What a nice firmware for NodeMCU, great work guys!
Yesterday I tried to make a pulse counter for my electric meter.
I use a LDR to count the pulses.
It works great but I can't see the real time use.
I made two tasks that listen to GPIO 0.
If I have one of the two tasks active it work, but when activating both of them at the same time only the last saved work.
The other one won't count any pulses.
Is it any way to make it work?
ESPeasy version: mega-20180914
Controller: Domoticz
What I hope to do:
One IDX with total use in kWh and another IDX with real time use in W.
Problem: Two task, listen to same GPIO
Re: Problem: Two task, listen to same GPIO
You should use a dummy device to populate the Wh. Use rules for that. Study the wiki and come back here if you need more help.
For inspiration: https://testoftimes.com/2017/11/25/moni ... g-esp8266/
Thanks for the answer!
I had done it right all the way to domoticz.
But I've chosen the wrong type of "energy read' in the device of power meter.
When I selected Computed it works instantly.
Users browsing this forum: No registered users and 144 guests
