Chicken door and light
SqUaT
#1 Post by SqUaT » 12 Dec 2018, 21:49
I was trying to create some rules for my chicken.
Switch light on at 6:00 and switch off at sunrise + light on at sunrise and light off at 20:00
Later I would like to implement the door to open and close them automatically.
Additional I would like to toggle the light by pressing a button (key). Each parts of the code work alone.
My idea was to generate dummy variable to hold the state (light on morning, light on evening) and also use always the same code for switch the light, but it dosn't work propperly.
Could somebody tell me, what I'm doing wrong?
on System#Boot do
    timerSet,1,20
on Rules#Timer=1 do
    if %systm_hm% > 6:00 and %systm_hm% < %sunrise% or  %systm_hm%  > %sunset% and %systime% < 20:00
         GPIO,12,0//Relais
         GPIO,13,0//LED
		GPIO,12,1//Relais
         GPIO,13,1//LED
On Clock#Time=All,6:00 do // every day at 6:00 hours switch on relay on gpio 12
 gpio,12,0
 GPIO,13,0//LED
//at sunrise time switch light off//set timer1 for 1 hour
On Clock#Time=All,%sunrise% do
//timerSet,2,3600
 GPIO,12,1//Relais/light off
 GPIO,13,1//LED off
 //GPIO,1,0//door up
//at sunset time switch light on
On Clock#Time=All,%sunset% do
 timerSet,1,3600
 GPIO,12,0//Relais
 GPIO,13,0//LED
//When Timer1 expires, <action>
On Rules#Timer=1 do
 GPIO,1,0 // close door
On Clock#Time=All,20:00 do // every day at 20:00 hours switch off relay on gpio 12
 GPIO,12,1//Relais
 GPIO,13,1//LED
Re: Chicken door and light
#2 Post by grovkillen » 12 Dec 2018, 23:01
You have two Rules#Timer=1 which will not work. Only one is allowed.
SqUaT
#3 Post by SqUaT » 19 Dec 2018, 10:46
OK, one step before.
Switching light on and of via dummy
on System#Boot do
    timerSet,1,10
on Rules#Timer=1 do
if Dummy#Moring=1
 GPIO,13,0
//On Dummy#Moring=0 do
 GPIO,13,1
 //TaskValueSet 3, 1, 1
Another test was:
On Dummy#Moring=1 do
 GPIO,13,0
 GPIO,13,1
Or:
 GPIO,13,0
 GPIO,13,1
Domosapiens
#4 Post by Domosapiens » 19 Dec 2018, 14:04
I see
Moring
instead of
Morning
SqUaT
#5 Post by SqUaT » 19 Dec 2018, 19:50
Thanks, but the error exist. The Led is still off.
If I send the Gpio command via http, I get the following error.
http://IP/control?cmd=GPIO,13,1
Unknown or restricted command!
#6 Post by grovkillen » 19 Dec 2018, 19:51
What version?
SqUaT
#7 Post by SqUaT » 19 Dec 2018, 21:52
GIT version: mega-20181208
#8 Post by grovkillen » 19 Dec 2018, 23:45
Please update to latest, there might be a bug...
SqUaT
#9 Post by SqUaT » 20 Dec 2018, 14:28
That helps a bit. The error doesn't appears.
One thing I found was the missing "[]"
on System#Boot do
 timerSet,1,2
On Rules#Timer=1 do
 if [Dummy#Morning]=1
  //GPIO,13,0
  TaskValueSet,3,1,0
  //GPIO,13,1
  TaskValueSet,3,1,1
timerSet,1,2
Now the LED will go on an off, but (only by using gpio function), not with the following code.
On LED#LED=1 do
 if [LED#LED]=1
  GPIO,13,0
  GPIO,13,1
LED is Task 3 (TaskValueSet,3,...)
