote: ↑22 Sep 2018, 17:59 Okay I need to try it myself. I'm currently in the move with getting this ship floating
Just a pointer to help you write rules.
In the latest firmware builds (last 2 weeks I guess) I added a page on Tools => System Variables.
These show all system variables and their current output.
That may be useful for debugging.
thank you. I was using that but while I have managed to solve this eventually I don't understand why but I do know how
what I have found is that for some reason the %syshour% result is always "0" when this is used within On System#Boot do
even though the clock is up and running as confirmed by the logs and use of delays ....
to work around I just set a timer in the System#Boot then add the call for the %syshour% from outside the System#Boot command.
I don't think this is a bug as such just an unexpected way of using the commands.
I now have this up and running so I may post a copy into the applications in case someone else wants to have aquarium lighting but I need to add all the other channels as I only have the 2 white channels (cold and warm white) and need to add in the RGB control as well.
for debugging rules the logs could be better. I tried several options but in the end found throwing variable changes into places in each rule and watching the device tab the only way to see what was going on but it was hard work. the logs only told me a taskvalueset had happened but not what or which value was changed likewise no real timer info.
while the rules are a powerful tool they do not always perform as expected and when they don't debugging can be extremely difficult when there is no information to work with. in this case without putting variable changes into each command I had no way of knowing if the trigger or if statement or the actual command was the problem. and the comand giving an unexpected result only when used in a certain place was not the first thing you would expect when debugging
unfortunately I suspect that adding in this kind of debugging information for the rules would not be a simple task so while its frustrating at times I do understand that there are limitations.
We have several events you can use in rules.
The system#boot is just that, the boot.
There are also events when the time is set, so if you depend on the system time, I suggest to trigger a rule on that event and consider that one as a boot like event.
Users browsing this forum: Google [Bot] and 128 guests
