would this be supported?
anyone having experience here?
anyone using cjmcu-0101 sensor?
Re: anyone using cjmcu-0101 sensor?
Seems to be a capacitive switch.
If so it is supported by the "switch" plugin.
Did a bit of research.
It seems that the chip on the board (Marking 8223) is similar to the well known TTP223.
Maybe a remake from another company? From layout it is not an inductive sensor but I may err.
Anyways, as longas output is just a high/low signal it can be used with the switch plugin.
Looks like a regular (supported) switch.
I use these, they come by #10
https://nl.aliexpress.com/item/10Pcs-TT ... Title=true
ok thanks, I will give it a tryShardan wrote: ↑05 Jan 2019, 20:20 Seems to be a capacitive switch.
Users browsing this forum: No registered users and 130 guests
