timer inside rules for a value less than a second
megamarco83
#1 Post by megamarco83 » 22 Oct 2018, 23:40
Hi, is it possible to use timer inside rules for a value that is less than a second?
i need to trigger a relay for a timer that is about 0.4seconds
now i have:
on event_UP_SHORT_blind_test_2 do
 if [relayp#R_UP_2]>0
  output,relayp,3,0
  output,relayp,3,0
  output,relayp,2,1
 timerset,1,2 // to trigger relay UP direction for 2seconds
but i need to trigger for a value that is 0.4seconds
is it possible?
thanks
Re: timer inside rules for a value less than a second
#2 Post by grovkillen » 23 Oct 2018, 06:10
Currently only seconds are possible. But you can use pulse commands.
megamarco83
#3 Post by megamarco83 » 23 Oct 2018, 11:01
grovkillen wrote: 23 Oct 2018, 06:10 Currently only seconds are possible. But you can use pulse commands.
i'm using multiple output plugin P_160
i try to use pulse in this way but it not works:
on event_UP_SHORT_blind_test do
 if [relayp#R_UP]>0
  output,relayp,0,0
  SendToHTTP 192.168.0.105,8085,/json.htm?type=command&param=updateuservariable&vname=blindControl&vtype=2&vvalue={"n"}
  output,relayp,1,0
  pulse,relayp,0,1,50
SendToHTTP 192.168.0.105,8085,/json.htm?type=command&param=updateuservariable&vname=blindControl&vtype=2&vvalue={"n":"blind_1","d":"UP","s":"2"}
why?
suggestions?
thanks
#4 Post by grovkillen » 23 Oct 2018, 11:38
That plugin is not in the official releases and I must ask you to take that issue with the developer of P_0160.
Users browsing this forum: No registered users and 152 guests
