I'm trying to get an PWM output with the last firmware 20102 - Mega.
Because i want to control an fanspeed based on an temp. input i must use the Regulator - Level Control.
I have setup the temp sensor as input and use GPIO13 (D7) as PWM output, only i see in the overview when the temp. is low an 1 and with it's rising an 0.
But with no indication for an analog (pwm) output.
Do i something wrong?
Let me know it.
Regards,
PWM output
Re: PWM output
I don't understand, do you want to know the PWM level?
Re: PWM output
Sorry for the cryptic description.
I want to have an pwm output so I can control an fan based on an pwm output.
Re: PWM output
Ok, you then need to use rules that does the PWM output.
Users browsing this forum: No registered users and 136 guests
