Setting OLED Contrast
I am looking for a possibilty to set the contrast of the display depending on an event. I would prefer to put it into rules to give domoticz the ability to adjust the contrast depending on sunrise/sunset.
Any ideas?
Any ideas?
pi@raspberrypi:~ $ man woman
No manual entry for woman
pi@raspberrypi:~ $
Re: Setting OLED Contrast
At this moment the Framed OLED plugin is the only one able to set the contrast.
The command is "OLEDFRAMEDCMD" and the options are:
- off
- on
- low
- med
- high
Commands can be sent from the rules.
- off
- on
- low
- med
- high
Thanks a lot, that is exactly what I was looking for. Done.
pi@raspberrypi:~ $
I was just trying this with the current build on my WeMos mini. However, every http call resulted in Unknown command. The Oled itself is working as expected. I would like to use the framed device for better readability but need to switch it off...
Is there a different way to test it?
Just a mistake in the command name ....
it should be : OledFRAMEDCmd,Display,.... on/off/low...
Patou
Patou
Perfect, couldn't find that information in the wiki. Works as expected!
Use the source, Luke!
Already on my todo listUse the source, Luke!
Users browsing this forum: Google [Bot] and 129 guests