#10 Post by grovkillen » 20 Dec 2018, 17:30
SqUaT wrote: 20 Dec 2018, 14:28 That helps a bit. The error doesn't appears.
on System#Boot do
 timerSet,1,2
On Rules#Timer=1 do
  //GPIO,13,0
  TaskValueSet,3,1,0
  //GPIO,13,1
  TaskValueSet,3,1,1
timerSet,1,2
On LED#LED=1 do
 if [LED#LED]=1
  GPIO,13,0
  GPIO,13,1
On LED#LED do
 if [LED#LED]=1
  GPIO,13,0
  GPIO,13,1
I would rename the value to state.
LED#state
SqUaT
#11 Post by SqUaT » 22 Dec 2018, 00:24
Good. Renaming helps.
Now I create the following Code. On manually changes of state "morning" and "evening", the relay and the Led toggle, also on using the button. But the state will not change on time.
I activate ntp and set the location Settings. Additional I set DSP on.
Does somebody know, why the time and sunset/sunrise did not set the State properly?
on System#Boot do
    timerSet,1,20
on Rules#Timer=1 do
 if %systm_hm% > 6:00 and %systm_hm% < %sunrise% //morning - set state to indicate light on
  TaskValueSet 5,1,1
  taskRun,5
 if %systm_hm%  > %sunset% and %systime% < 20:00 //evening - set state to indicate light on
  TaskValueSet 5,2,1
  taskRun,5
 TaskValueSet 5,1,1
 taskRun,5
//timerSet,2,3600
 TaskValueSet 5,1,0
 taskRun,5
 TaskValueSet 5,2,1
 taskRun,5
 TaskValueSet 5,2,0
 taskRun,5
// morning - relay
on LightState#morning do
  if [LightState#morning]=1
   gpio,12,1
   TaskValueSet 5,2,1
   gpio,12,0
   TaskValueSet 5,2,0
// evening - relay
on LightState#evening do
  if [LightState#evening]=1
   gpio,12,1
   TaskValueSet 5,3,1
   gpio,12,0
   TaskValueSet 5,3,0
// Button - relay
on button#switch do
  if [button#switch]=1
   gpio,12,1
   TaskValueSet 5,3,1
   gpio,12,0
   TaskValueSet 5,3,0
// LED
on relay#switch do
  if [relay#switch]=1 //change this [relay#switch]=0 for LED off when relay is closed
   gpio,13,0 //or pwm,13,700
   gpio,13,1 //or pwm,13,10
Domosapiens
#12 Post by Domosapiens » 22 Dec 2018, 00:45
I'm not sure what you are doing but:
- Task LED on GPIO 13 is defined as Task 3 as input
- In the Rule you control GPIO 13 as output
- GPIO-0 is a special one! Has a Pull-up on most boards.
- That means your switch must be active Low (at least ... high at boot!)
- Use GPIO-14 instead, just to make sure
SqUaT
#13 Post by SqUaT » 26 Dec 2018, 21:31
I update to Version mega-20181220 and delete all devices which aren't in use.
But today at the evening, the LightState does not go to 1. after seting it manually, one Minute later it was switching back to 0 and the light go off.
How can I see the variable %systm_hm% to verify the correct time?
I have also test to delete the %sunrise% and %sunset% to fix times (8:30 and 16:00, but it didn't work.
The switch (button), the led and the relay works now correct.
on System#Boot do
    timerSet,1,20
on Rules#Timer=1 do
  TaskValueSet 3,1,1
  taskRun,3
  TaskValueSet 3,2,1
  taskRun,3
 TaskValueSet 3,1,1
 taskRun,3
 TaskValueSet 3,1,0
 taskRun,3
 TaskValueSet 3,2,1
 taskRun,3
 TaskValueSet 3,2,0
 taskRun,3
// morning - relay
   gpio,12,1
   gpio,12,0
// evening - relay
   gpio,12,1
   gpio,12,0
// Button - relay
on button#switch do
   gpio,12,1
   gpio,12,0
// LED
on relay#switch do
#14 Post by grovkillen » 26 Dec 2018, 22:59
In tools you have the system variables page.
SqUaT
#15 Post by SqUaT » 26 Dec 2018, 23:32
OK, the system variable are in the same format and nearly the same time as written before (8:31 an 15:50).
Could somebody find an error in the code, why the LightState was set to 0 today at 17:30?
Users browsing this forum: No registered users and 146 guests
