Hello!
I would like to emulate a push button switch to ground. I can do that with this :
pinMode(powerButton, INPUT);
digitalWrite(powerButton, LOW);
pinMode(powerButton, OUTPUT); // Pull the signal low to activate the power button
delay(100);
pinMode(powerButton, INPUT); // Release the power button.
BUT, can I do that with EspEasy?
How to emulate push button switch to ground
Re: How to emulate push button switch to ground
What do you mean? Please explain more...
Please review the GPIO commands explained here:I would like to emulate a push button switch to ground. I can do that with this : {snip}
https://www.letscontrolit.com/wiki/index.php/GPIO
I see that you require the emulated switch to be Hi-Z when not active (driven low). So the built-in GPIO pulse command cannot be used. The workaround is to use discrete GPIO commands and a system timer. Unfortunately the system timer only has 1000mS resolution so the switch will be active for 1 second minimum.
Here is a set of rules that will activate GPIO14 by calling Event SendSwitch
on System#Boot do
GPIO,14,2 // Hi-Z GPIO 14
on Rules#Timer=4 do
on SendSwitch do
timerSet,4,1
GPIO,14,0
Important: Do not connect anything directly to a GPIO pin that could drive the pin higher than 3.3V. Otherwise the ESP8266 can be damaged.
Thank you Thomas, that will probably do the trick. Just to be clear: I would like to parallel connect the ESP GPIO to the LED controller push buttons.
Also, thanks for 3.3V tip. I will have to use the level shifter.
BR
Bojan
BR
Bojan
Instead of a typical level shifter you could use a simple NPN or FET transistor buffer circuit. This would allow you to use the GPIO Pulse command which would simplify your rules and allow 100mS switch On times.
Yes, that is probably the simplest solution. Thanks a lot.
Bojan
Bojan
Users browsing this forum: Bing [Bot], Google [Bot] and 128 guests
