I've added support into P016 (IR RX aka TSOP4838) and P035 (IR TX) for reading and printing out RAW IR codes, and submitting for trasmit. It uses a new format that is short enough to be sent as a command, but also allows easy inspections and modifications after the code is constructed. I called it 'RAW2'. It functions independently of GusPS's RAW format, which has implemented a B32 compressed format. The new RAW2 support prints out a line to the log (Info level) similar to the following:
IRSEND,RAW2,191C1E1^30161H15151716*2151,38,267,134
The RAW2 format is as follows:
- IRSEND,RAW2,<code>,<frequency in KHz>,<pulse multiplier>,<blank multiplier>
- Every pulse or blank timing is converted into a multiplier to be multiplied by the corresponding pulse or blank multiplier.
- The multiplier is then encoded in the code as a single B32 Hex digit (0-9A-V).
- If the multiplier is greater than 31, it is encoded as two B32 digits with a '^' sign prepended.
- If 2 multipliers repeat, for example: 454545, they are replaced by '*' and a single times digit, and then the two multipliers. For eaxmple: *345.
Hope this helps anyone...
Cheers,
Gilad
