I'm using ESPEasy with Home Assistant and have a buzzer hooked up and I currently use MQTT to play a tone with PWM. I want to actually use RTTTL so it's not just a continuous droning tone. Is there a way to repeat the sequence until a send MQTT message is received to stop? I want to create a sort of siren/two tone alarm for one condition (Side gate being left open too long etc). I suppose I could just repeat the RTTTL sequence multiple times and then every X second get Home Assistant to re-send the MQTT to start it again but that's not really the most efficient way to do it.
Tom
RTTTL Repeat
Re: RTTTL Repeat
Yes, using rules (with timer).
You then use the commands Event,PlayTune or Event,StopTune to start and stop the tune.
PS. Remember that RTTTL is blocking, meaning that the unit will play the tune from start till end. It will not be responding to any commands during this time.
On PlayTune Do
RTTTL,14,test:d=8,o=5,b=180,c6,b,c6,p,g,g-
TimerSet,1,2 //will play again in two seconds
EndOn
On StopTune Do
TimerSet,1,0 //disable timer
EndOn
On Rules#Timer=1 Do
Event,PlayTune
EndOn
Users browsing this forum: No registered users and 132 guests
